TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Oct 20, 2017 at 6:27 PM
    #4361
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    There is also a great write up someone did on here, step by step with pics. If you google search it, it comes up.
  2. Oct 20, 2017 at 6:33 PM
    #4362
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Thats a snowball of porting, coating, welding plates, and wallet rape i fear i may hit at some point.
    Dalandser, Torspd[QUOTED] and gersus like this.
  3. Oct 20, 2017 at 8:42 PM
    #4363
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Systemic with this forum....
    Dalandser and inwood customs like this.
  4. Oct 20, 2017 at 10:18 PM
    #4364
    inwood customs
    Dave
    And your name
    Dalandser likes this.
  5. Oct 21, 2017 at 6:34 AM
    #4365
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  6. Nov 4, 2017 at 2:48 PM
    #4366
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Question, adding a mechanical boost gauge.. Do I need to use the Tee fitting that comes with it? On the SC, the boost port is just capped off. So would a 90 degree elbow hose joiner work for the tubing?
    Or can i just run a tube directly from the boost port to the gauge? I know I should have a filter on there, but I am not going to run one.
  7. Nov 4, 2017 at 3:23 PM
    #4367
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    @12TRDTacoma are you running the stock pulley size? im thinking of doing the same.. just pulled my plugs and they look like crap.. i was running the ikh22's with the supercharger
  8. Nov 4, 2017 at 3:32 PM
    #4368
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I went directly off the port with rubber hose tubing....
  9. Nov 4, 2017 at 3:36 PM
    #4369
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
  10. Nov 4, 2017 at 3:38 PM
    #4370
    garciav
    Houston, TX
    TRD SC,HPTuners
  11. Nov 4, 2017 at 3:40 PM
    #4371
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am running the smallest pulley available outside of custom options. At the time of this post I was running a 2.85 pulley. Depending on your mods you could and should run the IKH-24 plugs.
  12. Nov 4, 2017 at 3:43 PM
    #4372
    GT7
    Grant
    Phoenix
    2013 DCLB
    I want to change my spark plugs without removing the blower, what tools do I need?
  13. Nov 4, 2017 at 4:19 PM
    #4373
    fatfurious2
    David
    Ashburn, VA
    thanks! I will do that! Just looking for confirmation
    JuanitoBonito[QUOTED] likes this.
  14. Nov 4, 2017 at 4:52 PM
    #4374
    inwood customs
    Dave
    Small hands, ratchet, plug socket, sockets for the coil packs, socket for a couple brackets, torque wrench in in lbs.
    Antisieze, about a half dozen short extensions, a long extension, swivels, and a floppy ratchet is ideal.
    Did i mention small hands?
    Because, i damn near broke mine tryin to get in thur.
    TXpro4X4 and 12TRDTacoma like this.
  15. Nov 4, 2017 at 6:01 PM
    #4375
    GT7
    Grant
    Phoenix
    2013 DCLB
    Sounds not even worth it
  16. Nov 4, 2017 at 6:02 PM
    #4376
    GT7
    Grant
    Phoenix
    2013 DCLB
    Anyone think it would be that bad to have the dealer change them? I really dont want to.
  17. Nov 4, 2017 at 6:05 PM
    #4377
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Totally worth it. If you are efficient with it, it'll take about an hour. The only one which gives a lot of trouble is the one which is furthest under the blower. The rest are fairly cake.
    Anti seize is optional. I have never been one to suggest you put them on your plugs. Besides, as rich as these trucks run with the blower tour plugs should actually be replaced every 30K or sooner. Iridium plugs or not.
    JuanitoBonito likes this.
  18. Nov 4, 2017 at 6:15 PM
    #4378
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Replace your intake with an AFe or URD true CAI. Your intake is still bottlenecking the system even though you gained more power from removing the second filter. You have more power waiting to come through.
    reedbrynn14[QUOTED] likes this.
  19. Nov 4, 2017 at 7:23 PM
    #4379
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Question about the UCON......I’m just not too familiar with it since I never really thought of getting it......I like reliability. My build is just that....or maybe I’ve just been lucky. So would adding the UCON take that away so to speak? Have there been any problems that anyone is aware off?
    My build,
    TRD S/C with TRD reflash
    AFE CAI pro dry s
    Doug Thorley shortys with vibrant high flow cats to URD y-pipe to URD Mark 3 exhaust
    2.825 URD pulley
    Walbro 2.55 fp
    Go...
  20. Nov 4, 2017 at 7:25 PM
    #4380
    GT7
    Grant
    Phoenix
    2013 DCLB
    In my opinion it doesn’t take away any reliability whatsoever.
    zerotimeouts, jojotoo and oni06 like this.
