TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 1, 2016 at 9:24 PM
    #2681
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Checked the oil too?
  2. Aug 1, 2016 at 9:29 PM
    #2682
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Drained the oil before I even attempted to purge water via pulling the plugs. Got and I'm not exaggerating, close to 4 gallons of water outta the oil drain plug BEFORE I even started to see oil come out. Turned engine over, oil/water shot out of plug holes, then refilled with oil. After electronics dry, I will try to get it running for an hour, then change oil again till I get non milky results
  3. Aug 1, 2016 at 9:40 PM
    #2683
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    4 gallons is astounding! Smart man. :thumbsup: Keep us updated and I truly hope all goes well.
    To reduce the chance of bearing wear during first start up, I will suggest this if you haven't yet thought of it.
    Keep the spark plugs out, remove the fuel pump relay, remove the oil filter, and crank by hand until oil starts to come out of the oil filter plate. Install filter, and crank by hand a little while longer. That should get it into the heads and back to the crank.
    With fuel pump relay and spark plugs still removed, then crank with key. After a few seconds of cranking, your engine should be primed.
    However, I have a strong hunch that those notes are redundant and you know what you are doing. :thumbsup:
    mightytacoman likes this.
  4. Aug 1, 2016 at 9:48 PM
    #2684
    mightytacoman
    Kel
    4.5L 1grfe
    I cranked it by hand after the oil change to help lube up the internals already. I'll crank it by hand again tomorrow till I get to the oil filler plate though. Today I just turned it about 30 full turns of the crank shaft. Didn't really have an idea how much to turn it but that was the number I picked. Do you mean to pull the fuel pump relay itself or the efi relay?
  5. Aug 1, 2016 at 9:57 PM
    #2685
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The fuel pump relay itself. If it is like my 06, then it will be a brown relay. This will prevent load from the combustion process off of the rotating assembly until lubricated.
    One method to determine when it is primed, is when after extended cranking, the Oil pressure light goes off.
    Then add plugs and relay, and start it up.
  6. Aug 2, 2016 at 9:09 AM
    #2686
    mightytacoman
    Kel
    4.5L 1grfe
    On my 09, the fuel pump relay is a tall brown relay too so ya, its the same as your 06. I'm cranking it over with the supercharger right off the truck that way the plugs on the drivers side are accessible.
  7. Aug 2, 2016 at 9:22 AM
    #2687
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That'll work.
  8. Aug 4, 2016 at 1:16 PM
    #2688
    mightytacoman
    Kel
    4.5L 1grfe
    It's running and sounds good. Had 6 codes I cleared and they haven't returned. Just the airbag light now and a blinker that won't shut off
    Torspd likes this.
  9. Aug 4, 2016 at 4:50 PM
    #2689
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    With the 2.8 pulley, afe intake, urd headers, my afr is lower then 11 everytime at WOT. If this is the case would it be bad to move to the 2.7?
  10. Aug 4, 2016 at 5:50 PM
    #2690
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    No? A smaller pulley is gonna get more air in there and probably pop you up in to the 11s
  11. Aug 4, 2016 at 7:42 PM
    #2691
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yeah Im aware but maybe there is something that someone knows that I dont.
  12. Aug 4, 2016 at 8:34 PM
    #2692
    VolcomTacoma
    Jeff
    NorCal
    Uhhh. You'll get more horsepower. TBH once you move past the 2.85 pulley and start popping the horsepower up more its highly recommended you get some sort of tuning software involved. Otherwise you can run the risk of blowing an engine up or doing some sort of damage because you're trying to up the horsepower without adjusting the Air/fuel/timing/whatevs and that can lead to boom.
  13. Aug 5, 2016 at 5:26 AM
    #2693
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    Hey jeff
    Did you find what was leaking at ur gas tank?
  14. Aug 5, 2016 at 6:17 AM
    #2694
    VolcomTacoma
    Jeff
    NorCal
    No, Im killing my gas tank this week so I can drop it next week on vacation and find out what the fuck is up lol
    Torspd likes this.
  15. Aug 5, 2016 at 7:29 AM
    #2695
    richiep
    Rich
    NY
    Maybe i can save you a little work b4 u go crazy droppin the tank. Double check the fill & vent hose's where the clamps are by the rear wheel, maybe ull get lucky.
  16. Aug 5, 2016 at 7:31 AM
    #2696
    richiep
    Rich
    NY
    When u said that it started leaking when the nozzle clicked, it was the first thing i thought of.
  17. Aug 5, 2016 at 7:39 AM
    #2697
    VolcomTacoma
    Jeff
    NorCal
    As I said, all visible connections are leak free. I checked everything I could reach, its something up on top of the tank
  18. Aug 5, 2016 at 8:16 AM
    #2698
    richiep
    Rich
    NY
    Have you lifted the bed to work on the tank?
    I think its easier than droppin the tank. I wish i could have when i did my fuel pump but i had 3 full size bed boxes attached. Big pain in the ass. I did it twice cause the float arm came of the switch after 2 weeks.
    I feel ur pain.
  19. Aug 5, 2016 at 8:25 AM
    #2699
    VolcomTacoma
    Jeff
    NorCal
    Yeaaaahhh Long travel bed cage and relocated battery box in bed and RTT mounted on Bed means dropping the tank is like 1000x easier.
    Torspd likes this.
  20. Aug 5, 2016 at 8:30 AM
    #2700
    richiep
    Rich
    NY
    Yup
    Like i said, big pain n the ass, those connections on top of the tank are just awkward.
