TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 20, 2015 at 7:26 PM
    #401
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dude, the pulley is hella easy. get ANYONE you know to hold a strap wrench or a set of channel locks on the pulley once its warmed up. From out of the oven to fully installed took about 3 minutes tops. As long as you have everything greased up and tools ready and everyone knows exactly what they are doing, its SUPER easy. Hardest part was shaving down the tip of one arm of my puller as it wouldn't clear the Supercharger assembly. I think I bought one size to big though.
  2. Sep 20, 2015 at 7:26 PM
    #402
    VolcomTacoma
    Jeff
    NorCal
    As for the fuel pump, I'm gonna wait for an extra set of hands, AND when it cools down just a bit lol
  3. Sep 20, 2015 at 7:32 PM
    #403
    ThomasMore66
    Dallas/Fort Worth & Durango
    So you've already violated the fuel pump code...
  4. Sep 20, 2015 at 7:35 PM
    #404
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Those stupid two bolts on the front and rear of the SC are easier to get to. The 1st gen is square where they are and blocks access to the back one a lot. I've dropped the nut in the engine before but luckily fished it out. Plus it's smaller and easier to move around. Other than that not much of a difference.
  5. Sep 20, 2015 at 8:15 PM
    #405
    VolcomTacoma
    Jeff
    NorCal
    Wut
  6. Sep 20, 2015 at 8:20 PM
    #406
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I know what he means.
  7. Sep 20, 2015 at 8:25 PM
    #407
    VolcomTacoma
    Jeff
    NorCal
  8. Sep 20, 2015 at 8:31 PM
    #408
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    He means you should have upgraded the fuel pump before installing the smaller pulley
  9. Sep 20, 2015 at 8:51 PM
    #409
    VolcomTacoma
    Jeff
    NorCal
    Hmmm, haven't noticed any lean outs or power cut outs...
  10. Sep 20, 2015 at 8:52 PM
    #410
    VolcomTacoma
    Jeff
    NorCal
    I fully plan on replacing it as soon as I can get a body
    1truckdriver likes this.
  11. Sep 20, 2015 at 8:59 PM
    #411
    ThomasMore66
    See, I've been asking for data on why, and you went out and added the pulley first. I'm proud of you. Now let's wait and see if there is a failure. Data. I love Data. Probably the engineering degree. Let me get some popcorn.
  12. Sep 20, 2015 at 9:06 PM
    #412
    ThomasMore66
    Yes! Everyone is going off script. I love these moments.
  13. Sep 20, 2015 at 9:06 PM
    #413
    VolcomTacoma
    Jeff
    NorCal
    My AFR is fine, I'm just adding the pump for future higher boost and mods and insurance
  14. Sep 20, 2015 at 9:08 PM
    #414
    ThomasMore66
    :popcorn:
    My Ultragauge says my AFR is fine. Why do I need a fuel pump?
  15. Sep 20, 2015 at 9:10 PM
    #415
    ThomasMore66
    Blaspheme!
  16. Sep 20, 2015 at 9:13 PM
    #416
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    It's not just rich vs lean.....
    It's how hard the stocker can be pushed before it overheats and how long it can push 100% before crapping out.
    Torspd likes this.
  17. Sep 20, 2015 at 9:13 PM
    #417
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  18. Sep 20, 2015 at 9:21 PM
    #418
    ThomasMore66
  19. Sep 20, 2015 at 9:25 PM
    #419
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    And not a single one of those trucks broken in yet
  20. Sep 20, 2015 at 9:34 PM
    #420
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fuel pump feeds injectors. Injectors feed cylinders.
    Injectors can feed a rich amount while the pump is on the verge of its duty cycle. Throw in some variable that pushes its duty cycle to much....done.
    Even the injectors themselves can be to small for the power and make the vehicle run rich. Until the fail to operate properly.
    There are formulas for flow to engine hp. Find them and use them.
    Conumdrum and Justus like this.
