TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jun 8, 2016 at 3:45 PM
    #2341
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I picked up a supercharged Tacoma. I plan to do the 2.8 pulley down the road but picked up an AEM intake with pro dry s and jba ceramic headers. Planning to delete all the cats. Will the better breathing help? Besides the smaller pulley that's as far as I plan to go with performance. Will I need to do fuel pump?
  2. Jun 8, 2016 at 4:27 PM
    #2342
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    Thank you Juan
  3. Jun 8, 2016 at 4:40 PM
    #2343
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    No problem....7/32 black rubber vacuum hose. What I have left is a crap shoot whether or not will be enough for you so your better off just going to pick some up at the auto parts store. It's cheap so not to worry.
  4. Jun 8, 2016 at 5:00 PM
    #2344
    richiep
    Rich
    NY
    Thanks again for checking, did you use hose clamps or is it just a nice tight fit?
  5. Jun 8, 2016 at 5:46 PM
    #2345
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Nice tight fit on the nipple of the s/c. I used a clamp on my nipple of my boost gauge but I totally didn't have to.....now lookingb ack, I have no idea why I did.
  6. Jun 8, 2016 at 9:41 PM
    #2346
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    congrats on the purchase. fuel pump is not required but recommended. Do you have an air fuel ratio gauge?
  7. Jun 8, 2016 at 10:39 PM
    #2347
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    No I do not
  8. Jun 10, 2016 at 7:59 PM
    #2348
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  9. Jun 12, 2016 at 8:30 AM
    #2349
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Some boost gauges come with a rubber adapter for that nipple. Some come with cheap rubber hose. Either way, at that nipple, over time the hose or adapter will crack and cause a vacuum leak. Just make sure to visually inspect it every once in a while.
    JuanitoBonito likes this.
  10. Jun 12, 2016 at 3:22 PM
    #2350
    richiep
    Rich
    NY
    Thanks Tor, i found some 7/32 hose & it seems to work perfect.
    I will keep an eye on it.
  11. Jun 12, 2016 at 3:29 PM
    #2351
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Just cut the depth down and repaint
  12. Jun 12, 2016 at 3:53 PM
    #2352
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So, break time, my back is killing me, turns out the Supercharger moves the throttle body over a bit, so the URD intake doesnt fit lol. Had to cut the intake down near the throttle body as the bends were hitting the headlight. Well see if i can get it to twist enough to fit with the SC radiator in the way
    @Torspd
  13. Jun 12, 2016 at 4:02 PM
    #2353
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    That's actually the easy part to deal with. The fun part is getting to fit in the grill. It's designed to sit where the water cooler is for the supercharger. So you'll need to modify the bracket that goes on the core support and clearance the back of the grill. It wasn't too bad but took a bit of fitting
  14. Jun 12, 2016 at 4:05 PM
    #2354
    glorifiedwelder
    jason
    Santa Clarita, ca
    You may actually want to tackle that first gadget has said that sometimes manual transmission trucks can stall out if they don't have the optional filter shield installed. Not sure what kind of clearance the 12-15 grills have behind them, but the 05-11 grill required a bunch of cutting
  15. Jun 12, 2016 at 4:10 PM
    #2355
    VolcomTacoma
    Jeff
    NorCal
    Yeah I have a Grillcraft installed, so Im good on that, and can always clear more if need be, but yeah, might have to fab up another bracket and get a longer sleeve if it wont fit, and i have the filter shield as well
  16. Jun 12, 2016 at 4:11 PM
    #2356
    VolcomTacoma
    Jeff
    NorCal
    Well see, baby woke up and wife is out at dinner, so break time until Wife gets back home while I babysit lol
  17. Jun 12, 2016 at 4:13 PM
    #2357
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    That really does look clean.
    Good job on that install.
  18. Jun 12, 2016 at 4:32 PM
    #2358
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Thanks man. Yes this one came out clean....because I was very careful and took my time. I bought my first pod and just kinda went at it thinking it would just come out looking fine.....I was wrong. So I was forced to buy a new one. I made a write up on the minor modifications needed if you ever buy one. It's easy to do. Just let me know and I'll send it over.
  19. Jun 12, 2016 at 4:41 PM
    #2359
    big_jarv
    2020 TRD Pro
    I wish, I don't have the kind of money for a supercharger.
  20. Jun 12, 2016 at 7:24 PM
    #2360
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i know my volant intake doesnt like the s/c either but it works and i love it
