TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 25, 2016 at 3:28 PM
    #2741
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Very interesting though, good luck man.
  2. Aug 25, 2016 at 4:05 PM
    #2742
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds to me like you have a loose connection on the rear side.
  3. Aug 25, 2016 at 4:09 PM
    #2743
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    I'll agree with that, but when I try to take the fuse box off, the issue goes away & i can't re-create the problem. I turn it on & off a bunch of time, shake & jiggle all the wires but it won't do it till some time after a few rides.
    too funny!
  4. Aug 25, 2016 at 4:09 PM
    #2744
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Gremlins!
  5. Aug 27, 2016 at 1:36 PM
    #2745
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So I had a bit of an issue this morning, no idea what happened. Started the truck up, no codes, nothing wrong, putted along (waited maybe 30 seconds before taking off) to the highway...as soon as I got on the highway and shifted in to 3rd, truck went in to almost a limp mode right when I hit 3k RPMS and wouldn't accelerate, and then felt a big clunk and it would accelerate again. Shifted to 4th right after...did the same thing... Couldn't reproduce it again, but it scared the shit out of me lol. No lights on the dash and the ultragauge doesn't show and truck codes, so I'm not sure what happened. Only thing I can think of was it was still too cold and went in to a limp mode when I punched it to get on the highway? No idea.
  6. Aug 27, 2016 at 1:39 PM
    #2746
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    You think it had to do with that secondary air injection pump?
  7. Aug 27, 2016 at 1:47 PM
    #2747
    VolcomTacoma
    Jeff
    NorCal
    Nooooooooooo idea what it was. I sprayed down the engine bay yesterday, like..pretty good. but left it open with the sun on it for a good couple of hours to dry out, and then had to move the truck and it started right up with no codes and was fine
  8. Aug 27, 2016 at 1:52 PM
    #2748
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Well, no codes is obviously a great thing. Hope it don't happen again and chalk it up as a freak thing for now. :fingerscrossed:
  9. Aug 27, 2016 at 1:59 PM
    #2749
    VolcomTacoma
    Jeff
    NorCal
    That's my plan lol! I'm convinced it was just super cold and went in to limp mode for a second or something. No idea lol. I'll find out tomorrow morning when its freezing cold lol
  10. Aug 27, 2016 at 2:30 PM
    #2750
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Weird. Was there a 2nd clunk in 4th too?
  11. Aug 27, 2016 at 2:41 PM
    #2751
    VolcomTacoma
    Jeff
    NorCal
    Yeah, 3rd and 4th were like limp mode and pedal to the medal it just kinda of puttered up to 3k rpms and then just sat there for a few seconds before the clunk and I got power back
  12. Aug 31, 2016 at 8:34 PM
    #2752
    ThomasMore66
    Dallas/Fort Worth & Durango
    Water in the fuel?
  13. Sep 1, 2016 at 7:48 AM
    #2753
    VolcomTacoma
    Jeff
    NorCal
    No clue, haven't been able to replicate it. In retrospect I think the tilt sensor was still buzzing or something. No real idea what was going on, it felt like a hard shift from an automatic suspension but it wasn't during a shift. It was in limp mode up to 3k RPMS, then held at 3K for a few seconds before the hard clunk and then it went over 3k at which point I shifted to GTFO of that gear before the truck could explode, and then it did it in 4th as well.
    Didn't happen the next day and I tried to do exactly what I did the day before.
  14. Sep 1, 2016 at 9:17 AM
    #2754
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Transmission clunk? Were you able to look at the timing?
    Did the foam seal get eaten by the engine?
  15. Sep 1, 2016 at 9:20 AM
    #2755
    VolcomTacoma
    Jeff
    NorCal
    No idea on the timing?
    No idea on the foam seal, but why would that limp mode/stick at 3k rpms and then clunk and be fine in 3rd and 4th gear only?
  16. Sep 1, 2016 at 11:03 AM
    #2756
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Timing could have been viewed with your ultragauge. If timing was retarded a lot, you'd know for a fact that it was actually in a limp mode. Especially if throttle position was far less than throttle input.
    If the cel light didn't blink, or come on, it doesn't sound exactly like limp mode to me. It all depends on where the clunk came from.
  17. Sep 1, 2016 at 11:32 AM
    #2757
    VolcomTacoma
    Jeff
    NorCal
    Yeah not sure exactly what happened, but it hasn't happened again.
  18. Sep 1, 2016 at 1:44 PM
    #2758
    eon_blue
    Azusa, CA
    I wonder if some water managed to get into the intake somehow from when you hosed down the engine? The symptoms you describe happened exactly like that to my previous car, a manual trans Scion tC. I had a CAI on it and whenever it rained heavily, some moisture would occasionally get picked up by the intake and the car would do just what you describe your's doing when I'd shift and accelerate. Sudden loss of power, feeling like it wanted to stall/going into limp mode for a second, etc. When I removed the intake and went back to stock it never happened again, so I assume it was a bit of water getting in.
    VolcomTacoma[QUOTED] likes this.
  19. Sep 1, 2016 at 1:57 PM
    #2759
    VolcomTacoma
    Jeff
    NorCal
    That sounds about right actually! BUT I've got the URD Intake so there's not really anywhere for the water to pool, plus I ran it the day before and nothing happened, I'd think anything sitting in the CAI tubing would be sucked up right off the bat...I dunno man. Hopefully just a fluke and won't happen again
  20. Sep 1, 2016 at 2:00 PM
    #2760
    eon_blue
    Azusa, CA
    Yeah I was thinking either that or some bit of moisture got on your MAF sensor and made it angry, those things are super sensitive. But they usually throw a code when they sense something is off. I dunno, water is stealthy like that....it can work its way into places you didn't think it could. I'm always really nervous when I hose down my engine, I usually put plastic bags over the MAF sensor, battery and alternator. I've heard you're fine not covering them but I get paranoid about stuff like this
