TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Oct 11, 2017 at 2:36 PM
    #4301
    ThomasMore66
    Dallas/Fort Worth & Durango
    Apparently you can datalog with the UCON. I should have jumped on that right away, but I had just burned a bunch of money on my house and the checkbook needed a cooling-off period. I don't do that debt thing. Who knew Gadget would have limited supply.
  2. Oct 11, 2017 at 2:36 PM
    #4302
    ThomasMore66
    And I added the Y-pipe with a new pulley.
  3. Oct 11, 2017 at 2:55 PM
    #4303
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am running them on my truck. My dad’s truck has the doug thorleys. The DTs sure were of better crafting quality, but overall I am happy with my JBAs. An immediate performance difference was noticed.
    reedbrynn14[QUOTED] likes this.
  4. Oct 11, 2017 at 2:57 PM
    #4304
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I know DT flanges are thick as hell............. how bout the JBA?
  5. Oct 11, 2017 at 3:02 PM
    #4305
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    They were pretty thick, i think the shop put longer studs in too.
  6. Oct 11, 2017 at 6:52 PM
    #4306
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check the N/A dyno link in my Sig.
  7. Oct 11, 2017 at 7:01 PM
    #4307
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I think the biggest difference from the Doug thorleys vs JBA is that the welds on dtlts are outside the primaries and jba are inside. So with that said beveling the primaries to fit the exhaust ports becomes an issue.
  8. Oct 11, 2017 at 7:52 PM
    #4308
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    :hattip:
    Do you see any issues running a Y pipe and TRD C/B, without headers?
    Also I'm running a stock pulley, stock airbox with AFE dry filter and BD/Magnuson tune.
  9. Oct 11, 2017 at 7:58 PM
    #4309
    reedbrynn14
    reedbrynn14 Well-Known Member
    2014 TRD Tacoma
    supercharged, icon stage 2, rock sliders, 255/85-16
    Does Thorley make a shorty header? All I see are long tubes.
  10. Oct 11, 2017 at 8:01 PM
    #4310
    rmepilot
    Rob
    Huntsville, AL
  11. Oct 11, 2017 at 8:02 PM
    #4311
    reedbrynn14
    2014 TRD Tacoma
    I recently removed the secondary filter from the inside of my stock air box. I picked up almost a pound of boost but the power under the curve is tremendously better.
    rmepilot[QUOTED] likes this.
  12. Oct 11, 2017 at 8:02 PM
    #4312
    ThomasMore66
    Hadn’t looked through @Torspd sig before. Want LT’s now and the O2 sim. The man is keeping me down with his rules. My inspector never does a visual.
    rmepilot likes this.
  13. Oct 11, 2017 at 8:05 PM
    #4313
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I first put my URD y-pipe with no supercharger.....I also had my TRD exhaust. It felt a little stronger and was definitely a little louder. I also did a AFE pro dry s CAI.
    I then did the supercharger......I then added the full 3”URD exhaust. It made it even louder but very tolerable. I feel it definitely made it run better.
    I then added my pulley and headers. Made it a little louder and again I felt improvement on what I already did.
    Adding the y-pipe eliminates the 2 rear cats which the computer doesn’t recognize and read. So eliminating them will not give you any cels.
  14. Oct 11, 2017 at 8:06 PM
    #4314
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yes...I have em
  15. Oct 11, 2017 at 8:08 PM
    #4315
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I wish I could’ve/would’ve gone the URD long tube route.....but I just didn’t want to deal with the sims and with my luck I would end up with the inspector that picks my truck as the one he actually pays total attention to.
  16. Oct 11, 2017 at 8:08 PM
    #4316
    reedbrynn14
    2014 TRD Tacoma
    Torspd likes this.
  17. Oct 11, 2017 at 8:09 PM
    #4317
    ThomasMore66
    Only live once.
  18. Oct 11, 2017 at 8:11 PM
    #4318
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Ha, true dat.....maybe at some point I’ll do it....:cool:
  19. Oct 12, 2017 at 8:31 AM
    #4319
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Ill find my 02 sim and send it to you if you want for cheap
  20. Oct 12, 2017 at 11:58 AM
    #4320
    Lastnutleft
    Lastnutleft Member
    2017 TRD OFF-ROAD
    Almost Everything the pro comes with and more!!!!!!
    Hey bud I got an 08 pre-runner lookin to add some hp already put in a air Intake and exhaust what’s next
