TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 16, 2017 at 4:03 PM
    #3641
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Only still available for the URD s/c kits. The production runs for the '09+ is still under way. They should be released in another few months. To be sold without URD s/c kits.
    You don't need the FPR mod. You'll only be even more rich than now, and lose power. It is because your transmission isn't slipping like it used to.
    This!^^^
  2. Mar 16, 2017 at 4:15 PM
    #3642
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good stuff. I'll reverse it when I get home. No sense in wasting more gas than these things already do.
    inwood customs likes this.
  3. Mar 16, 2017 at 5:03 PM
    #3643
    ThomasMore66
    Dallas/Fort Worth & Durango
    Did we decide IPT is the best valve body mod?
    zerotimeouts likes this.
  4. Mar 16, 2017 at 5:15 PM
    #3644
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think so yes, only because of bad reviews from Level 10 IIRC
  5. Mar 16, 2017 at 5:36 PM
    #3645
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I want a modded valve body so damn bad.
  6. Mar 16, 2017 at 5:53 PM
    #3646
    ThomasMore66
    I need to do it. And headers.
  7. Mar 16, 2017 at 6:11 PM
    #3647
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    So, your saying it wasnt just my imagination?
    Nice to hear that from an authority
    12TRDTacoma and Torspd[QUOTED] like this.
  8. Mar 16, 2017 at 6:14 PM
    #3648
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If from rich to puddle, then yup. Bog. Lol
    12TRDTacoma likes this.
  9. Mar 16, 2017 at 6:19 PM
    #3649
    inwood customs
    Dave
    makes perfect sense, growing up its always been that way.......But without numbers to back it up, well you know how that goes.
    I felt my truck stumble, but yeh........"butt dyno"
  10. Mar 16, 2017 at 6:58 PM
    #3650
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shoot. As I have been fiddling with my tune on my Haltech Elite, certain areas have been too rich or too lean. Those rich areas, in the high 9's and low 10's, would cause a noticeable loss in power. Scale them to the 12's and holy sheet, it is all back.
    Now there is another trick, but most people here won't want to spend the money. Even though it isn't too much.
    It is what I had to do with my current engine, to be able to have a good AFR's while in Open Loop WOT w/OEM ECU. Just installing the engine and going, with OEM N/A injectors, and factory 43.5 psi fuel pressure, the WOT AFR's were somewhere more rich than 10's. What did I do, since I couldn't do any ecu tuning, to lean it out???
    Dropped the fuel pressure, with my aftermarket fuel pressure regulator. Dropped it down to about 36-37 psi. Boom. Running mid 11's in WOT. Good enough for WOT, and not a low enough fuel pressure to trip the CEL for bad fuel trims.
    Couldn't electrically tune, so I mechanically tuned.
    :spy:
    inwood customs and gersus like this.
  11. Mar 16, 2017 at 7:58 PM
    #3651
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dropping the fuel pressure will help you get better AFR's on these?
  12. Mar 16, 2017 at 8:17 PM
    #3652
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes, in the Open Loop cells.
  13. Mar 16, 2017 at 10:27 PM
    #3653
    12TRDTacoma
    Rob
    Concordia
    Boosted
    IPT, yes. Unless you have the knowledge and ability to do it yourself.
    Do it!
    It is SO worth it! It's a night and day difference how much the valve body is holding back when in stock form, all because people want granny shifting. I would compare it the equal to shifting gears in a manual and then slowly letting the clutch out instead of just letting off. Causes excess friction build up because of extended engagement/ disengagement.
  14. Mar 17, 2017 at 12:14 PM
    #3654
    ThomasMore66
    So I'm thinking the new intercooler reservoir cap has cured my leak. New cap has a very satisfying click when you tighten it. The stock one never had that.
    inwood customs and JuanitoBonito like this.
  15. Mar 17, 2017 at 12:48 PM
    #3655
    VolcomTacoma
    Jeff
    NorCal
    I don't think mine clicks, I just tighten it as hard as necessary and its fine. I see residue around the cap alot and every so often there will be a dried drip down the side, but my coolant level is still fine.
  16. Mar 19, 2017 at 9:16 PM
    #3656
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    How is the elite 2500?
  17. Mar 20, 2017 at 4:23 AM
    #3657
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Absolutely enamored. I wish it were available back when I purchased the ProEFI. It is so intuitive, and user friendly.
    Truck idles and runs smoother, with cams mind you, than it did on the stock ecu.
  18. Mar 20, 2017 at 9:51 PM
    #3658
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I see the usual suspects are still around lol.
    I have a question for you guys. I recently rolled my intake back to stock to simplify my Safari snorkel installation and I ran into some odd hiccups. First off, my stock intake doesn't fit quite right... the lower mounting screw is about an inch away from where it should be should I couldn't bolt it up. In the end I just secured the box with the top screw and it seems not to be going anywhere but I found this very odd. I even mounted the box twice and double checked that it was all the way on the throttle assembly but it always ends up with the bottom screw missing the hole by an inch. I've never had the stock intake box on with the SC, I'm wondering if my SC mount for the intake box just isn't where it should be for some reason?
    The second odd thing is that I noticed that the stock intake tube has water drain holes in the bottom of it near the fender. Should I silicon these off for the snorkel. I mean the tube is up higher then the water I'll be going into but, still, couldn't this be a source of a hydrolock should I slip into deeper water? Does the risk of sucking in too much water in some freak heavy snow storm outweigh the risk of slipping into a deep puddle?
  19. Mar 21, 2017 at 5:05 AM
    #3659
    inwood customs
    Dave
    Not sure about the drain holes, but the stock intake should fit with the blower. The fit kit comes with a trd air filter that fits the stock housing.
    Ive swapped kine back and forth without issue.
  20. Mar 21, 2017 at 11:46 AM
    #3660
    jsriolo
    jsriolo Well-Known Member
    Susquehanna, PA
    2015 TRD Off-Road V6 6-Speed 4x4 Access Cab
    The supercharger fit kit comes with a small ~1" flat bracket that functions as an offset to support the air box lower mounting bolt. I don't have a good picture handy but lets see if I can 'enhance' what I have...airboxbolt.jpg
    What intake are you taking off? If its the AFE then perhaps we can arrange something...
