TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jun 21, 2015 at 4:15 PM
    #241
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. Also, URD has a stockpile of them.
  2. Jun 21, 2015 at 5:09 PM
    #242
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    There is a rebuild kit on eBay that I'm probably gonna pick up. The company's description states it fits blowers for second gens. From 05 to 12??? I messaged him and asked why wouldn't this work on my 14...same motor, blower part number and so on.
    They said the kit is not confirmed for the newer series superchargers howerver, it is probable that they share the correct parts.
    According to them the series one s/c's are "grey top trd " and the second are black.
  3. Jun 21, 2015 at 5:13 PM
    #243
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    The grey s/c's are for the 1st gen tacomas.
  4. Jun 21, 2015 at 7:26 PM
    #244
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Are the first gen superchargers the eaton M62's???
  5. Jun 21, 2015 at 9:41 PM
    #245
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Yeah they are. Most rebuild kits are for the 1st gen sc's.
  6. Jun 21, 2015 at 10:10 PM
    #246
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    There is no way a Toyota technician could see a difference between and apr 2.85 pulley and the stock one... No freaking way
  7. Jun 21, 2015 at 10:14 PM
    #247
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I would recommend the URD 2.85 stealth pulley. It's got all the stamps of the stock 3.0 pulley and looks exactly like it you take a micrometer to it
    Teesredtoy likes this.
  8. Jun 21, 2015 at 10:20 PM
    #248
    Dingus
    Dingus Well-Known Member
    West slope of the Sierra
    2015 4x4 DCLB TRD Sport
    Exhaust/Supercharger/OME lift
    With all being said. What parts would the stealer remove from a stock v6 if they installed the SC? I'm only asking because I had the stealer install my SC.
    I might get all attorney on their ass. If I knew an attorney that is.
  9. Jun 21, 2015 at 10:22 PM
    #249
    VolcomTacoma
    Jeff
    NorCal
    I would make sure to let them know you want every stock piece they pull off. That's part of your truck, they can't just take it because you replaced it
  10. Jun 21, 2015 at 10:24 PM
    #250
    VolcomTacoma
    Jeff
    NorCal
    AND THE ENGINE COVER
  11. Jun 21, 2015 at 10:32 PM
    #251
    VolcomTacoma
    Jeff
    NorCal
    I'll make it fit.
    12TRDTacoma likes this.
  12. Jun 30, 2015 at 10:22 PM
    #252
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So as far as the TRD intake is concerned, since it causes "lean" conditions, it's almost exactly what supercharged trucks need to help remove the richness of the factory supercharged tune right?
    I wonder if anyone has tried the Volant intake and how that has worked out for them.
  13. Jun 30, 2015 at 10:26 PM
    #253
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Right but it almost sounds as if the factory intake is not flowing as much air as the TRD one. Based upon the fact that the stock tune dumps fuel for fun, ideally the TRD CAI would be an ideal mod then if my understanding about it is correct, right?
  14. Jun 30, 2015 at 10:30 PM
    #254
    12TRDTacoma
    Rob
    Concordia
    Boosted
    How come? Its allowing more air over stock right? Thats exactly whats needed to help balance the lean/rich situation. At least you would think.
  15. Jun 30, 2015 at 10:33 PM
    #255
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    I would say PASS on the TRD Super Charger..just because they decided to stop making it/parts for it, so if anything was to happen your SoL. Would've been nice to own one though.
  16. Jun 30, 2015 at 10:35 PM
    #256
    SDB666
    SDB666 Well-Known Member
    Apex, NC
    I'd say pass unless you're getting it at pre-panic pricing. Otherwise, the aftermarket will fill the void shortly.
  17. Jun 30, 2015 at 10:45 PM
    #257
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So what you're saying is that by removing the breather as an obstruction from that area of the intake and relocating it further down that would eliminate the "blinding" of the MAF? I never even thought of or noticed that about its location in relativity to the MAF itself before.
  18. Jun 30, 2015 at 10:46 PM
    #258
    SDB666
    Apex, NC
    :confused: I didn't mention warranty at all.
  19. Jun 30, 2015 at 10:49 PM
    #259
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just suck it up and get the Uconn. Worth it. Then you can bolt on anything and it'll tune it for you.
    My dad has:
    Trd blower
    2.8 stealth pulley
    DT long tube headers
    URD crossover pipe
    Custom dual exhaust
    URD TCAI
    URD 7th injector kit
    URD Uconn kit
    Hauls ass for a armored up truck on 34s
  20. Jul 1, 2015 at 4:51 AM
    #260
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Ucon not available for 09+ Tacomas.
