TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jan 20, 2017 at 8:12 AM
    #3341
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    If one were to get a ucon from underdog, is there any benefit to having the maf sensor calibrator too?
  2. Jan 20, 2017 at 3:00 PM
    #3342
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Pretty sure they'd fight each other a bit? I'm betting URD would recommend the UCON and disable the MaF Cal
    mightytacoman likes this.
  3. Jan 25, 2017 at 4:15 AM
    #3343
    Whodat04
    Whodat04 New Member
    Hey I'm interested if you still got it
  4. Jan 25, 2017 at 5:52 AM
    #3344
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No. It would inhibit the accuracy of the superior unit.
  5. Feb 5, 2017 at 1:29 PM
    #3345
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Anyone ever see these and think using them for the cats......welding them onto some shorty headers??? Do you think they are worth it?? Or junk??
    https://www.ebay.com/itm/331830016295
  6. Feb 8, 2017 at 5:44 PM
    #3346
    ThomasMore66
    Dallas/Fort Worth & Durango
    So I'm getting my Y-Pipe, pulley, fuel pump and gauges installed at Tandem Automotive in Ft Worth. They installed Harrop elockers on my FZJ80. This is the text I got from the mechanic: "First gear is just a glorified tire liquefier." They also reset my tranny because I was having issues with 4-5 hang and hitting the limiter on 1-2, and 2-3.
    5thGearPinned and inwood customs like this.
  7. Feb 8, 2017 at 6:01 PM
    #3347
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mmm. Liquid rubber. :rasta:
    inwood customs likes this.
  8. Feb 8, 2017 at 6:45 PM
    #3348
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Yeah, i chopped my exhaust cause i got tired of smelling burnt rubber everytime the exhaust got up to temp and heated the rubber on it.
  9. Feb 8, 2017 at 7:16 PM
    #3349
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's the annoying kind. Fine line.
  10. Feb 8, 2017 at 7:17 PM
    #3350
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    How do they reset the transmission
  11. Feb 9, 2017 at 4:31 AM
    #3351
    ThomasMore66
    Using a diagnostic tool (same kind that read check engine codes) you can reset the computer learning of the trans. It's coverered earlier in this thread, but I didn't search for it.
  12. Feb 9, 2017 at 8:10 AM
    #3352
    VolcomTacoma
    Jeff
    NorCal
    You can also just take the cables off the battery for like half an hour to do the same thing IIRC
  13. Feb 9, 2017 at 8:51 AM
    #3353
    GT7
    Grant
    Phoenix
    2013 DCLB
    Thats what I thought but wasnt 100% sure
  14. Feb 9, 2017 at 4:46 PM
    #3354
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    ThomasMore66, have you got truck back from Tandem yet? I have been looking for a shop to take mine too for some work and wondered if they were good to go. Glad to see you are finally getting your pully installed, your going to love it! I'm already wanting the 2.7 and the meth kit now, especially when this Texas weather hits in summer time! I really just want the 7th and Ucon but might just do this until we can get the Ucon.
    JuanitoBonito likes this.
  15. Feb 9, 2017 at 5:26 PM
    #3355
    ThomasMore66
    They have been great to work with. They are a small shop and only work on Toyotas. Just be flexible on timing.
  16. Feb 9, 2017 at 6:03 PM
    #3356
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Hey that's sounds awesome. Anybody I should ask for? Thanks.
  17. Feb 9, 2017 at 6:10 PM
    #3357
    ThomasMore66
    Lol. It's small. Pablo is the lead mechanic and Alejandro runs the place.
    http://www.tandemauto.com/ I don't have Facebook, but they're on there and instagram.
    5thGearPinned[QUOTED] likes this.
  18. Feb 9, 2017 at 6:11 PM
    #3358
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Thank you sir!
  19. Feb 9, 2017 at 6:14 PM
    #3359
    ThomasMore66
    So Pablo has a history of building tuner cars and 4x4's. He's always excited to get something different. For me the location is a little awkward since I live north of DFW airport and work in Dallas. I've never Ubered so much.
  20. Feb 9, 2017 at 6:23 PM
    #3360
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Again thank you, The location is easy for me to get to, I just need to get an URD Y pipe now. Where did you get yours coated, that I would like to do. It sounds like they like there Toyota's.
