TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 15, 2015 at 1:05 PM
    #341
    ThomasMore66
    Dallas/Fort Worth & Durango
    Exactly. It would be cool to have an aluminum reservoir to match my oil catch can.
  2. Aug 17, 2015 at 8:58 AM
    #342
    ThomasMore66
    Why?
  3. Aug 17, 2015 at 10:36 AM
    #343
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    haha yea buddy.
  4. Aug 23, 2015 at 9:38 PM
    #344
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Coupe made some. Extremely nice pieces. Low volume meant high price though. I posted a link about it a while ago.
    That small nipple on the plastic one tends to leak after a while.
  5. Aug 23, 2015 at 9:46 PM
    #345
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Just seen a local guys work on some custom alum overflows..... I may hit him up
  6. Aug 24, 2015 at 2:58 AM
    #346
    ThomasMore66
    Details? Group buy!
  7. Aug 24, 2015 at 8:02 AM
    #347
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    O rly?!
  8. Aug 24, 2015 at 9:34 AM
    #348
    VolcomTacoma
    Jeff
    NorCal
  9. Aug 24, 2015 at 9:47 AM
    #349
    VolcomTacoma
    Jeff
    NorCal
    I need to have some custom shit made uo so i can mount my catch cans and an electrical box on those 2 body bolts. Just have another piece go down to a fender bolt for stability
  10. Aug 24, 2015 at 9:52 AM
    #350
    VolcomTacoma
    Jeff
    NorCal
    Smog pump FTL. Theres room for me to mount everything i want on the drivers side, i just need to be creative with mount points and supports and such. I basically want a plate for that whole section lol, mount reservoirs to plate, mount aux fuse block to plate, mount plate to wall. Money.
  11. Aug 24, 2015 at 10:40 AM
    #351
    VolcomTacoma
    Jeff
    NorCal
    Yep, bed box in planning stages for dual battery and compressor
  12. Aug 25, 2015 at 8:52 PM
    #352
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Aug 25, 2015 at 9:15 PM
    #353
    VolcomTacoma
    Jeff
    NorCal
    I'm looking at the ADD W1 Oil catch can off of Ebay...any bad reviews on that?
    I'd like to get rid of that cheap plastic reservoir while I'm at it and replace with a nice sleek black metal
  14. Aug 26, 2015 at 3:18 AM
    #354
    ThomasMore66
    I have one. Works fine. I'd like to find some curved or angled nipples to clean up my hose routing, but I haven't figured out the thread size on the can.
  15. Aug 26, 2015 at 8:43 AM
    #355
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You have the Canton Racing supercharger reservoir?
  16. Aug 26, 2015 at 1:20 PM
    #356
    ThomasMore66
  17. Aug 26, 2015 at 1:36 PM
    #357
    VolcomTacoma
    Jeff
    NorCal
    Bah that's just a $50 cap lol.
  18. Aug 26, 2015 at 6:20 PM
    #358
    ThomasMore66
    Look at the other link. Those cans come in different sizes. What's the volume of ours?
  19. Aug 26, 2015 at 7:21 PM
    #359
    VolcomTacoma
    Jeff
    NorCal
    Ahhh my bad. yea I don't really want to have to reroute shit lol, wonder if the factory hoses would stretch to fit that, or if theyre the same size
  20. Aug 26, 2015 at 7:22 PM
    #360
    VolcomTacoma
    Jeff
    NorCal
    Out of everything, the factory SC coolant pump and reservoir just scream cheap at me
