TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 2, 2015 at 10:39 AM
    #281
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is one issue. The '08's had clutches which the hubs could easily separate from the disks. It was when Toyota changed clutch vendors from LUK to Aisin. Aisin being the same manufacturer as the transmission. They then changed back to LUK after a a short period and many many warranty claims.
  2. Jul 2, 2015 at 10:42 AM
    #282
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD has a tuning solution for that intake as well, but that is limited to year model versus tuning solution.
    The fix in the video is of a Toyota Tech showing the part and how to, I believe. Not 100% certain if it was a Toyota Tech, as it was quite a few years ago. The video came out shortly after that intake came to market.
  3. Jul 2, 2015 at 10:54 AM
    #283
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  4. Jul 2, 2015 at 12:06 PM
    #284
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    I went to the Toyo dealer last night looking for Supercharger oil, and they said Toyota wont be selling superchargers anymore! Has anyone else heard about this? Apparently there was a bulletin that was sent out about 3 weeks ago stating that?!
  5. Jul 2, 2015 at 12:36 PM
    #285
    josefmd
    josefmd Well-Known Member
    Springboro OH
    2017 4R TRD Pro Cement. 2024 Ford Ranger Raptor
  6. Jul 2, 2015 at 12:39 PM
    #286
    05SuperChrg
    SF Bay Area
    Thanks for posting that!! The only thing that I can see as possibly becoming an issue is the ECM calibration won't be part of any ECM update.
  7. Jul 2, 2015 at 1:45 PM
    #287
    ThomasMore66
    Dallas/Fort Worth & Durango
    But! Has anyone run the AFE on a 2012 or later with the SC?
  8. Jul 2, 2015 at 2:33 PM
    #288
    ThomasMore66
    My Ultragauge says its way rich. I'm ready to give it a bit more air. What does the AFR do if you go to the mountains? Will the stock computer adjust fine? It sure does normally aspirated.
  9. Jul 2, 2015 at 4:47 PM
    #289
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look at my previous post.
  10. Jul 3, 2015 at 12:30 PM
    #290
    ThomasMore66
    I still don't understand why Toyota has their panties in a wad over the CAI on later model trucks.
    Gridguy likes this.
  11. Jul 4, 2015 at 12:24 PM
    #291
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Told a work bud I bought the supercharger and am waiting on fit kit backorders to be filled (hopefully). He asked me why I did a stupid thing like that instead of putting the same $4500 into my STI instead. He's got a point..... I could get injectors, 314SS headers, and a turbo and get 100WHP more for close to the same $.
    My counter is that I plan to keep the truck until the wheels fall off, and it's my other toy anyway.
  12. Jul 4, 2015 at 2:11 PM
    #292
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    But where's the fun in that? Might as well never touch alcohol and stay a virgin while you're at it.
    12TRDTacoma likes this.
  13. Jul 4, 2015 at 2:29 PM
    #293
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You only live once!
  14. Jul 4, 2015 at 2:44 PM
    #294
    VolcomTacoma
    Jeff
    NorCal
    No. You do not Yolo. Ever.
  15. Jul 4, 2015 at 3:18 PM
    #295
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I've had no issues arise from mine. Is there a better option for my setup or other setups? I don't know, never needed to find out.
    I will look in to this Youtube video "fix" though.
  16. Jul 5, 2015 at 12:06 PM
    #296
    ThomasMore66
    Anybody know of a good speed shop in DFW that has Tacoma experience? I'd really like to have professional input befor I venture off the Toyota package too far. I just feel there is more that can be done with the M90.
  17. Jul 7, 2015 at 7:47 PM
    #297
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I dropped mine off at the dealer today boys!!!! Can't wait to get it back with a little more horsepower.:D
  18. Jul 12, 2015 at 1:44 PM
    #298
    Dingus
    Dingus Well-Known Member
    West slope of the Sierra
    2015 4x4 DCLB TRD Sport
    Exhaust/Supercharger/OME lift
    I thought it was "never go full retard."
  19. Jul 12, 2015 at 1:54 PM
    #299
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well is right. Don't leave us hornswaggled over here Juanito!
  20. Jul 12, 2015 at 6:20 PM
    #300
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol not yet fellas, ......I dropped it off last Tuesday. They said it would definitely take them a couple days. I replied with I've already been quoted exactly what I am paying so keep it as long as you need..... I didn't think they would take me so literal!!!!! But honestly so long as it is done right and not rushed I'm fine with them having it a few extra days. I will be calling tomorrow for an update though.
