TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 28, 2017 at 11:13 AM
    #4081
    oni06
    oni06 Well-Known Member
    Moral of this story is make sure the truck is filled with gas before letting wife/girlfriend drive it.
  2. Jul 28, 2017 at 6:57 PM
    #4082
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ok wow, I know we talked about air filters, and it's only been about 5k miles since I last cleaned mine, but I figured it's also got about 3 Pismo trip and a couple Hollister trips, it was filthy! Getting the truck all ready for Pismo next weekend, glad I cleaned it when I did. Soaked it in the cleaner for like 5 minutes then sprayed it out with the hose lightly, pure brown water for about a solid minute!
  3. Jul 29, 2017 at 1:05 AM
    #4083
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Some sources say 30k miles for cleaning the air filter. As with so many other maintenance items, it all depends on the usage that it sees. Glad you checked it.
  4. Jul 29, 2017 at 2:27 AM
    #4084
    VolcomTacoma
    Jeff
    NorCal
    Yeah I mean If its just road use, then the average user is probably fine, but having the intake on the front of the truck, plus being out in the sand and following behind trucks offroad that are kicking up dust, it was pretty coated. I'll have to be sure to keep an eye on it more often.
  5. Jul 29, 2017 at 7:20 AM
    #4085
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You have the URD filter correct? What cleaner did you use. All I have seen including Injen say to use a vaccuum or light air pressure to clean it. I prefer the low pressure water idea sprayed from the inside of the filter outward.
    jojotoo and Skootter14 like this.
  6. Jul 29, 2017 at 1:37 PM
    #4086
    VolcomTacoma
    Jeff
    NorCal
    I had some old K&N cleaner I used on it. Maybe it shortened the life of it, who knows. But It had some pretty en-trained dirt in it, that light watering wasn't taking out. Usually the dry filters if you do it often enough after an offroad trip you can take it off and lightly bang it against something and most of the sand and grit will fall out. But this one, nothing came off when I did that and it was still stained a bit lol. I just bought the AFE cleaner since I'm pretty sure this is just an AFE filter slapped on to some tubing with a URD sticker on it lol.
    Roostfactor[QUOTED] likes this.
  7. Jul 29, 2017 at 4:37 PM
    #4087
    Roostfactor
    TX panhandle
    I think it's an Injen nanofilter...probably the same thing.
  8. Jul 29, 2017 at 6:45 PM
    #4088
    VolcomTacoma
    Jeff
    NorCal
    Yeah whatever, it's all the same shit lol. Non-oiled being the key. I've got that prefilter cover I need to put over it, I forgot when I had it off to add it on. Should definitely help kept alot of the larger particulate and bugs and crap from sticking in between the filter ridges
    Roostfactor likes this.
  9. Aug 1, 2017 at 3:14 PM
    #4089
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Its made by amsoil, not afe
  10. Aug 1, 2017 at 3:25 PM
    #4090
    VolcomTacoma
    Jeff
    NorCal
  11. Aug 1, 2017 at 3:44 PM
    #4091
    inwood customs
    Dave
    Too good for accurate information?
  12. Aug 1, 2017 at 4:17 PM
    #4092
    VolcomTacoma
    Jeff
    NorCal
  13. Aug 1, 2017 at 4:39 PM
    #4093
    inwood customs
    Dave
    Lol, now thats goodshit.
  14. Aug 1, 2017 at 4:44 PM
    #4094
    inwood customs
    Dave
    More fun?
    Just found this....
    "The URD TCAI uses an AMSOIL filter that has the Donaldson's dry synthetic media" per Gadget
  15. Aug 1, 2017 at 6:12 PM
    #4095
    VolcomTacoma
    Jeff
    NorCal
  16. Aug 1, 2017 at 6:35 PM
    #4096
    inwood customs
    Dave
    she looks like a can of budweiser... Id take a pbr over that crap
    JuanitoBonito likes this.
  17. Aug 1, 2017 at 6:36 PM
    #4097
    VolcomTacoma
    Jeff
    NorCal
    Whoa whoa whoa, now you've gone too far.
  18. Aug 1, 2017 at 6:38 PM
    #4098
    inwood customs
    Dave
    coors light?
  19. Aug 1, 2017 at 6:40 PM
    #4099
    VolcomTacoma
    Jeff
    NorCal
    Ok we can compromise on that. Would still bang J-law any day though, Bud light shirt or not.
    inwood customs likes this.
  20. Aug 1, 2017 at 6:41 PM
    #4100
    inwood customs
    Dave
    J. Law you say?
    rmepilot likes this.
