TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 31, 2016 at 8:47 PM
    #2261
    ThomasMore66
    Dallas/Fort Worth & Durango
    Time to get some. Is IRR a 50/50 water/glycol mix?
  2. May 31, 2016 at 8:47 PM
    #2262
    ThomasMore66
    Mine used to be. Check it with oil changes. Same with the catch can.
  3. May 31, 2016 at 8:49 PM
    #2263
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah, I should get in the habit of that.....the catch can I still haven't done and am up in the air if I'm gonna do it.
  4. May 31, 2016 at 8:55 PM
    #2264
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I would. In fact thats on my list to do. Right now all that oil feedback is coating your intercooler
  5. May 31, 2016 at 8:55 PM
    #2265
    ThomasMore66
    Mine is always about 3/4 full between oil changes.
    Gadget just emailed me back. Might be out of Y-pipes. 3 weeks for one if he doesn't have it. Sadness.
  6. May 31, 2016 at 9:04 PM
    #2266
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I remember the catch can was a hot topic a few months back. I thought some felt that certain seals would or could dry rot so to speak if it didn't have that oil.....I hope I explained that somewhat correct. There was also a debate on what and where that oil does and what it exactly affects. I see it like this, if it is something our trucks really need wouldn't there be a ton of problems for the guys that don't have them? If I'm way off, school me and make me a believer. If it makes sense, I'll do it.
  7. May 31, 2016 at 9:07 PM
    #2267
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Itl be worth the wait...
  8. May 31, 2016 at 9:07 PM
    #2268
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Welcome to talking about superchargers on TW. The only thing that is for sure is a dissenting set of opinions.
    I still haven't installed the catch can I ordered... and honestly I might not do it. Not that I don't think catch cans are useless, it's just that I'm unsure of how great a device they actually are.
    JuanitoBonito likes this.
  9. May 31, 2016 at 9:08 PM
    #2269
    ThomasMore66
    I bled installing mine. Freakin' pcv valve is hard to reach. Tor has one. I drank the coolaid. Think of your intercooler filled with oil. I'm a believer. Join us.
    JuanitoBonito[QUOTED] likes this.
  10. May 31, 2016 at 9:09 PM
    #2270
    VolcomTacoma
    Jeff
    NorCal
    The only thing that was pointed out to me about it for TRD superchargers, is that if you dont have one, your intercooler will start to soak up that pil overtime and reduce cooling
    Torspd likes this.
  11. May 31, 2016 at 9:10 PM
    #2271
    VolcomTacoma
    Jeff
    NorCal
    Ugh!!!! My hands cant fit lol. I ended up buying a set of like foot long needle nose to get in there and get that hose clamp on and off, now i just need to rig up a mounting spot
  12. May 31, 2016 at 9:13 PM
    #2272
    ThomasMore66
    It goes here.
  13. May 31, 2016 at 9:13 PM
    #2273
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So, I've seen how much oil it can catch. Would it be a wise thing to check the oil level and add a little to offset what's in the catch can? Or is it a dismissible amount?
  14. May 31, 2016 at 9:15 PM
    #2274
    VolcomTacoma
    Jeff
    NorCal
    Wait, where did you mount your resevoir? You have ATRAC I think? So yours mounted off the fender wall?
  15. May 31, 2016 at 9:16 PM
    #2275
    ThomasMore66
    Just pour this in your intercooler.
  16. May 31, 2016 at 9:17 PM
    #2276
    VolcomTacoma
    Jeff
    NorCal
  17. May 31, 2016 at 9:19 PM
    #2277
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Just playing devil advocate but won't running seafoam get rid of most of that gunk anyways?
  18. May 31, 2016 at 9:19 PM
    #2278
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  19. May 31, 2016 at 9:23 PM
    #2279
    ThomasMore66
    Until just now I thought it was Burrito. Wtf is Bunito?
  20. May 31, 2016 at 9:26 PM
    #2280
    ThomasMore66
    I made a special bracket. Screw the relay box.
