TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jun 12, 2017 at 4:27 PM
    #3841
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yeah, those.
  2. Jun 13, 2017 at 10:42 AM
    #3842
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Of course, only on a closed course
  3. Jun 13, 2017 at 10:43 AM
    #3843
    VolcomTacoma
    Jeff
    NorCal
    Dude I surprise people constantly. Full size trucks always get agro when their cute little V8 can't keep up
  4. Jun 13, 2017 at 11:05 AM
    #3844
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It's not in their heads. Just in their foot. Lol
  5. Jun 13, 2017 at 1:38 PM
    #3845
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I'm actually running it on the TRD reflash. My AFRs are 11.3 at wot ;)
    jojotoo and gersus[QUOTED] like this.
  6. Jun 13, 2017 at 1:40 PM
    #3846
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Do you have a 7th injector or bigger overall injectors?
  7. Jun 13, 2017 at 2:02 PM
    #3847
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Guessing not possible without UCON, not sure how it is still in the safe range???
    Do tell...
    gersus likes this.
  8. Jun 13, 2017 at 2:24 PM
    #3848
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Mostly whiney diesels around here that leave my little yoter in their smoke.
  9. Jun 13, 2017 at 2:32 PM
    #3849
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :devil:
    We haz smartz.
    7th injector would be harder to run without the UCON. AFR's at 11.3:1 @WOT, through the RPM range are quite safe. I will let him explain his secrets. :D Should he want. Don't want to take that mystery away from him..
    jojotoo and gersus like this.
  10. Jun 13, 2017 at 5:52 PM
    #3850
    VolcomTacoma
    Jeff
    NorCal
    My first time really punching it was against some dude in a brand new Turbo Diesel. He was gunning it light to light, I got next to him finally, and stayed ahead of him despite the worst shifting I've ever done. Staying well within the speed limit, obviously.
  11. Jun 13, 2017 at 5:55 PM
    #3851
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well within, obviously.
  12. Jun 13, 2017 at 5:57 PM
    #3852
    VolcomTacoma
    Jeff
    NorCal
    We had a gentleman's agreement to keep the RPMs under 4k as well. Speed limit was 45 on that road, I managed to stay ahead for that whole minute it took to get there. #owned
    gersus and Torspd[QUOTED] like this.
  13. Jun 13, 2017 at 6:20 PM
    #3853
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    #cantcruisewithme
  14. Jun 15, 2017 at 2:29 PM
    #3854
    bendilzerian
    bendilzerian Well-Known Member
    Houston
    2015 DCSB White TRD Sport PreXrunner
    Any numbers? How big of injectors you running?
    I'm planning out my build and curious where you're at. I figure I'll go the whole 9 yards and do the 2.55, UCON, 7th... what else am I gonna do with that 10K lol
    oni06 likes this.
  15. Jun 15, 2017 at 5:49 PM
    #3855
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    So I got a AEM Uego x series afr gauge and was wondering if I only needed to connect power and ground and tape together all the rest of the wires or are they also needed?
  16. Jun 15, 2017 at 7:38 PM
    #3856
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yup you can do that. ....you don't need them
  17. Jun 15, 2017 at 9:08 PM
    #3857
    TRON
    I'm running the 455 injectors and reflash. I've never dynoed my setup. I did run the UCon for many years... Even helped work with Scott on trouble shooting both versions of the ucon to run better . But if I knew what I know now, I would have stuck with the TRD reflash and leaned it out to its potential. Or purchased an after market ecu that a nearby tuner knows well. I think that's most important for tuning any ride. Find a local tuner and buy an ecu that he can tune well!! The TRD reflash is very dependable and consistent, which I like. It's true I have the 2.55 and NST kit... But I also live at 5000 ft and keep my rev limit at 5800 rpms.
    SonnyBones and Torspd like this.
  18. Jun 16, 2017 at 8:19 AM
    #3858
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Forgive the ignorance, but what kinda performance gains can we expect by adding the uconn? I've searched here and xr-underground without finding much info. To my understanding- having an intake, exhaust, smaller pullies etc. will lead to bigger gains for the uconn than say just a stock supercharged set-up. Assuming thats true, how much more will the uconn add?
    Tn Jeff likes this.
  19. Jun 16, 2017 at 8:37 AM
    #3859
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Inproved tuning map over either, stock or reflash.
  20. Jun 16, 2017 at 8:47 AM
    #3860
    mightytacoman
    Kel
    4.5L 1grfe
    I get that, but to what degree will that be seen? What kinda hp/torque is left on the table under the stock/reflash in comparison.
