TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 27, 2017 at 7:40 PM
    #3721
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Hope not.....but if I do, I'll get a urd stage 2
  2. May 27, 2017 at 7:53 PM
    #3722
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    What high flow cats did you go with? link?
  3. May 27, 2017 at 8:54 PM
    #3723
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Honestly, not sure.....it's a shop that does nothing but Subarus....I had some stock cats with me but the owner talked me into some high flow stainless ones for 150 a piece. I know they know what they are doing so I said have at it....I'll find out what specific brand and I'll let you know.
  4. May 28, 2017 at 10:35 PM
    #3724
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    Anyone here have the k&n intake with their supercharger? I thought I heard not all intakes work with supercharger
  5. May 29, 2017 at 11:06 AM
    #3725
    ThomasMore66
    Dallas/Fort Worth & Durango
    Generally we stay away from the oiled filters. Potential to foul the MAF.
    Blacktaco2042 likes this.
  6. May 29, 2017 at 11:07 AM
    #3726
    TacoJova
    Central Oregon
    Stock for now
    Well I've been running mine for quite a while now but I'm just wondering if I need to buy a new intake or not.
  7. May 29, 2017 at 11:07 AM
    #3727
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Afe pro dry s :thumbsup:
    GT7 likes this.
  8. May 29, 2017 at 12:36 PM
    #3728
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To add to what Thomas said, oil filters are for map based systems, whereas non oiled are for maf based systems. It is the industry standard.
  9. May 29, 2017 at 4:43 PM
    #3729
    eon_blue
    Azusa, CA
    Just got the URD 7th injector kit installed on my truck yesterday, feels like a brand new vehicle :thumbsup: I'm guessing this is what the 5VZE supercharger was supposed to feel like all along. Before I would ping like crazy going up any sort of incline while in boost, sometimes even just cruising around town it would ping. The out-of-the-box results from the kit are very impressive to say the least, for me anyway.
    Now I need to start talking myself into the smaller pulley....
    GT7, Torspd, oni06 and 2 others like this.
  10. May 30, 2017 at 11:22 PM
    #3730
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Into should be pretty easy. Out of is where it becomes challenging. :)
    eon_blue[QUOTED] likes this.
  11. May 31, 2017 at 5:36 AM
    #3731
    ThomasMore66
    Mileage take a big drop? I think that mine gets better mileage with the smaller pulley. However, the right foot still can't leave the pedal alone. Been driving my FJ80 lately. It wins no races. Calms me down. Turn on the 70's music and just cruise.
    JuanitoBonito likes this.
  12. May 31, 2017 at 9:44 AM
    #3732
    eon_blue
    Azusa, CA
    Still on the first tank of gas since I got it installed but should know soon....based on what I'm seeing though it looks to be about the same, maybe even a little better because I've been pretty heavy on the throttle after the install. A few months ago my mileage took a pretty significant dump for no apparent reason so I'm wondering if maybe the new spark plugs and fuel pump in the kit helped out some? After I run a couple of tanks of gas through it and calculate the mileage I'll know for sure.
    tacomavoyager likes this.
  13. Jun 1, 2017 at 5:10 AM
    #3733
    AvaTRD
    AvaTRD Member
    My MAF was throwing a p0101 error two days after having a K&N oiled filter installed as part of my Magnuson S/C kit. There were also some issues with shifting, and a terrible drop in gas mileage. I've since cleaned the sensor and went with a dry filter.
    Fuel performance shot up immediately from 15mpg to 21. That's calculated at the pump, the old fashioned way, rather than relying on sensor data.
    Even though I still need to monitor my A/F for other issues, the cleaning seems to have cleared up all of my problems. I would not recommend using an oiled filter. At least not with a Tacoma.
    SonnyBones likes this.
  14. Jun 2, 2017 at 11:14 AM
    #3734
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Well.....got my truck back with the additions I had done......WOW!!!! what an improvement. Totally different truck....
    GT7, FinnJ and eon_blue like this.
  15. Jun 2, 2017 at 11:19 AM
    #3735
    eon_blue
    Azusa, CA
    Yeah the oiled filters are no good...had one on my older 99 Tacoma and it ruined my MAF sensor. Stock or washable pro dry filter is the way to go, I have the AFE drop in one.
  16. Jun 2, 2017 at 12:23 PM
    #3736
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    2.825 pulley, walbro 255 fuel pump, DT shorties with high flow cats. Also, slapped on a goodyear gator belt and replaced the Toyota stock belt.
  17. Jun 2, 2017 at 12:27 PM
    #3737
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Also, I was planning initially on putting stock cats on the shorties. I purchased a set of stock manifolds/cats from a member with only 14 thousand miles if I remember correctly. They will be up for sale shortly. If anyone wants them let me know.....
  18. Jun 2, 2017 at 1:36 PM
    #3738
    AvaTRD
    AvaTRD Member
    Damn, that's pretty.
  19. Jun 2, 2017 at 3:08 PM
    #3739
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    How does it sound with the headers and cats? Did you find out what cats you used?
  20. Jun 2, 2017 at 3:18 PM
    #3740
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Vibrant high flows are what was installed. They seem to have decent reviews so that makes me happy. As far as sound, it definitely brings out a little more deeper rumble without being to obnoxious. I wanted it a little louder and that's exactly what I got:thumbsup:
