TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Feb 22, 2017 at 6:05 PM
    #3501
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Its 100% easier than trying to reach under it.
    StOrMyThEtAcO likes this.
  2. Feb 22, 2017 at 6:13 PM
    #3502
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    and honestly now that i have done it i feel i could remove it in an hour and a half to two hours
  3. Feb 22, 2017 at 6:17 PM
    #3503
    VolcomTacoma
    Jeff
    NorCal
    Like full job, or just pulling the top off? I mean, drill gun with the right sockets and thats a 20 minute job to pull it off lol
  4. Feb 22, 2017 at 6:50 PM
    #3504
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    This is true. What else you doing to it
  5. Feb 23, 2017 at 5:47 AM
    #3505
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Swivel extensions, and a swivel ratchet. -5 minute job. :p
  6. Feb 23, 2017 at 5:50 AM
    #3506
    VolcomTacoma
    Jeff
    NorCal
    I need.
    rmepilot likes this.
  7. Feb 23, 2017 at 6:05 AM
    #3507
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It will make you want to find something to work on. To champion over its defiance.
    VolcomTacoma likes this.
  8. Mar 7, 2017 at 5:45 PM
    #3508
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So I'm looking hard into my headers finally......I've been trying to find info that I thought has been discussed before.
    Between shorties and longtubes, which will rob you of low end power? And which of the two are ultimately the better set for our motors???
  9. Mar 7, 2017 at 7:05 PM
    #3509
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD Spec-U headers.
    HomerTaco and Blacktaco2042 like this.
  10. Mar 7, 2017 at 7:31 PM
    #3510
    VolcomTacoma
    Jeff
    NorCal
    PS This happened. Said F it, I have nothing swivel anything, might as well get some.
    Torspd[QUOTED] likes this.
  11. Mar 7, 2017 at 7:34 PM
    #3511
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    This. Hands down
  12. Mar 7, 2017 at 7:43 PM
    #3512
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    From what I've read performance wise they are awesome but also a pain to install. I've seen at least two guys have a ton of problems with them and gadget not really wanting to help.
    Of the two, long tubes and shorties.....which rob f/a of low end power???
  13. Mar 7, 2017 at 8:11 PM
    #3513
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    It's a pain but I think some people over complicate things too much. Like that guy who took off the transmission brace to install their Y pipe lol
  14. Mar 7, 2017 at 8:21 PM
    #3514
    glorifiedwelder
    jason
    Santa Clarita, ca
    I installed a set for someone and it wasn't bad at all. Once I get my front end sorted out and done I'm gonna swap my afe's out for a set. I've had both short tube and long tube headers with my s/c. Long tubes win hands down. But URD's are far superior to both and I'm not a urd fan at all, but no one makes anything comparable
    JuanitoBonito[QUOTED] likes this.
  15. Mar 7, 2017 at 8:46 PM
    #3515
    Blacktaco2042
    wisconsin
    im gonna get a set of urd long tubes and y pipe to go with my trd cat back. i was told to remove front driveshaft to help with install instead of disconnecting the steering shaft
    hopefully that true
  16. Mar 8, 2017 at 7:47 AM
    #3516
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    That's what I did. Worked for me
  17. Mar 8, 2017 at 11:45 AM
    #3517
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    @JuanitoBunito just get the urd headers. Tbh the power is really great, but the other bs like install is annoying but ultimately worth it. I took my truck to a shop that does 1000 hp + cars and even they had trouble with the install.
  18. Mar 8, 2017 at 3:18 PM
    #3518
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What about did they charge you.....did you have them weld on the cats too??
  19. Mar 8, 2017 at 6:00 PM
    #3519
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Another question I haven't heard anyone mention......Has anyone gone with the red URD suregrip pulley, 2.825 instead of the 2.85???
  20. Mar 8, 2017 at 6:01 PM
    #3520
    mightytacoman
    Kel
    4.5L 1grfe
    Me... I don't need a stealth pulley for inspection so I went with the cheaper option
