TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 14, 2015 at 9:23 PM
    #321
    ThomasMore66
    Dallas/Fort Worth & Durango
    Lobster gets surly when he's drinking.
  2. Jul 15, 2015 at 4:58 AM
    #322
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    No custom tune yet. I need to call Gadget still and see if the MAF calibrator will help me or not wth all those mods
  3. Jul 15, 2015 at 10:35 AM
    #323
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    VolcomTacoma,
    I chatted briefly with Gadget about something similar yesterday. Currently, I'm N/A with I/E/H and URD MAF Cal. I ended up getting the TRD blower and called Gadget to order the stealth pulley and fuel pump upgrade. I asked him about the installation of the TRD blower with the existing URD MAF Cal his instructions were to basically "zero" out the MAF Cal, get the TRD blower reflash, and then custom tune the MAF Cal through usual means. He did not have a calibrated MAF Cal map for the TRD blower ecu flash since he's seen A/F ratios all over the place with the reflash. But yes, the URD MAF Cal can be used to tweak and adjust the Toyota ECU reflash (supercharger).
    This was for my '08 DCSB PreRunner
  4. Jul 15, 2015 at 10:38 AM
    #324
    VolcomTacoma
    Jeff
    NorCal
    Awesome! Let's see if 2015 works as well! That's good info right there
  5. Jul 15, 2015 at 8:52 PM
    #325
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i got a 10 taco with the s/c
    im thinking bout getting the urd y-pipe and mate it to my trd cat back
    anyone have a sound clip for it?
    also gonna be getting a afe intake soon
  6. Jul 17, 2015 at 3:45 PM
    #326
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Well gentlemen, I just got mine back......supercharged. way too much traffic to even remotely open it up. However the one time I was able to get on it a little I did indeed noticed a difference.....and it sounds sweet. We stopped for a bite and when we get outta here the traffic where I'm at is gonna be down right horrible!!!! When I get closer to home I should be able to see what it has to really offer me.....I'll keep you all informed.:mudding:
  7. Jul 17, 2015 at 4:37 PM
    #327
    ThomasMore66
    Your first couple of fill ups will suck. Computer has to adjust.
  8. Jul 17, 2015 at 4:50 PM
    #328
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I figured as much....from what I read. Do you figure a couple hundred miles or so and that should do it??
  9. Jul 17, 2015 at 6:36 PM
    #329
    ThomasMore66
    I drove from Dallas to OKC and the mileage was unbelievably bad. Drove home and it seemed ok.
    Now, your right foot will continue to find a reason to mash the go pedal. I've had mine a year and I've never stopped. Now I want more parts to go faster.
    Redsyota likes this.
  10. Jul 17, 2015 at 7:52 PM
    #330
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I guess how I'll see how it turns out. I'm sure at some point I'll be a little tempted to do the smaller pulley/ fuel pump thing. Honestly....I don't want any possible hassle of what may come from modding the blower so I'm positive itl stay stock.
  11. Jul 23, 2015 at 12:05 PM
    #331
    SUMOTNK
    Eddie
  12. Jul 23, 2015 at 2:32 PM
    #332
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Well tomorrow will be a week that I've had the supercharger. I love it. The difference to me is night and day. Its no Ferrari but to me at least it drastically increased acceleration power. I understand everyone has their own opinion as to how different it feels, worth it/not worth it and so on. I'm glad i got mine for sure. Paired with the manual trans and quick shifter, it makes my truck an absolute pleasure to drive.
    6xchamps likes this.
  13. Jul 23, 2015 at 3:52 PM
    #333
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I love mine as well, even with the automatic. Damn glad I bought a 2015 and supercharged it, rather than getting a car engine in the 2016.
  14. Jul 24, 2015 at 3:52 AM
    #334
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    yeah that motor is not impressing too many people....
    Pavlik1988 likes this.
  15. Aug 6, 2015 at 8:22 AM
    #335
    JDinSLT
    JDinSLT Member
    Tahoe
    2015 Black DCLB S/C
    pelfreybilt aluminum bumper with center hoops icon suspension kenwood tm-v71a ham radio baja designs s8 20" amber bar baja designs squadron sport fog amber
    I had the S/C installed on my new 2015 in February and live at altitude. The S/C has made a big difference in driving around, I sort of regret going to the automatic, (had a 2014 Taco Manual prior) so I cannot really reflect on what that would've been like mileage wise, but am very glad I had it installed. I love the sound the S/C makes. I am getting 16-17mpg (which was what I was getting on my Manual before), but I started in the 12-13 range for the first couple of months.
  16. Aug 15, 2015 at 11:56 AM
    #336
    ThomasMore66
    Anybody else think the coolant reservoir is hard to open? Am I missing some trick?
  17. Aug 15, 2015 at 12:03 PM
    #337
    ThomasMore66
    It just turns, right? Service tech must have really muscled it.
  18. Aug 15, 2015 at 12:08 PM
    #338
    VolcomTacoma
    Jeff
    NorCal
    Yes, it turns. I check mine usually every other day just to see if Ive lost any coolant at all
  19. Aug 15, 2015 at 12:09 PM
    #339
    ThomasMore66
    Hmm. Might have to put a strap wrench on it.
    Edit: strap wrench worked. Didn't want to break anything.
  20. Aug 15, 2015 at 12:18 PM
    #340
    VolcomTacoma
    Jeff
    NorCal
    Awesome. Just watch the bracket and bolts its on...i tightened mine to much and while trying to open it later i saw the brscket bending on the body a bit, didnt want to rip some bolts out lol
