TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 1, 2015 at 6:35 AM
    #261
    ninjaexplosion
    ninjaexplosion Well-Known Member
    steven
    AZ, CA, CO
    2004 Tacoma Double cab
    stock height on 35s, 488s
    U can make your own harness
  2. Jul 1, 2015 at 9:36 AM
    #262
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Doesn't seem like it'd be all that hard though?
  3. Jul 1, 2015 at 10:09 AM
    #263
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol well now we are back to square one. You said the problem is not the intakes. It is the MAF location in comparison to the breather tube didn't you?
  4. Jul 1, 2015 at 10:15 AM
    #264
    12TRDTacoma
    Rob
    Concordia
    Boosted
    AFE eh? I'll have to take a look at it. CARB legal?
  5. Jul 1, 2015 at 11:31 AM
    #265
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah. They are easy enough to change. I may just have to do that.
  6. Jul 1, 2015 at 11:58 AM
    #266
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    My supercharger just arrived from New York. Dropping it off on Tuesday......cant wait!!
  7. Jul 1, 2015 at 12:34 PM
    #267
    12TRDTacoma
    Rob
    Concordia
    Boosted
  8. Jul 1, 2015 at 2:21 PM
    #268
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I have read that the TRD catback &CAI is made by AFE.
  9. Jul 1, 2015 at 2:33 PM
    #269
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I bought the new AFE Stage 2 SI pro dry
    12TRDTacoma likes this.
  10. Jul 1, 2015 at 2:33 PM
    #270
    VolcomTacoma
    Jeff
    NorCal
    And a Coupe clear cover for it
  11. Jul 1, 2015 at 2:56 PM
    #271
    12TRDTacoma
    Rob
    Concordia
    Boosted
    VERY interesting! So it would appear the AFE has more space for incoming air to store it than the stock unit and the TRD unit as well.
    Hm... any power added by that thing on our blowers?
  12. Jul 1, 2015 at 3:31 PM
    #272
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm running a 2013 with the stock intake. I have an Ultragauge and I have been focusing on the lambda readings. The thing is way rich except when you're coasting to a stop. I mean when you have your foot to the floor, it's rich. Anybody running the AFE on a 2012+ with the SC? Do you ever go lean?
  13. Jul 1, 2015 at 3:34 PM
    #273
    VolcomTacoma
    Jeff
    NorCal
    I'll let you know :). Ordering headers y pipe and exhaust in about two weeks as well. Should be picking up my 2015 right about then as well. I'm so ready to do this finally!
  14. Jul 1, 2015 at 3:35 PM
    #274
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It stops being rich on coasting because the computer on these vehicles uses a feature called Deceleration Fuel Cut Off (DFCO) it's a fuel saving feature that doesn't do a whole lot. It does help a little bit. Keyword, a little bit.
  15. Jul 1, 2015 at 3:36 PM
    #275
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's it...it's official. 08 is the best year for 2nd gens
  16. Jul 1, 2015 at 3:45 PM
    #276
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    I've known this for a long time :stirthepot:
  17. Jul 1, 2015 at 4:05 PM
    #277
    Blackdawg
    Monte
    Wyoming/St. Louis
    Torspd and ninjaexplosion like this.
  18. Jul 1, 2015 at 4:16 PM
    #278
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well as you can see...the scoop wins.
  19. Jul 1, 2015 at 7:52 PM
    #279
    josefmd
    josefmd Well-Known Member
    Springboro OH
    2017 4R TRD Pro Cement. 2024 Ford Ranger Raptor
  20. Jul 2, 2015 at 10:05 AM
    #280
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a fix for the new TRD intake. Video is on YouTube. Also, there are other intakes available which will work as well. I do not recommend it either, without doing the "fix".
    www.zzperformance.com has a lot of parts for the M90. Like Rock Lobster said, that s/c is on a lot of vehicles. Just a different housing. Plenty of parts out there.
    12TRDTacoma[QUOTED] likes this.
