TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 27, 2016 at 6:17 PM
    #2981
    Springs719
    Springs719 Well-Known Member
    Brett
    08trdoffroad
    What would you go with I know a lot of them are a joke from what I have heard. Don't hear a knock as of know.
  2. Sep 27, 2016 at 9:50 PM
    #2982
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I think you'll be fine as long as you stay outta the boost (no wot) this tank. Throw an octane booster in for good measure..it won't hurt
  3. Sep 28, 2016 at 5:39 AM
    #2983
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lucas oil or VP Racing. Primarily VP Racing. It is only a few hundred miles that you have to stay out of boost. It will pass quickly enough.
  4. Sep 28, 2016 at 6:03 AM
    #2984
    Springs719
    Brett
    08trdoffroad
    Cool guys thanks for the quick responses appreciate it
  5. Sep 28, 2016 at 2:38 PM
    #2985
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just ran a guy in another Tacoma. We had to chat when he finally got to the next light.
    "What have you got in that thing?"
  6. Sep 28, 2016 at 2:57 PM
    #2986
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Lol......same thing happened to me last week with a guy in a civic that was not so stock. I believe he kinda under estimated my truck with 33's and that weird whine coming from under the hood.
  7. Sep 28, 2016 at 5:00 PM
    #2987
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A Hemi. ;)
  8. Sep 28, 2016 at 7:07 PM
    #2988
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Just broke some dudes neck that was driving a ricer with a huge body kit on it and his 'stance' looked like 4 broken axles lol. Drove by, saw him and couldn't resist gunning it for a second to get some whine going and watched his eyes get wide and his head whipped around so fast he must have whiplash. Ahhhhh the little things lol
    Biscuits, rmepilot, Torspd and 2 others like this.
  9. Oct 1, 2016 at 10:56 AM
    #2989
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Any opinions on water/meth systems? I live in South Florida and feel heat soak issues on both the truck and my turbo car
  10. Oct 1, 2016 at 1:34 PM
    #2990
    VolcomTacoma
    Jeff
    NorCal
    Uhhhh who installed that water meth kit recently, I forget. I'm on the fence about it while wsiting for plug and play tuners *cough ucon cough @Gadget@URD cough 2015 cough*
  11. Oct 1, 2016 at 2:07 PM
    #2991
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Aren't you selling a tuner?
    My truck is beyond night and day difference between early morning and middle of the day. The heat down here is brutal and kills my power
  12. Oct 1, 2016 at 3:29 PM
    #2992
    eon_blue
    Azusa, CA
    Went to change out the oil in the nosecone last night and couldn't suck any out, it was practically dry :eek: Got a whole 4oz bottle of the ACDelco supercharger oil in. 30k miles on it. Check your oil
    Also, my motor is pinging again like crazy on the freeway. Got it to go away earlier this summer when I swapped in colder plugs (IK20) but it's starting to ping again like it was before, 5k miles later. Any suggestions? I know I need to get the 7th injector kit eventually
    Torspd likes this.
  13. Oct 1, 2016 at 3:30 PM
    #2993
    VolcomTacoma
    Jeff
    NorCal
    Top line, sounds like a personal problem, OR TWSS.
    eon_blue likes this.
  14. Oct 1, 2016 at 4:57 PM
    #2994
    ThomasMore66
    @Brianawd. He went all in. Looks super cool.
  15. Oct 1, 2016 at 10:51 PM
    #2995
    Springs719
    Brett
    08trdoffroad
    What about upgrading your fuel pump. Couple $100 less then the 7th injector kit.
    eon_blue[QUOTED] likes this.
  16. Oct 2, 2016 at 7:19 PM
    #2996
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To follow up with what Springs719 asked, have you upgraded your fuel pump? Especially considering the age of yours.
    When is the last time that you changed the fuel filter?
    Since your S/C doesn't come with an aftercooler, a meth kit would also be extremely beneficial.
    eon_blue[QUOTED] and Springs719 like this.
  17. Oct 2, 2016 at 7:32 PM
    #2997
    eon_blue
    Azusa, CA
    No fuel pump upgrade, but I've been eyeballing that along with the 7th injector URD kit. Just don't have the funds at the moment unfortunately.
    Replaced the fuel filter when I first got the truck, it's got maybe 10k miles on it. It's just weird that the pinging almost entirely went away with the new iridium plugs I got, but roughly 5k miles later it's back with a vengeance. Like the plugs have already gone bad or something.
    Some times it's worse than others but it's definitely most apparent in high gear/low rpm conditions, like giving it throttle in 5th gear on the freeway going 65mph...don't really want to drop it into 4th going that fast but I guess maybe I should if I have to.
  18. Oct 3, 2016 at 5:16 AM
    #2998
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Check your plugs? Maybe something is fouling your plugs
  19. Oct 3, 2016 at 5:23 AM
    #2999
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    I'm new to this forum, but not to supercharger. Maybe I can help.
    Check your bypass valve to make sure it's functioning. There's a rubber diaphragm in there that will go back eventually (I don't know how old your kit is, but it's worth a shot). When the bypass valve goes bad the blower can not move any air around the rotors so you're compressing air (raising the temp) at part throttle and causing knock.
    Hope this helps!
    Source: This happened on my roots SC'd civic once upon a time.
  20. Oct 3, 2016 at 8:19 AM
    #3000
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is the perfect scenario to create detonation. Low rpm, and high load. Definitely change gears to a lower gear.
    Next on your list should be the fuel pump upgrade. Only about $140.
    See how it does with that, then go from there with additional mods.
    You can always try the next step colder plugs, as well.
    Which brand gas do you normaly use, and which octane?
