TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 18, 2016 at 10:49 PM
    #2601
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know....I've done it...
  2. Jul 18, 2016 at 10:57 PM
    #2602
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well shit. Lol.
    IMO the only way to go over the stock box. Then again, I have no basis for comparison other than stock so...
  3. Jul 19, 2016 at 4:58 AM
    #2603
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It just isn't "direct bolt-on." Minor modification needed. Simple as that. :thumbsup:
  4. Jul 19, 2016 at 6:46 AM
    #2604
    ThomasMore66
    Dallas/Fort Worth & Durango
    So does it count as water injection when it's like 1000% humidity in the morning?
  5. Jul 19, 2016 at 11:20 AM
    #2605
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yes. You should just soak your filter in meth to make the mixture complete
  6. Jul 19, 2016 at 11:58 AM
    #2606
    ThomasMore66
    There's an idea.
  7. Jul 24, 2016 at 8:22 AM
    #2607
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    A guy I met has a 98 Tacoma w/ the 3.4 V6 and he is an old man that bought the truck with the s/c on it. He had it taken off since he just bought the truck for a hunting rig. He is a heavy equipment mechanic and said it's not that difficult to take off or install. So I asked him what color it was. He said bronze. I thought there were only black s/c and silver s/c? Can anyone elaborate on a bronze Tacoma s/c? By the way he said the s/c that came off of his 98 Tacoma will fit in my 04 Tacoma. We both have the 3.4.
  8. Jul 24, 2016 at 8:48 AM
    #2608
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    He's probably talking about the 1st gen charger
  9. Jul 24, 2016 at 11:46 AM
    #2609
    Sicyota04
    Morgan
    California
    04 DC 4x4
    So as long it's the silver one w/ the red TRD letters which is the 1st gen S/C. And we both have the 3.4. Will it fit on my truck? Even though his truck is a 98? Only part that sucks is my truck is a DCSB 4x4 automatic. It kinda defeats the purpose to have a S/C with an automatic. He has all the parts and an extra belt for the supercharger.
  10. Jul 24, 2016 at 11:55 AM
    #2610
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    It's actually grey but yeah that's the one he's most likely talking about. They don't come standard with red letters but people tend to put the provided decals over the raised logo. Yes it'll work on yours, as long as he has the provided brackets like the one for the TB as the old drive by wire style is different.
    I wouldn't say a s/c'd auto has no definition because no matter what you'll be seeing a HP increase that you could never naturally provide to your truck. If anything you can combine power ECT with it to shift at higher points. Win win.
  11. Jul 24, 2016 at 11:58 AM
    #2611
    anthony250f
    Anthony
    San Diego, CA
    Will work just fine.
  12. Jul 24, 2016 at 12:55 PM
    #2612
    Sicyota04
    Morgan
    California
    04 DC 4x4
    After the SC is installed do you have to have it tuned? My buddy had one on his 01 Tacoma but I never paid attention to it back in 01, other than it threw the back of my head against the head rest. Now he has a 2012 w/ a SC and same thing. Plus he has the short throw shifter. Is it smog legal? Since I live in CA. And do you have to have any certain company install it? Or will it still be pass smog if my buddy & I install it? I currently have 244,000 miles on my Tacoma and when my buddy had his 01 Tacoma, his engine didn't last very long due to him putting it in 4Hi off the line at stop lights just to blow people with sports cars doors off. I'm sure that wasn't the only reason. He drove that thing like he stole it every time he was behind the wheel. So I guess what I'm asking is, will the SC wear my engine out sooner? Only other question I have is will I need larger injectors? I read that the 3.4 in 2002 - 2004 have bigger injectors or a different spray pattern to where it's not so much a worry as the pre 2001 Tacoma injectors. I've also heard of the URD 7th injector upgrade. Thanks in advance everyone
  13. Jul 24, 2016 at 1:07 PM
    #2613
    anthony250f
    Anthony
    San Diego, CA
    I installed it myself and passed smog fine in ca. You can tune it yourself. I did it and it's pretty easy just time consuming.
  14. Jul 24, 2016 at 1:09 PM
    #2614
    TashcomerTexas
    You don't necessarily need to tune it, as these are bolt on design. Your best bet down the road will be the 7th kit that can be tuned accordingly. It is smog legal but I believe you need the sticker and something to do with the EGR, I will never live in Cali so I'm not 100% on this facet.
    You could install it yourself or with a friend, there's instructions that the PO should have or you could find it online. Worse case scenario just ask someone here, like myself. Be generous when driving if anything your tranny will be the first to go with that power. I don't think I've heard of any boosted tacomas having a shorter life span due to F/I. Just keep it maintained and realize that the oil should be changed and bearings about every 100,000 miles. Don't worry about the injector size.
  15. Jul 24, 2016 at 1:10 PM
    #2615
    anthony250f
    Anthony
    San Diego, CA
    No tacoma has the egr. I had the urd 7th and urd pulley and passed easy. You do need the sticker though OR call around different shops
  16. Jul 24, 2016 at 1:16 PM
    #2616
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Alright thanks
  17. Jul 25, 2016 at 10:48 AM
    #2617
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Jul 25, 2016 at 11:35 AM
    #2618
    eon_blue
    Azusa, CA
    Are you sure it's a TRD supercharger? TRD never (to my knowledge) made a bronze colored blower. Either it was custom painted or it's a different brand.
  19. Jul 25, 2016 at 11:39 AM
    #2619
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
  20. Jul 25, 2016 at 11:56 AM
    #2620
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I just asked him what color it was so I could get an idea of which SC he was talking about. I haven't seen it yet. He's a deisel mechanic and bought a 98 Tacoma for a hunting rig since he has a brand new Dodge Cummins. He said he took it straight off of his Tacoma and it's just sitting at his house. We both have the same motor so I wasn't worried till he said " bronze " SC. I'll have to get him to send some pictures. He lives 5 miles from me and shipping was always the deal breaker before. To be continued...
