TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 7, 2016 at 2:56 PM
    #2701
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well done. :thumbsup: Back from the brink of mechanical death.
  2. Aug 7, 2016 at 6:19 PM
    #2702
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Ive been running without that gasket for years. Think it runs better without
  3. Aug 7, 2016 at 6:26 PM
    #2703
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely won't be lunch for the valves, if it isn't there.
  4. Aug 7, 2016 at 8:41 PM
    #2704
    TRON
    Hahaha... I removed it all together after noticing about a 1/4 of it got sucked in. Once I get the haltech 2500 working. E85 and 7th injector will keep the air cool regardless.
  5. Aug 7, 2016 at 8:45 PM
    #2705
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You better not beat me to the 2500. :p
  6. Aug 8, 2016 at 12:01 PM
    #2706
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    pretty close. Better then I Thought it would be. She still has a rough idle. New O2 sensor and MAF sensor coming in tomorrow in hopes of correcting that. Truck doesn't want take in fuel either. Possibly clogged charcoal filter? I see on older models that can cause a rough idle too. Thoughts? P0171 code is all right now
  7. Aug 9, 2016 at 4:30 AM
    #2707
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could be that the sensor was soaked to long?
    If only getting that code on the passenger side, it could be a vacuum leak, or specifically the parts you mentioned.
    Was it deep enough that water could have gotten into the canister? I would think it would also cause some evap code, but possibly not. It might be possible to get it off without removing the bed or tank. I just cannot remember right now. I do know that unattaching the large hose from the canister to the fuel tank will be difficult on the tank side though.
    Very tired right now, so you'll have to excuse my lack of clarity. If that canister filled up with water, it is very likely that it could have also then flowed into the tank.
  8. Aug 9, 2016 at 6:41 AM
    #2708
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Question
    I was at my local track the other day an hit the governor on my truck. wondering if anyone has been able to get it removed.
  9. Aug 9, 2016 at 7:21 AM
    #2709
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There are a few methods. A UCON when available, will be the easiest. For those track runs, or high speed off-road rallies.
    However, when I had an X-1, the setting was for 250mph speed limit. Still couldn't surpass the OEM governor. My truck is a 4x4 model. No one else ever mentioned it with their 2wd models.
    StOrMyThEtAcO likes this.
  10. Aug 9, 2016 at 7:52 AM
    #2710
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah that Governor sure is pesky. Pretty sure I've got another 20mph or so left in the engine with the stock RPM max in 6th gear
  11. Aug 9, 2016 at 8:54 AM
    #2711
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As long as you haven't calibrated your speedo to your over sized tires, you'll get over OEM speed limit.
  12. Aug 9, 2016 at 9:55 AM
    #2712
    VolcomTacoma
    Jeff
    NorCal
    I know :anonymous:
    My Ultragauge is calibrated correctly :anonymous:
  13. Aug 9, 2016 at 9:56 AM
    #2713
    VolcomTacoma
    Jeff
    NorCal
    But I also lost a boat load of power :(. Im hoping next month or so I should be able to afford a full regear.
  14. Aug 9, 2016 at 10:14 AM
    #2714
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Aug 9, 2016 at 10:20 AM
    #2715
    VolcomTacoma
    Jeff
    NorCal
  16. Aug 9, 2016 at 8:06 PM
    #2716
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    I want to hook up a catch can, but it looks almost impossible to get to the pcv port with the supercharger in the way. Does anybody know a trick to getting at that to get the clip & hose off & back on without removing the s/c?
    I was thinking of using the existing hose & just extending it, but i would feel so much better if i could replace it.
  17. Aug 9, 2016 at 8:06 PM
    #2717
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I used my hands
    richiep, mightytacoman and Torspd like this.
  18. Aug 10, 2016 at 3:14 AM
    #2718
    ThomasMore66
    Dallas/Fort Worth & Durango
    Get ready to bleed. At least that was my experience. You need one more arm joint.
  19. Aug 10, 2016 at 7:05 AM
    #2719
    GT7
    Grant
    Phoenix
    2013 DCLB
    Definitly takes patience to get the new hose on there tight.
  20. Aug 10, 2016 at 1:45 PM
    #2720
    VolcomTacoma
    Jeff
    NorCal
    So, fuel tank update- after playing with that fuckin vent hose coming from the fuel filler neck I veto'd dropping the entire tank, but was able to pull the straps off and lower it enough to get a solid visual on the top. Nothing is cracked or looking strained, so the only thing I could think was that I didn't get the Fuel Pump Ring tight enough when I swapped out the fuel pump. So my BFH and a giant flat head got me another solid 1"-1 1/2" of turn on the ring, which I wanna say I was about 1/2"-1" away from lining up the original marks when I put it back up. So we'll see how that does now.
    One thing I did notice even afterwords, when I was jacking up the fuel tank to get the straps up- I could see the tank flex a bit and got a little whiff of gas. Now, my face was next to the external filter, so It could have just been that (when I installed everything I hadn't tightened the filter enough and it leaked like a sumbitch until I cranked on everything) because I can't get any more turns on the pipe clamps but I still get a whiff of gas from it every so often.
    But we'll see next fill up. Hoping I just needed to tighten the ring some more and thats that. If I get another overflow I'll suck it up and drop the whole tank and reseat the pump ring and see how the O-ring/gasket looks...or if its even there :facepalm:
