TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 5, 2017 at 11:48 AM
    #4421
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wide Fucking Open.
  2. Nov 5, 2017 at 11:59 AM
    #4422
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    What do y'all think about running some weatherstripping instead of that rubber gasket? It looks beefier than the orange piece
  3. Nov 5, 2017 at 11:59 AM
    #4423
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Not bouncing per say. It's taped directly to the boost port without a T fitting. It seems to hold whatever boost I put it at and not fluctuate. It does make a rattle noise around -0.5->+3psi though. I've tried the q-tip cotton in the tube and it seemed to help some but I've heard some individuals put an inline fuel filter. Didn't know if anyone here has had the same issue and how they fixed it.
  4. Nov 5, 2017 at 12:35 PM
    #4424
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Revelation time.
    Check your supercharger bypass valve hose. Matter of fact, just replace it with a smaller one for a tighter fit. Mine slipped right off. Thanks for tip off @Torspd
    There is also a vacuum restrictor jet. If you run any pulley smaller than stock remove it. It is located at the vacuum port of the bypass valve behind the blower. As soon as you remove the hose you'll see it. I think that jet is causing sporadic boost readings and decreasing max boost consistency. It's a little brass piece. I removed mine and am going to run it. I should net better results as a whole now that that jet is removed and the hose is actually tight fitting to the valve and supercharger.
  5. Nov 5, 2017 at 12:47 PM
    #4425
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Confirmed...
    10 psi consistent now in this 59* ish California weather at sea level.
    Change your hose or clamp it and remove the restrictor jet. It made all the difference on consistency and I am way happier now! :)
    jojotoo and JuanitoBonito like this.
  6. Nov 5, 2017 at 12:52 PM
    #4426
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Didn't even know about the restrictor jet.
    jojotoo and 12TRDTacoma like this.
  7. Nov 5, 2017 at 12:57 PM
    #4427
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I kinda know where....but not exactly, can you put some pics up??
    inwood customs and mightytacoman like this.
  8. Nov 5, 2017 at 1:17 PM
    #4428
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Also, I think this little booger was the culprit for my cels, p0420/p0430. Once I tightened the hose .. cels have not returned. They should have by now.
    All this time I thought it was an exhaust leak ..
    4 trips to the muffler shop
    2 trips to the dealership
    3 trips to my buddys shop
    Re-tightened / re-checked the whole exhaust numerous times.
    Hopefully, my assessment isnt premature. Will update after few more day.
    Biscuits and Torspd[QUOTED] like this.
  9. Nov 5, 2017 at 1:20 PM
    #4429
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Yes sir, I have to check those. I have had quite much ”turbo lag” nowadays although I have the supercharger, not turbocharger.
    I’d like to get rid of it, this might be the reason.
    GT7 and jojotoo like this.
  10. Nov 5, 2017 at 2:13 PM
    #4430
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It seriously made all the difference. Boost hits 10 now where as before it would not. The boost is much more consistent now also.
    As an added bonus vacuum also spikes higher now into 25 in. Hg. When decelerating so the blower is sealing up better now. Vacuum at idle is better now also. I'm not sure if the smaller ID hose did that or removing the jet did or both but I'll take it. :)
    I've been trying to, do you not know where the bypass valve is located at behind the blower? You have to remove the hose to see it. All I managed to snap a pic of was the jet itself, not it inside of the valve.
    It appears that some of that "turbo lag" at 2000 rpm until 3000 rpm went away after doing these mods. :)
    jojotoo likes this.
  11. Nov 5, 2017 at 2:28 PM
    #4431
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I know it’s back there somewhere......I didn’t do my install, I guess I can look at my instructions . So you took the hose off,.... took off that restrictor, then put the hose back on??
  12. Nov 5, 2017 at 2:32 PM
    #4432
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I replaced the hose with a smaller ID hose because the one originally in place is too large and can be a source of boost and vacuum leaks. The site is not letting me upload the pics for some reason. I removed the hose, removed the restrictor with a small set of pliers, then replaced the hose with a smaller ID hose and that was it. :)
    JuanitoBonito[QUOTED] likes this.
  13. Nov 5, 2017 at 2:36 PM
    #4433
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Makes me wonder about afr.
    I know partial throttle can put boost around 5psi sometimes and still have afr around 13. Ive always had to babysit this on grades. Ill throw it into a lower gear (auto), and pull a higher rpm which seems like less load dependent on the grade. Since boost is load dependent, this means im not making boost at that moment if the right gear was found.
    That said, i can always mash the pedal in that lower gear and make boost with safer afr.
    Its the partial throttle i worry about.
  14. Nov 5, 2017 at 2:42 PM
    #4434
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have not monitored part throttle with it removed, however, this is a mod that was done by Tundra owners because they felt that their belt was slipping when it was actually was not, it was the jet and they never had issues with partial throttle applications. I would imagine their TRD tunes are put rich like ours are.
    Then again partial throttle and AFR is going to be dictated by pulley size and how rich you normally go during partial throttle.
  15. Nov 5, 2017 at 2:45 PM
    #4435
    ThomasMore66
    Dallas/Fort Worth & Durango
    In the same boat. Looking at it now.
  16. Nov 5, 2017 at 2:48 PM
    #4436
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay, apparently Magnuson knows about the mod people are doing as far as removing it or modifying the orfice size goes. They have said you are fine removing it as long as you don't mind a very slight decrease in MPG. Personally speaking I did not notice the boost coming on any quicker and the engine is still just as streetable as it was before I removed it, so if I'm good with a 2.5 pulley the rest of you will be as well.
    This is a well known mod within the roots blower owners community, Grand Prix, GTO, Vette, Mustang, Lightning, Challenger (etc.) Owners know all about it apparently. Many just remove it because the the restrictor is meant to slow down the valve from working and many do not like that, but the drawback as well is that it actually limits boost and makes it less consistent. No brainer free mod.
    Torspd likes this.
  17. Nov 5, 2017 at 2:51 PM
    #4437
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here are pics of the restrictor orfice jet I removed. It is at the top of the vacuum port. Brass color as you can see. @JuanitoBunito [​IMG]
    Biscuits and JuanitoBonito like this.
  18. Nov 5, 2017 at 3:03 PM
    #4438
    ThomasMore66
    Passenger side by the firewall under these wires. Conveniently located. My hose is tight.
  19. Nov 5, 2017 at 3:04 PM
    #4439
    ThomasMore66
    Vac line comes from my air intake
  20. Nov 5, 2017 at 3:05 PM
    #4440
    ThomasMore66
    How did you get it out?
