TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 20, 2015 at 9:36 PM
    #421
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The magic words were spoken
  2. Sep 20, 2015 at 9:41 PM
    #422
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    U got another blower?
  3. Sep 20, 2015 at 9:41 PM
    #423
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The actual data of oem fuel pump with OEM filter, was posted. In non biased form. Data showing where it fails. By Lucario Runner.
    However, the topic was always so heated, by a few members, that the data was not accepted by the mods. They closed the thread and warned him not to create a new thread or ban. He posted the thread, and the few hours after when he came back to show me the thread, it was closed. No idea what happened in there, if anything at all.
    I never even got to see it myself, and lost the copy of the disk.
    The attitudes of a few ruined it for all, and the data was not allowed to be shared on the open forum. Testing to provide the data was performed in a lab. Yes, a research laboratory.
    The only other person who was told the information, was @Moose1988 , since he was the one who supplied the pump and filter.
  4. Sep 20, 2015 at 9:44 PM
    #424
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    @tcBob
    Truff?
    Factual data closed a thread and was ban worthy offense?
  5. Sep 20, 2015 at 9:49 PM
    #425
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have no need to lie. Even told Moose to go check the thread, then told him never mind, since it was deleted. Is the thread soft deleted or permanently? I have no clue.
  6. Sep 20, 2015 at 10:03 PM
    #426
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Do I smell fuel pumps tonight? They are a pretty easy install.
    Torspd likes this.
  7. Sep 21, 2015 at 3:37 AM
    #427
    ThomasMore66
    Dallas/Fort Worth & Durango
    I get the flow pressure thing. Granted, this is my first Tacoma, but I've never had a fuel pump failure on a Toyota. Doesn't the pump on our trucks run at a fixed speed to maintain pressure with a return line for excess flow?
  8. Sep 21, 2015 at 4:21 AM
    #428
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Oh yeah I forgot about those 2 nuts! I had to use one of those magnetic stick things and try to get the first couple threads started, then put a socket on it.
  9. Sep 21, 2015 at 5:07 AM
    #429
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Not directed at you Tor, to the others.
    Any chance you went my route and got the TRD SC under warranty? Why take the chance with a smaller pulley? You already spent way to much money for 27% HP gain. Why not a bit more for the pulley and a pump? You know if you don't you will never post the big mistake. I'm sure across the Tacoma Multiverse some have seen boom and never were brave enough to share the pain.
    Just do it and be safe. Smoking an engine is always a bad thing. If I ever get the smaller pulley (6.5 years for the warranty I bought) I will get the better pump. By then, Unobtainium fuel will be available.
    Torspd[QUOTED] likes this.
  10. Sep 21, 2015 at 8:54 AM
    #430
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Sep 21, 2015 at 9:24 AM
    #431
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. I did. ;) 2.55" pulley you must.
  12. Sep 21, 2015 at 10:47 AM
    #432
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    yea i saw 6 on cold mornings. now i'm regularly at 7-7.5 and dip up to 8 every so often
  13. Sep 29, 2015 at 4:51 PM
    #433
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Anyone else besides sytfu510 running a supercharger with a snorkel?
  14. Sep 29, 2015 at 4:58 PM
    #434
    ThomasMore66
    That seems like starvation, but it should be a simple area calc. No holes in my fenders.
  15. Sep 29, 2015 at 5:38 PM
    #435
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I think Homer?
    Biscuits likes this.
  16. Sep 29, 2015 at 7:05 PM
    #436
    VolcomTacoma
    Jeff
    NorCal
    I'm looking in to it. As long as you use a large enough OD piping, you're not starving anything.
    Krazie Sj likes this.
  17. Sep 30, 2015 at 12:58 PM
    #437
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It's a safari snorkel so I have no idea what how large it would need to be. And please don't ask me to maths. I can't maths very well.
  18. Sep 30, 2015 at 1:04 PM
    #438
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Airflows were tested with the s/c and pulled enough volume, only one I know of that was approved. Haven't seen ARB's numbers yet though
  19. Sep 30, 2015 at 1:52 PM
    #439
    VolcomTacoma
    Jeff
    NorCal
    Yea I was liking the airflows before they dissappeared. Hopefully the ARBs have a large OD as well to support superchargers. On the flip side, im also gonna have fiberglass fenders, so i can either just do what Alex did, or take an ARB and try to retrofit
  20. Sep 30, 2015 at 3:55 PM
    #440
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'm thinking they should be fine. The neck of the airflow is actually pretty narrow and on par with arbs.
