TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jun 3, 2017 at 6:28 PM
    #3761
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^This, you need a gauge that actually pulls from your headers/Y pipe to get an accurate reading of your mixture.
    Torspd likes this.
  2. Jun 4, 2017 at 6:59 AM
    #3762
    Rattlecanpaint
    Rattlecanpaint Member
    Winston Salem, NC
    '14 4wd sport dbl cab LB Blue Ribbon Metalic
    Ok. Well that makes me feel a bit better. The rest of the truck (drivetrain) is stock. Am I going to need to weld in a bung for that or could I just replace the factory o2 sensors. Also aren't the cats going to skew that reading if it's in the y pipe?
  3. Jun 4, 2017 at 8:11 AM
    #3763
    oni06
    oni06 Well-Known Member
    You need to weld a bung and the cats will skew it a bit.
  4. Jun 4, 2017 at 4:27 PM
    #3764
    Rattlecanpaint
    Winston Salem, NC
    Gotcha. So what is the best tuner? I wasn't really aware anyone but Bully Dog made anything for the 4.0.
  5. Jun 4, 2017 at 5:01 PM
    #3765
    oni06
    Get the TRD S/C flash. But if you already but the BD tune on you can't get it.
    gersus likes this.
  6. Jun 4, 2017 at 6:07 PM
    #3766
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rumor has it that there is a shop in SoCal, which can get the plugs, to then make a jumper harness.
    I am still quite skeptical on that, so I give it a small chance of actually being true.
    If you want, I can direct you to the individual having one made with said plugs?
  7. Jun 4, 2017 at 6:08 PM
    #3767
    ThomasMore66
    Dallas/Fort Worth & Durango
    What's that smell? Clutch?
  8. Jun 4, 2017 at 6:15 PM
    #3768
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Magnuson only uses the BD device to put their specific tune onto the Tacoma.
    BD has their specific tunes.
    The TRD reflash is available by dealerships, if they allow you to have it.
    URD UCON Advanced Engine management, is available for 05-08, and currently the '09+ if you purchase their S/C kit. Soon to be available to nom kit purchasers.
  9. Jun 4, 2017 at 6:31 PM
    #3769
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    lol....it's holding up , but almost on it's last leg.
  10. Jun 4, 2017 at 6:53 PM
    #3770
    ThomasMore66
    I want headers now. Been spending time and money on the 97 FJ80. Checkbook needs a break. Taking it to CO in a couple weeks. I was just planning a little wheeling.
    JuanitoBonito likes this.
  11. Jun 4, 2017 at 7:12 PM
    #3771
    VolcomTacoma
    Jeff
    NorCal
    I contacted the guy on here a while back who did it, he wanted about a grand to make the harness for UCON. Holding out for now since I've got a kid due any day now and have to put money in shock rebuilds and paint right now, but Performance is coming up soon on the list :D
    Torspd[QUOTED] and oni06 like this.
  12. Jun 4, 2017 at 7:30 PM
    #3772
    oni06
    Congrats on the kid. We had our second in February.
  13. Jun 4, 2017 at 7:31 PM
    #3773
    ThomasMore66
    You know what's better than having kids? Getting them off your payroll. More money for toys.
  14. Jun 5, 2017 at 8:02 AM
    #3774
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers: :laugh:
  15. Jun 5, 2017 at 10:06 AM
    #3775
    Rattlecanpaint
    Winston Salem, NC
    Oh. Ok. I had to have BD update my unit remotely (work firewall and such wouldn't let me do it.) So I figured it was BDs tune. I guess I'll stick with that then. Just wish I could do more with it like compensate for the bigger tires and stuff like they do for jeeps. Maybe Toyota won't let them into that side of things. Seems like it put a performance shift program in the trans though.
  16. Jun 7, 2017 at 5:38 PM
    #3776
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Jun 7, 2017 at 5:39 PM
    #3777
    VolcomTacoma
    Jeff
    NorCal
    gersus likes this.
  18. Jun 7, 2017 at 5:40 PM
    #3778
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I already ordered! :)
  19. Jun 7, 2017 at 6:25 PM
    #3779
    oni06
    What the price?
  20. Jun 7, 2017 at 6:32 PM
    #3780
    gersus
    Missouri
    14 Tacoma DCOR
    1599
