TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 13, 2017 at 9:53 AM
    #3601
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The 7th supplements the tiny intercooler, by using the fuel to reduce the charge air temps.
    Higher boost pressure, increases the compressed are temperature. The IAT sensor is pre charge. So it cannot adjust the map, for the increased temp, as it cannot read it.
    Deoending on your climate, additional power mods, and how frequently (including duration) the skinny pedal french kisses the floor board, are all reasons why you would consider it.
  2. Mar 13, 2017 at 9:55 AM
    #3602
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ok well, the Torspd has spoken. Guess I'm getting the 7th injector lol
  3. Mar 13, 2017 at 9:56 AM
    #3603
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Primary injectors should always be sized to match or be over, the engine HP requirements. First and foremost.
  4. Mar 13, 2017 at 9:58 AM
    #3604
    VolcomTacoma
    Jeff
    NorCal
    Interesting. I would say I'll probably be at least 350 at the crank with UCON, if not more...wonder if I should I should swap to larger injectors while I'm at it
  5. Mar 13, 2017 at 10:01 AM
    #3605
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    How much over? Sounds like the 7th injector is as much cooling as it is providing additional fuel. Would running 61lb injectors instead of the TRD 440cc (~42 lbs) eliminate the need for 7th?
  6. Mar 13, 2017 at 10:19 AM
    #3606
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For the cost that they are, it is worthy. They already have maps for them, so it would be straight drop in, plug in ecu, and drive away.
    Bring up the question though. As they have dealt with both the properly sized injectors, and the need for the 7th, a lot.
  7. Mar 13, 2017 at 10:20 AM
    #3607
    VolcomTacoma
    Jeff
    NorCal
    Yeah when I start seeing stuff moving around a bit more I'll give Gadget a call and order everything. I still need to call him about my Pulley install tool that snapped.
    zerotimeouts likes this.
  8. Mar 13, 2017 at 10:21 AM
    #3608
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Enough to have an overhead for your future engine hp goals. www.rceng.com has the perfect calculator. Always focus on primary injectors first.
  9. Mar 13, 2017 at 12:02 PM
    #3609
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I thought 7th injector was 1st gen only
  10. Mar 13, 2017 at 12:31 PM
    #3610
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Negative. First introduced by APR, for the 2nd Gen. Then by URD.
  11. Mar 13, 2017 at 3:38 PM
    #3611
    VolcomTacoma
    Jeff
    NorCal
    Are there still fitment issues at all? Thought I read there was an issue with the 7th rubbing on the TRD SC body or something
  12. Mar 13, 2017 at 5:34 PM
    #3612
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fuel rail adapter, at rear of passenger side of the fuel rail. Sometimes it touches and sometimes it does not. A few passes with a files, to the adapter, clears it up.
    zerotimeouts and VolcomTacoma like this.
  13. Mar 14, 2017 at 5:31 PM
    #3613
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Is there a bigger intercooler that might fit well?
  14. Mar 14, 2017 at 5:35 PM
    #3614
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
    So I'm bout ready to pull the trigger on a s/c. What else are you guys doing to them? Pulley, f/p?? what tune to use? Bully dog/ucon/trd flash?? Thanks
  15. Mar 14, 2017 at 5:59 PM
    #3615
    GT7
    Grant
    Phoenix
    2013 DCLB
    All excluding bully dog
  16. Mar 14, 2017 at 7:21 PM
    #3616
    VolcomTacoma
    Jeff
    NorCal
    I would suggest do the Supercharger first, get a feel for it, then do secondary mods. That way you can feel the gain. Going full throttle with everything right off the bat might make you feel like you want alot more when there isn't that much more. You can almost double the HP out of the SC with all the mods, but after that it gets a little rocky trying for more. Alot of people coming from other supercharged vehicles feel like they gained nothing with just the blower (and whine about it constantly :rofl: ) while there are some of us that love it from the get go.
    Tacomalx4x4[QUOTED] likes this.
  17. Mar 14, 2017 at 8:24 PM
    #3617
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    UCON, since easily available for the '07. Fuel pump, and AFR gauge. Then a 2.7" pulley. :D
  18. Mar 14, 2017 at 11:42 PM
    #3618
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Except you have to pull out the SC again if you are going to UCON route.
  19. Mar 15, 2017 at 12:27 AM
    #3619
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Easy task if you know what you are doing :thumbsup:
  20. Mar 15, 2017 at 10:03 PM
    #3620
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Any idea why the UCON says it is only for 2005-08 and not later. I have an '11 and I know they added the emissions pump in '12 but I didn't think there was much difference until '12.
