TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 12, 2017 at 5:06 AM
    #3581
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    You guys drop the tank or pull the bed to replace the pump
  2. Mar 12, 2017 at 5:24 AM
    #3582
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  3. Mar 12, 2017 at 7:13 AM
    #3583
    ThomasMore66
    Dallas/Fort Worth & Durango
    I thinK you'll be ok with URD.
  4. Mar 12, 2017 at 7:29 AM
    #3584
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Hope so.
  5. Mar 12, 2017 at 8:53 AM
    #3585
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    14mpg highway is really bad. Do you have an aftermarket roof rack/lightbar on top? A plate bumper that opens up the front wheel wells? Oversized heavy E-load tires? Heavy steel wheels? If larger tires, are you remembering to factor in the mileage delta caused by the larger tires from the odometer reading when calculating mileage?
    Torspd likes this.
  6. Mar 12, 2017 at 9:48 AM
    #3586
    ThomasMore66
    So, I think it's all about your right foot. I can't keep mine out of it. Cruising on the highway it seems about the same, but get in traffic and I find myself using the HP to get around people.
    12TRDTacoma likes this.
  7. Mar 12, 2017 at 9:59 AM
    #3587
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    It does have a 3-inch Icon lift, but the tires are original size. I don't think the wheels are significantly heavier than the stock ones.
  8. Mar 12, 2017 at 10:00 AM
    #3588
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I admit to having a lead foot, but when on the highway I usually set the cruise control to the speed limit if there isn't too much traffic.
  9. Mar 12, 2017 at 10:05 AM
    #3589
    ThomasMore66
    I'm in Dallas. I'd love no traffic, but it doesn't happen. Worse all the time.
  10. Mar 12, 2017 at 10:06 AM
    #3590
    tacomavoyager
    tacomavoyager Well-Known Member
    On the short bed you can't access the pump if you remove the bed. Don't know if it's different on the long bed. I was originally going to remove the bed myself thinking I could access it. It basically sits right below the rear seat on the drivers side.
  11. Mar 12, 2017 at 10:21 AM
    #3591
    ThomasMore66
  12. Mar 12, 2017 at 12:34 PM
    #3592
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Possibly, and or too full. It is only plastic.
    The pump install instruction plan out how to drop the tank. It is by no means difficult, when the tank is low.
    inwood customs and crashnburn80 like this.
  13. Mar 12, 2017 at 5:41 PM
    #3593
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ordered the URD Deatschwerks 255 fuel pump kit. Hope to install next weekend.
    JuanitoBonito likes this.
  14. Mar 13, 2017 at 12:43 AM
    #3594
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I dropped the tank, get a tool for the hose / lid removal. The hardest part was getting those dame breather hoses unhooked. That part would be much easier with the bed off. If I had help/room I would have lifted off bed.
  15. Mar 13, 2017 at 12:45 AM
    #3595
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Iirc a boa type strap wrench works for the top of the gas tank
  16. Mar 13, 2017 at 12:45 AM
    #3596
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    I wants UCON too.:anonymous:.. maybe this summer. Not sure I want to venture into 7th injector territory with CA SMOG. Seems like would be PIA to take it off every two years. :burp:
  17. Mar 13, 2017 at 8:50 AM
    #3597
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah I'm on the fence about the 7th injector, but definitely 2.7 and UCON when I haz money. I have to swap to my stock intake and Y pipe anyways for smog.
  18. Mar 13, 2017 at 9:07 AM
    #3598
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    URD lists the 7th injector as required for 2.7". I guess maybe workaround would be 6 bigger injectors instead? That could be cost as much as kit but may not be as visible.
  19. Mar 13, 2017 at 9:31 AM
    #3599
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Quick calculation borrowed from a corvette site indicates that the 61 lb injectors from URD should be enough even with 255 LPH fuel pump. But I'd have to ask Gadget to be sure. Looks like the 42 lb TRD injectors would be getting close to maxed out at some point.
    400HPx.75=300lbs. 300lbs/6 injectors=50lbs/hr. 61/.8=40lbs/hr injector @ 80% duty cycle.
  20. Mar 13, 2017 at 9:44 AM
    #3600
    VolcomTacoma
    Jeff
    NorCal
    I was leaning closer to water/meth
