TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 16, 2016 at 3:43 PM
    #2861
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah it should be super easy but shit always happens with me lol
    I only get 200 miles on a tank
    eon_blue likes this.
  2. Sep 16, 2016 at 3:45 PM
    #2862
    eon_blue
    Azusa, CA
    ouch, I get 270 on average....300 if I run it nearly dry on a mostly highway tank. Still running stock size tires though.
  3. Sep 16, 2016 at 3:45 PM
    #2863
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Can you offer a simple explanation as to why I burned so much less fuel than the other trucks I ran with?
  4. Sep 16, 2016 at 3:46 PM
    #2864
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    you know what cools the fuel pump right?
  5. Sep 16, 2016 at 3:47 PM
    #2865
    anthony250f
    Anthony
    San Diego, CA
    I can only ever fit like 15-16 gallons in. Comes out to 14.7 mpg
  6. Sep 16, 2016 at 3:47 PM
    #2866
    anthony250f
    Anthony
    San Diego, CA
    Oxygen.....lol
  7. Sep 16, 2016 at 3:48 PM
    #2867
    inwood customs
    Dave
    only if you give specifics of what these other trucks and mods were........... then that MAY be possible.
    all I cas say for now is lower load = almost zero parasitic loss, and thats a fact taken from eatons specs.
  8. Sep 16, 2016 at 3:48 PM
    #2868
    inwood customs
    Dave
    that will be your lil secret
  9. Sep 16, 2016 at 3:49 PM
    #2869
    eon_blue
    Azusa, CA
    I don't literally 'run it dry'....running dry to me is driving a few miles after the light comes on. I avoid doing that at all costs, usually fill up with 1/4 left.
  10. Sep 16, 2016 at 3:49 PM
    #2870
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yes that was dig at your shipping fiasco lol. 200 miles? Do you have a 7th injector?
  11. Sep 16, 2016 at 3:49 PM
    #2871
    inwood customs
    Dave
    good call...... I dont run below 1/4 either.
    eon_blue[QUOTED] likes this.
  12. Sep 16, 2016 at 3:50 PM
    #2872
    anthony250f
    Anthony
    San Diego, CA
    Yeah and it's fueling pretty heavy too. Had to way up the numbers
  13. Sep 16, 2016 at 3:51 PM
    #2873
    eon_blue
    Azusa, CA
    Is the 7th injector necessary for an '04 Tacoma? I read that the '04 has better (larger) Denso fuel injectors than the previous model years had. Curious if the 7th injector is something I need to invest in or not.
  14. Sep 16, 2016 at 3:52 PM
    #2874
    anthony250f
    Anthony
    San Diego, CA
    Yes
    I have 04 injectors and I wouldn't even run the truck without the 7th
  15. Sep 16, 2016 at 3:54 PM
    #2875
    eon_blue
    Azusa, CA
    Gotcha. One more thing to add to the $$$$$$ mod list :help:
  16. Sep 16, 2016 at 3:55 PM
    #2876
    anthony250f
    Anthony
    San Diego, CA
    How bad does it ping? Do you have a afr gauge??
  17. Sep 16, 2016 at 3:56 PM
    #2877
    TashcomerTexas
    I was gonna say maybe you need to retune it. I know I have to cause I'm using up a good amount of fuel as well - it was tuned when I had p0171 so the idle was low and rough so it needs to be adjusted again. I need to check my ultragauge to check my fuel specs.
  18. Sep 16, 2016 at 3:57 PM
    #2878
    eon_blue
    Azusa, CA
    No AFR gauge. I used to get pretty bad pinging but that almost entirely went away when I upgraded to colder iridium spark plugs (previous owner had the stock copper ones in). I occasionally get pinging under high gear/low RPM (freeway for instance), but only sometimes.
  19. Sep 16, 2016 at 3:58 PM
    #2879
    inwood customs
    Dave
    Gadget relates to the high gear low rpm ping and has warned ppl about it for yrs.
    This also could cause rotor slap.
    do not accelerate in an overly high gear.
  20. Sep 16, 2016 at 4:02 PM
    #2880
    anthony250f
    Anthony
    San Diego, CA
    Here's my map b
    You have to use a wideband. Ultragauge only reads narrow
    inwood customs likes this.
