TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 30, 2017 at 8:29 PM
    #4221
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    There it is!!:rolleyes:
  2. Sep 30, 2017 at 8:40 PM
    #4222
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Scratch that. I'm thinking about the intercooler pump. Apparently the TRD pump is an off-the-shelf Bosch that is also used on the 2003 s/c'ed Mustangs.
  3. Sep 30, 2017 at 9:00 PM
    #4223
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Biscuits[QUOTED] likes this.
  4. Sep 30, 2017 at 9:08 PM
    #4224
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    :smack:............I’ve always wanted to use this emoji
    Torspd, gersus and oni06 like this.
  5. Sep 30, 2017 at 10:17 PM
    #4225
    ThomasMore66
    FU
    JuanitoBonito[QUOTED] likes this.
  6. Sep 30, 2017 at 10:26 PM
    #4226
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Figs engineering makes an aluminum reservoir tank for Magnason S/C.
    zerotimeouts likes this.
  7. Sep 30, 2017 at 10:29 PM
    #4227
    Biscuits
    SonnyBones[QUOTED] likes this.
  8. Sep 30, 2017 at 10:34 PM
    #4228
    SonnyBones
    Jeffery
    Very pricey too lol
    Biscuits likes this.
  9. Sep 30, 2017 at 10:46 PM
    #4229
    Biscuits
    I think I'll add that at the very bottom of the"shit I don't need to buy but one day I might" list.
    1truckdriver, oni06 and SonnyBones like this.
  10. Oct 1, 2017 at 6:49 AM
    #4230
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    If you have access to a shop for work or something you could just make one yourself. For a lot less even. Its really just your time at that point.
  11. Oct 1, 2017 at 8:30 AM
    #4231
    reedbrynn14
    reedbrynn14 Well-Known Member
    2014 TRD Tacoma
    supercharged, icon stage 2, rock sliders, 255/85-16
    My intercooler pump turns on randomly while the truck is sitting in the driveway and/or garage. I've asked my service department about the issue just to be told that everything is hooked up properly. Is this normal or should I look for another 12V source?
  12. Oct 1, 2017 at 8:52 AM
    #4232
    oni06
    oni06 Well-Known Member
    Normal. The circuit that the instructions have you tap into goes hot periodically. Forget why this happens but it's explained on here
    somewhere.
    reedbrynn14[QUOTED] likes this.
  13. Oct 1, 2017 at 10:01 AM
    #4233
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    System emissions/evap check happens to be on that circuit
  14. Oct 1, 2017 at 10:19 AM
    #4234
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I like this one very much. That won't have the nipple leak associated with the plastic reservoir. Coupe, years ago made small run of a design similar to the Figs, in the link. It was a just a littls more in price as it had ports for sensors.
  15. Oct 1, 2017 at 10:22 AM
    #4235
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah it runs from time to time. Once should be about 20 min after you shut it off and then one more time a few hours later (that runs for quite a while)
    It's all normal though
  16. Oct 1, 2017 at 10:30 AM
    #4236
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I've wondered if you couldn't just get someone to fab a custom one for that price with a bit more volume. Or just find one of the dozens of ~$150 camaro or mustang ones that could fit instead.
    Biscuits[QUOTED] and Torspd like this.
  17. Oct 1, 2017 at 10:49 AM
    #4237
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm probably the jerk of this thread for posting this up, but go with a custom reservoir. Mine fits about 1.25 gallons for reserve not including what is in the system already and if I really want to I could use ice in there at any point as well. ;)
  18. Oct 1, 2017 at 11:08 AM
    #4238
    memario1214
    Colton
    Missoula, MT
    That's sweet.
    Dumb question... but where's your battery?
  19. Oct 1, 2017 at 11:10 AM
    #4239
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol thanks brotha! The battery is relocated to the back, on the frame under the cab.
  20. Oct 1, 2017 at 11:52 AM
    #4240
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Whoa!!!
