TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 31, 2016 at 11:29 AM
    #2221
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I just got my AFR gauge and URD y-pipe installed over the weekend. Thanks to @jaunitoBunito for answering all my questions.
    With afe CAI, URD y-pipe I'm seeing about 14.8-15 idle and normal driving and at WOT 13.8-14 AFR's. Truck was flashed last Nov. It seems that I'm getting less rich readings than others with the TRD flash. Think the flash might've been refined/changed recently or could the CAI leaned it out a little??
    JuanitoBonito likes this.
  2. May 31, 2016 at 11:31 AM
    #2222
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    14 @ wot is dangerously lean
    12TRDTacoma likes this.
  3. May 31, 2016 at 11:32 AM
    #2223
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah that's pretty lean, never heard of the reflash being so lean. Usually its rich or just barely rich
  4. May 31, 2016 at 11:35 AM
    #2224
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Mines a 2009... I have always been able to read and clear codes. Sounds like a rather similar situation. I doubt it'll be covered under warranty though. Too many miles on my truck. Plus I'm missing rock therapy because of this.
    MtnDesertTaco likes this.
  5. May 31, 2016 at 11:43 AM
    #2225
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    My scangauge worked with it fine and could read/clear codes but techstream and the ECU didn't get along. Hopefully you can find one in a junkyard or something.
  6. May 31, 2016 at 11:50 AM
    #2226
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    You have to plug the Bully dog in to the OBD port to get it to read right? It wouldn't be out of place to suggest that their plug bent your pins and then fucked up the communication between ECU's when it tried to talk to them with whatever was left. Hopefully this doesn't cause you even more issues in the future.
    VolcomTacoma likes this.
  7. May 31, 2016 at 11:59 AM
    #2227
    mightytacoman
    Kel
    4.5L 1grfe
    Yes Bully Dog plugs into the obd port, so does my bluetooth diagnostic code reader. My reader never had trouble reading realtime data or clearing codes etc and both plugged in without any problems or difficulty. It isn't like i'm hammering them in, they always push in nice and easy. should have more info at the end of the night
  8. May 31, 2016 at 12:00 PM
    #2228
    68vert
    AZ
    DCSB 4X
    Yeah thats what I was thinking too. Any suggestions to richen the AFR's up aside from reflashing? I'm guessing the gauge might be off slightly since its speedhut reading from AEM Uego. Plus the sensor is also downstream on passenger side.
  9. May 31, 2016 at 12:05 PM
    #2229
    glorifiedwelder
    jason
    Santa Clarita, ca
    I had my wideband post catalytic converter for a few weeks while I was waiting for my exhaust. Afr differences were negligible
  10. May 31, 2016 at 12:07 PM
    #2230
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    If anyone wants a CAI and is willing to pay some shipping I'm going to be selling mine soon. I'm going to a snorkel and in the interests of making things easy I'm rolling back to stock with the AFe prodry filter.
  11. May 31, 2016 at 12:09 PM
    #2231
    VolcomTacoma
    Jeff
    NorCal
    I ended up switching to the URD CAI from my AFE CAI just to fit an engine crossbrace. Thinking on modifying/cutting in the bend in the engine bay to add an exhaust cutout and run a Snorkel up with tubing as well. that way I run both unless I'm about to get hit with water or crazy dust and then run through the snorkel
  12. May 31, 2016 at 12:09 PM
    #2232
    68vert
    AZ
    DCSB 4X
    Yeah its weird cause ever since the reflash, my exhaust is always covered in soot from unburned gas. Never like that before. Not sure about the accuracy of my speedhut gauges. The boost gauge was so off I had to send back to them for recal. Now wondering if my AFR is the same
  13. May 31, 2016 at 12:11 PM
    #2233
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    You are missing what I'm saying. I'm saying that plugging in the Bully Dog did the damage. Even if you inserted it gently it could bend pins if it wasn't designed correctly.
    No blame on you. Your code reader only needs access to one module so it may still work after the Bully Dog damage, if that's what happened.
  14. May 31, 2016 at 12:12 PM
    #2234
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Meh, I'm not in the quest for the most HP ever. I'm actually happy now with the stock S/C and I'm probably going to roll back to stock exhaust as well. Maybe I'll do the headers at some point and maybe a pulley, but that's it.
  15. May 31, 2016 at 12:14 PM
    #2235
    mightytacoman
    Kel
    4.5L 1grfe
    Agreed. I'm hoping they can just take the obd apart and bend the pins back to get the ecu to squawk like it should. The quote to get the ecu replaced isn't pretty. But if the ecu was bad, shouldn't it throw a bad ecu code?
  16. May 31, 2016 at 12:15 PM
    #2236
    VolcomTacoma
    Jeff
    NorCal
    Intake swap wasn't for HP, it was because the AFE box was in the way of the Engine crossbrace. Snorkel idea is just for shits n giggles if I ever have to cross water.
  17. May 31, 2016 at 12:49 PM
    #2237
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I've found water in the bottom of my airbox after going offroad. Getting a snorkel is a real need for me.
  18. May 31, 2016 at 12:56 PM
    #2238
    VolcomTacoma
    Jeff
    NorCal
    Agreed.
  19. May 31, 2016 at 12:57 PM
    #2239
    VolcomTacoma
    Jeff
    NorCal
    Shit, I have to make a water crossing to get to work some days where the water is up to my floor boards, for 2 patches of about 100 feet.
  20. May 31, 2016 at 3:40 PM
    #2240
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I run both speedhut boost and wodeband gauges. I am using a PlX wideband controle module with a Bosch sensor. Most the time at idle or cruise i see between 14.5-15.0, when i dig into the power im seeing 11.0-11.3 with a 2.825 pully and no FPR mod at 75F air temps. With the mod im bottoming out at the 10.5 or less depending on ambient air. Also im at sea level.
