TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 27, 2017 at 8:13 PM
    #4161
    ThomasMore66
    Dallas/Fort Worth & Durango
    I struggle with my reservoir leaking. A new Al can would be something I'd pay up for.
    GT7 likes this.
  2. Aug 27, 2017 at 9:38 PM
    #4162
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Coupe used to make them.
    inwood customs likes this.
  3. Aug 29, 2017 at 10:57 AM
    #4163
    ThomasMore66
    Yes he did. Used to. You dry @Torspd? Shit is getting real down there.
  4. Aug 31, 2017 at 7:01 AM
    #4164
    ThomasMore66
    Boys, we're already having a gasoline shortage in the Dallas area due to Harvey. I looked at STP octane booster last night and didn't get comfortable that it would do the trick. If I have to buy regular what is the best octane booster to add to make up the difference?
  5. Aug 31, 2017 at 7:06 AM
    #4165
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Anyone have a PDF or something showing what I need to return my engine to stock? Truck was boosted when I bought it
  6. Aug 31, 2017 at 7:07 AM
    #4166
    ThomasMore66
    Why would anyone do that?
    12TRDTacoma and sbond007 like this.
  7. Aug 31, 2017 at 7:08 AM
    #4167
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Selling the truck. Not impressed with the supercharger either
  8. Aug 31, 2017 at 7:11 AM
    #4168
    ThomasMore66
    The SC really gets better when you step down to a 2.85" pulley and add a bigger fuel pump, but it's not for everyone.
    12TRDTacoma and 1truckdriver like this.
  9. Aug 31, 2017 at 7:11 AM
    #4169
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    The guy that sold me my supercharger just followed the installation PDF in reverse order. I don't know if that will help you. You will need some parts such as injectors and the intake manifold if you bought it already supercharged. Which btw I have most, if not all of my stock parts in a box still.
  10. Aug 31, 2017 at 7:14 AM
    #4170
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yeah I guess that's not a bad idea. I'll find the instructions and see if it helps.
    I've been meaning to put the 2.85 pull in. But now truck is for sale so it doesn't matter. Still sucks to make 12mpg and pay for premium. Although it did help with all the armor and camping equipment on the truck.
  11. Aug 31, 2017 at 7:33 AM
    #4171
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I know that the yellow fuel injectors need to stay in the truck for it to run right with the flashed ecu. Aside from that you should be able to follow the instructions in reverse order I believe.
  12. Aug 31, 2017 at 7:35 AM
    #4172
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Torco octain booster is the best, but if you can't get it and get jammed with buying regular, you can do it just stay out of boost, you'll have to drive like a grandma, but that's the only way.
    On the other hand, my heart goes out to you guys down there. During hurricane Sandy I was the OEM coordinator in a major city up here. The refinery in Elizabeth got flooded and there was no fuel, we ended up getting two military diesel tankers come up to supply fuel for our fire engines, and FEMA brought up a tanker full of gasoline for our police cars.
    The only thing I could recommend is have at least one vehicle filled up in case you need to vacate the area. Stay safe
    ls1 prerunner likes this.
  13. Aug 31, 2017 at 7:43 AM
    #4173
    ThomasMore66
    I had another recommendation for Torco too. Just looked it up. Does it work with cats and o2 sensors? I looked at one VP Racing product that did not.
  14. Aug 31, 2017 at 7:52 AM
    #4174
    ThomasMore66
    Can't seem to find Torco near me, but I did find Lucas Oil. Claims to be safe with cats and O2 sensors. I guess I'll grab a few bottles. Just saw that the Motiva refinery (largest in US) could be down two weeks.
  15. Aug 31, 2017 at 7:52 AM
    #4175
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I have all my stock shit...
  16. Aug 31, 2017 at 7:53 AM
    #4176
    ThomasMore66
    I have mine too, but it's never going back on. If anyone wants some 2013 stock parts, let me know.
    1truckdriver likes this.
  17. Aug 31, 2017 at 8:00 AM
    #4177
    Billy182
    Bill
    NJ
    X-Runner
    http://torcoracefuel.net/pro-accelerator.html
    Torspd likes this.
  18. Aug 31, 2017 at 8:01 AM
    #4178
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Mine also has always leaked/seeped a little from the hose fittings. $35 for a jug of Toyota coolant and topping it off at every oil change. All good.
  19. Aug 31, 2017 at 8:07 AM
    #4179
    ThomasMore66
    Found that a minute ago. If I can find it in a store I'll buy that over Lucas. Apparently Autozone has Lucas, but not Torco.
    I figured we'd have a gasoline issue down here, but I didn't think it would happen this fast. Wonder how the gas shortage will impact rescue efforts and people getting out of S. TX... What a mess.
  20. Aug 31, 2017 at 8:31 AM
    #4180
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I'm gonna source a stock ecu I think
