TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jun 12, 2017 at 7:38 AM
    #3821
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Jun 12, 2017 at 10:23 AM
    #3822
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    How does a 2.55 not blow up stock internals?
  3. Jun 12, 2017 at 10:24 AM
    #3823
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    No one said it wouldn't ;)
    :boink::burnrubber::bikewhoops::boom:
  4. Jun 12, 2017 at 10:43 AM
    #3824
    ThomasMore66
    Dallas/Fort Worth & Durango
    What kind of boost numbers is 2.55"? New injectors required?
  5. Jun 12, 2017 at 10:43 AM
    #3825
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ask @TRON . He is running it.
  6. Jun 12, 2017 at 10:47 AM
    #3826
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depends on which size injectors you currently have. Then how much crank hp that will be after the pulley is installed. Determining whether your injectors have enough overheard before reaching 90% duty cycle.
  7. Jun 12, 2017 at 10:49 AM
    #3827
    ThomasMore66
    I have the ones that came with the SC. I'm still learning on all of this. I had read 80% duty cycle, but I'll trust you on that. What do you think the boost will go to? I can hit 8 psi max now with the 2.85".
  8. Jun 12, 2017 at 10:50 AM
    #3828
    gersus
    Missouri
    14 Tacoma DCOR
    That's craziness
  9. Jun 12, 2017 at 10:58 AM
    #3829
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    I think once you go 2.7 or lower you'll need a 7th injector or upgrade current 6 injectors.
    And of course an upgraded fuel pump.
    gersus likes this.
  10. Jun 12, 2017 at 11:08 AM
    #3830
    ThomasMore66
    Got the fuel pump.
  11. Jun 12, 2017 at 12:17 PM
    #3831
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He also upgraded to the NST s/c crank pulley. :eek:
    gersus[QUOTED] likes this.
  12. Jun 12, 2017 at 1:42 PM
    #3832
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Whenever I can grab the UCON, I'll be doing 7th injector, 2.7 pulley and UCON. With my current setup I think that's about as far as I wanna go before I start fucking with internals.
    jojotoo, gersus and oni06 like this.
  13. Jun 12, 2017 at 2:53 PM
    #3833
    ThomasMore66
  14. Jun 12, 2017 at 2:57 PM
    #3834
    ThomasMore66
    With the UCON do you need the 7th injector? Just for cooling? Any emissions issues with that?
  15. Jun 12, 2017 at 3:32 PM
    #3835
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Jun 12, 2017 at 3:50 PM
    #3836
    GT7
    Grant
    Phoenix
    2013 DCLB
    I thought they just stopped producing them
  17. Jun 12, 2017 at 3:56 PM
    #3837
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was the other part of it. The Story Goes deeper than either of the two elements listed though.
  18. Jun 12, 2017 at 4:24 PM
    #3838
    ThomasMore66
    Does the UCON make it possible to disable the governor?
  19. Jun 12, 2017 at 4:25 PM
    #3839
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For those off-road or track day scenarios, yes.
  20. Jun 12, 2017 at 4:26 PM
    #3840
    ThomasMore66
    I played with a guy driving the big Jag with personalized plates on the way home. I'm 100% certain he'd leave me on open road, but with congestion I was always right there. I want more hp!
