TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 23, 2017 at 8:53 PM
    #4061
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You mean the inner cooler that gets bolted in to the main supercharger unit? Or an additional external 'radiator'.
  2. Jul 24, 2017 at 3:14 AM
    #4062
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
    No room for the inner. I meant the cooler that u mount it behind the bumper
  3. Jul 24, 2017 at 6:39 AM
    #4063
    VolcomTacoma
    Jeff
    NorCal
    Oh. Yeah you could mount another one in the bumper I suppose, but you might not get much airflow through it. And mounting one in front of the other two will probably inhibit flow through the engine radistor. Best bet really is a larger outer cooler.
    I need to get one of those radiators Tor found for us( for himself but shared with us :rofl: ) and throw a dual electric fan on it, maybe they can build a bigger blower cooler as well to fit in right behind the grill. My issue is the URD CAI is already pretty squished right there. So a thicker blower cooler would crush the CAI even more. Might need to rethink the CAI.
    Have been considering a custom snorkel using 3" aluminum tubing from throttle body to above roof line with an in line filter. I found all the components on Amazon lol, even a Toyota MAF tubing section that should let the MAF bolt right up. Question is, where exactly do I position the MAF in the intake for perfect readings. Like...a foot off the TB or what?
  4. Jul 24, 2017 at 6:59 AM
    #4064
    VolcomTacoma
    Jeff
    NorCal
  5. Jul 24, 2017 at 8:18 AM
    #4065
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Link isn't working on my phone.
  6. Jul 24, 2017 at 8:26 AM
    #4066
    VolcomTacoma
    Jeff
    NorCal
    It's a Spectre In line filter 6" wide with 4" inlet and outlet. Use a 4" to 3" reducer on either side to match 3" aluminum tubing for all the rest of the piping, probably just go straight out from the TB and utilize the existing fender hole, 90° right out of the hole and go along the inner fender and up along the A pillar. They also make a 3" inlet/outlet inline filter but the filter body itself is only 4" with a small cone filter inside, would rather have the 6" to maximise filter size. Even that is a major drop in filter size from the URD, so I'd be cleaning it often lol
  7. Jul 24, 2017 at 8:35 AM
    #4067
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A lot of stuff to comment on in here. Lol.
    When people are referring to the heat exchanger are they talking about the internal cooler which gets bolted into the supercharger or the one which is outside of the engine bay?
    As a reference, the maximum you want to spin these blowers before you start losing power is 18,000 RPM straight from Eaton.
    Hey Jeff @VolcomTacoma , we have the same intake don't we? We could always go with a shorty nose intake. They sell them at pep boys. It may work better behind the grill than our huge ones we have in there now and not get crushed like our current ones and also be easier to remove for cleaning.
    @FinnJ I did forget the Euro cars do tend to run on the hotter side than ours, that is true. No cooling system issues for me, just want to cool things down and give more capacity to what is already in place because I feel like it is not a lot that runs through the system.
  8. Jul 24, 2017 at 9:59 AM
    #4068
    VolcomTacoma
    Jeff
    NorCal
    The problem isn't length, Rob, it's width, and why would reduce your filter media amount. Did you want to clean it every week? You do realize once it gets dirty enough not only are you suffocating the engine a bit, it can start pulling particulate through the clogged media and right in to your engine. :facepalm:
  9. Jul 24, 2017 at 10:46 AM
    #4069
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I haven't cleaned my filter since I got it. Lol. Remember they are dry so they don't attract as much bs as those K&N oiled ones do. It's just an idea. Remember it's all about options and the more we know about the better off we are to use what is at our disposal. :)
  10. Jul 24, 2017 at 11:55 AM
    #4070
    VolcomTacoma
    Jeff
    NorCal
    So because it's dry it doesn't get dirty. Are you serious?
    TacoJova likes this.
  11. Jul 24, 2017 at 12:16 PM
    #4071
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are the king of misconstruing my words. Lol.
  12. Jul 24, 2017 at 12:34 PM
    #4072
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    About 2 weeks ago I noticed my truck sluggish and with only 1 psi of boost. I have an aFe dry intake which has white filter media, it looked slightly tan but not too much to raise awareness. Well halfway through ripping the supercharger and bypass valve, I decided to try cleaning the filter and it was actually very dirty. Cleaned it, and back to boosting. Last time I cleaned the filter was two years ago but having driven about 7k miles I figured it was fine still. Off-roading will do a number for sure. Ordered a black pre-filter now so it's more obvious when it gets dirty.
    12TRDTacoma and jojotoo like this.
  13. Jul 24, 2017 at 1:29 PM
    #4073
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. So it was clogged to the point where it was hindering boost? Being that I put my filter on well over 7K ago and have wheeled a couple times since I put it on I'm going to pull mine off and clean it as well. I wonder how clogged it might be. I haven't cleaned it in a LONG time.
    ls1 prerunner[QUOTED] likes this.
  14. Jul 24, 2017 at 1:33 PM
    #4074
    ls1 prerunner
    Andy
    El Paso, TX
    Yeah, I was surprised too. Now I'm going to make it a force of habit to clean it at minimum with every oil change. There's some areas with silt where I trail so that didn't help my case either.
  15. Jul 24, 2017 at 1:44 PM
    #4075
    VolcomTacoma
    Jeff
    NorCal
    Misconstrue what. They're dry so they don't attract as much BS (dirt? Particulate). It's still a filter, Rob. It's going to filter as much as an oiled filter, but instead of using oil to catch it, it uses layered dry filter media.
    Roostfactor likes this.
  16. Jul 24, 2017 at 1:46 PM
    #4076
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I have the disreputable 2gen TRD CAI, but it has one nice feature, this:
    http://www.****************/wp-content/uploads/2017/01/TRD_Cold_Air_Intake_5th_Gen_4Runner_Service_Filter.jpg
    I have used nowadays the OEM filter (2010+ FJ Cruiser/4Runner) in it, there was always went some dirt over the K&N type TRD filter.
    12TRDTacoma likes this.
  17. Jul 24, 2017 at 1:48 PM
    #4077
    VolcomTacoma
    Jeff
    NorCal
    ^Ewwwwwwwwwww
  18. Jul 24, 2017 at 1:52 PM
    #4078
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I never liked oiled filters because they cause harm to the MAF.
    GM quality right there. ;)
  19. Jul 28, 2017 at 10:32 AM
    #4079
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    Welp.... girlfriend drove the truck today and accidentally put 89 octane in. :annoyed: I told her to just stop by orileys and buy some octane booster for just the one time. What do y'all think?
    jojotoo likes this.
  20. Jul 28, 2017 at 10:38 AM
    #4080
    VolcomTacoma
    Jeff
    NorCal
    You'll be fine. Maybe put 2 octane booster bottles in just to be safe though :D
    My Wife did that once with 87 on a road trip. I went in and got 2 bottles and dumped them in and felt a little power boost out of it lol
    jojotoo and SlapChop7 like this.
