TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 4, 2017 at 10:29 PM
    #4381
    ThomasMore66
    Dallas/Fort Worth & Durango
    Is Ucon available again?
  2. Nov 4, 2017 at 10:33 PM
    #4382
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. Most likely.
  3. Nov 4, 2017 at 10:47 PM
    #4383
    ThomasMore66
  4. Nov 5, 2017 at 6:54 AM
    #4384
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    1. What kinds filter do i need in line to stop my manual boost gauge rattle?
  5. Nov 5, 2017 at 7:31 AM
    #4385
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do you have it on your truck??
  6. Nov 5, 2017 at 7:41 AM
    #4386
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Lol. Yes, got one of the first batch
  7. Nov 5, 2017 at 7:44 AM
    #4387
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    How do you like it? Did you see a lot of improvement coupled with the S/C?
  8. Nov 5, 2017 at 8:10 AM
    #4388
    GT7
    Grant
    Phoenix
    2013 DCLB
    If Im being honest it has been a whatever experience so far. I need an ecu that wasnt trd flashed, I need to change my plugs.
    We will see if that helps.
    It runs the truck alot better and smooth in the low rpm which is awesome, but so far it doesnt blow me away. Honestly didnt feel much of a bump in power. Hopefully with logging more data and getting a new ecu it will be awesome.
  9. Nov 5, 2017 at 8:16 AM
    #4389
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I thought it would really benefit best with the S/C with TRD reflash....so if you get a new ecu, what flash are you gonna go with ? Bully dog??
  10. Nov 5, 2017 at 8:23 AM
    #4390
    GT7
    Grant
    Phoenix
    2013 DCLB
    Let me explain, Others have got ecu’s that have NOT been flashed. Something about them makes it better for tuning w/ucon
    I will still be using the ucon, and I will never take the cam gears out of that truck so the ucon is here to stay.
    Skootter14 likes this.
  11. Nov 5, 2017 at 8:28 AM
    #4391
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Huh.....so stock ecu, blower, and UCON ...interesting.. were the cam gears a pain to install?
  12. Nov 5, 2017 at 8:50 AM
    #4392
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yes and no, me and my girlfriend did it and it took us a full day along with the thermostat. Not hard just takes alot of time and I went slow to ensure I dont fuck it up. Getting the old ones off was hard, im only ~175lb so I was struggling a bit :anonymous:
    Overall I was nervous about it big time. Turned out not to be a big deal
  13. Nov 5, 2017 at 8:53 AM
    #4393
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    ........you shoulda just changed the plugs at that time ...:boink:
    12TRDTacoma likes this.
  14. Nov 5, 2017 at 8:59 AM
    #4394
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Is the needle bouncing? Where is it tapped into?
  15. Nov 5, 2017 at 8:59 AM
    #4395
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hey. Shut up.
    My work schedule was crazy busy and I WAS EXCITED. So I put it on even though I hadnt gotten plugs. The day before I searched around locally in alberta and couldnt find any so I said fuck it and ill change them when I have more time like I do now :bananadance:
  16. Nov 5, 2017 at 9:00 AM
    #4396
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Hey man I’m just sayin.... lol
    GT7[QUOTED] likes this.
  17. Nov 5, 2017 at 9:01 AM
    #4397
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Slacker. :bananadead:
  18. Nov 5, 2017 at 9:01 AM
    #4398
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hes not wrong^
    12TRDTacoma[QUOTED] likes this.
  19. Nov 5, 2017 at 9:18 AM
    #4399
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    So the cam gears, UCON, etc.. kit from URD is compatible with the 2012-15 Tacoma’s?
    I had always thought they were for 05-11 only as URD had not listed them as a product when selecting a 2012-15 tacoma as your vehicle...
  20. Nov 5, 2017 at 9:19 AM
    #4400
    GT7
    Grant
    Phoenix
    2013 DCLB
    They are very new and have only had 2 batch’s so far I believe
