TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 8, 2016 at 12:16 PM
    #2821
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So which other performance mods do you have? Did you add any during the rebuild? Why did you go to the lower boost pulley?
    Have you sprayed around the engine bay for vacuum leaks?
  2. Sep 8, 2016 at 1:43 PM
    #2822
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have the urd 7th injector. Nothing else has changed.i changed because I absolutely couldn't get my afr correct and thought the belt was slipping.
  3. Sep 8, 2016 at 1:44 PM
    #2823
    anthony250f
    Anthony
    San Diego, CA
    Not yet since the rebuild so I need to do that
  4. Sep 13, 2016 at 4:17 AM
    #2824
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Okay, i guess this is the place since im in the market for boost now, has anyone on here actually run the new Magnuson Supercharger kit with the Toyota Reflash? i absolutley despise the idea of one of those bullydog ripoff flash units, and would rather have the toyota reflash or a ucon or something proven to work. also not opposed to URD's kit, as long as the UCON will pass OBD2 Emissions, since that's what my truck is subject too.
  5. Sep 13, 2016 at 5:14 AM
    #2825
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think the Magnuson is exactly the same as the TRD. It was always a Magnuson with a giant TRD on it. We've all used the same reflash. It works fine. It's rich. I'm subject to emissions check too. No issues.
  6. Sep 13, 2016 at 11:52 AM
    #2826
    Gaunt596
    Matthew
    Central Maryland
    Cool, so magnuson kit with the URD pulley to lean it out a touch and I'll be good to go
  7. Sep 13, 2016 at 12:05 PM
    #2827
    anthony250f
    Anthony
    San Diego, CA
    Will Toyota even still flash it ?
  8. Sep 13, 2016 at 3:52 PM
    #2828
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    exactly what I have on mine and love it.
    Toyota dealer I found did my reflash HOWEVER the Magnusson kit comes with a bully dog programmer to reflash it yourself. you might have trouble getting it to reflash if you have a 09 or 12 from what my research shows though. In which case Toyota wont be able to reflash either and a new ecm is required.
    on a postitive note, I tackled Dusy Ershim trail this past week and got double the gas mileage than the non charged rigs. I was able to go over most of the trail at almost an idle. I thought the charger would lower offroad crawling mileage and was happy to see the opposite effect.
    Torspd likes this.
  9. Sep 13, 2016 at 4:30 PM
    #2829
    Gaunt596
    Matthew
    Central Maryland
    Sweet. So I just have to find a dealer that can flash it and I'm good to go. And finding that money tree with my 6 grand on it.
  10. Sep 13, 2016 at 4:34 PM
    #2830
    mightytacoman
    Kel
    4.5L 1grfe
    Assuming the programmer that comes with the Magnusson didn't work for you then yes, you would have to find a dealer that will
  11. Sep 13, 2016 at 6:54 PM
    #2831
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Can't you order the Magnusson kit without the tuner? Thought they had a 'call us for price quote' on the tuner edition or something
    rmepilot likes this.
  12. Sep 13, 2016 at 7:01 PM
    #2832
    mightytacoman
    Kel
    4.5L 1grfe
    I think so. I haven't asked. The tuner is 350$ so if you wanted to go that route, it would probably save your about that much
  13. Sep 13, 2016 at 7:12 PM
    #2833
    Gaunt596
    Matthew
    Central Maryland
    I'm just looking at the emissions standpoint, the Toyota reflash is garunteed vs an aftermarket tuner that gets crap reviews on here for not doing anything.
    I hope so, would be nice to knock off a few bucks for something I don't plan on using.
  14. Sep 14, 2016 at 9:58 PM
    #2834
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    No the Toyota flash is not guaranteed. In order to get the emissions cert it would need to be a TRD SC kit that came with all the emissions compliant paper work.
    If you live in nazi land and don't have the CARB cert your fucked. I believe magnuson is still working on the carb cert. But maybe they got it already
    Torspd likes this.
  15. Sep 14, 2016 at 10:02 PM
    #2835
    Gaunt596
    Matthew
    Central Maryland
    nope, not in commiefornia. where im at, all the emissions crap in the ECU just has to report its "okay" to the states scanner. the toyota reflash leaves all that stuff in place, whereas a lot of aftermarket tuners just turn them "off" meaning you fail emissions via OBD2 Scanner.
  16. Sep 14, 2016 at 11:34 PM
    #2836
    Gaunt596
    Matthew
    Central Maryland
    Also, i just looked it up, URD has the magnusson kit minus the "tuner" at 5,595,
  17. Sep 15, 2016 at 8:33 AM
    #2837
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The UCON should be available to non URD S/C specific customers with in a few months. Once their chargers are all shipped out, and the next batch of UCONs are made. Which will work with the Magnusson kit, and pass emissions. Their is an internal O2 sim for cat-less operation.
    Gaunt596 likes this.
  18. Sep 15, 2016 at 9:02 AM
    #2838
    VolcomTacoma
    Jeff
    NorCal
    Brice, Gaunt596, Torspd and 1 other person like this.
  19. Sep 16, 2016 at 2:47 PM
    #2839
    ThomasMore66
    I got my new toy. Jonesing for the LS upgrade.
  20. Sep 16, 2016 at 2:54 PM
    #2840
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    bypass valve makes the blower use approx 1/2hp when not creating boost i believe.
