TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 6, 2017 at 11:28 AM
    #4521
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Man cmon Im not that dumb :thumbsup:
    I got that little fucker out, put the hose back on and went for a test drive!
    2.85 pulley
    12TRDTacoma[QUOTED] likes this.
  2. Nov 6, 2017 at 11:28 AM
    #4522
    GT7
    Grant
    Phoenix
    2013 DCLB
    Not on mondays :)
  3. Nov 6, 2017 at 11:30 AM
    #4523
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    smoke break out by your truck? and "check your oil" while you're out there
    Torspd and 12TRDTacoma like this.
  4. Nov 6, 2017 at 11:42 AM
    #4524
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have the factory intake still? It is a major bottleneck in the system even with the secondary filter removed.
    I am at work, but I'm slacking. ;)
    Good stuff man!
    2.85 pulley at sea level ran 8.5 psi on my setup max. Normally I saw 7- 7.5 psi max effort, very rarely did I see 8.5, I believe a lot of that was attributed to this stupid jet which is no longer a player in the game.
    If you are seeing 5, you either have other vacuum leaks, or you are above sea level. What is your altitude, and have you checked the rest of the system to ensure it is sealed?
  5. Nov 6, 2017 at 11:44 AM
    #4525
    GT7
    Grant
    Phoenix
    2013 DCLB
    Afe intake.
    1500 ft or so in phx but i saw the same boost in flagstaff and Calgary which are much higher.
    I have looked for vacuum leaks but have found none, just yesterday every vac line I could find was checked on both ends
  6. Nov 6, 2017 at 11:52 AM
    #4526
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes but remember you still had the restrictor jet in during thst time, so boost was all over the damn place anyways. At 1500 feet the jury is out how much boost you will lose. Keep driving it and see if your consistent will be 5.5. It is too soon to say if that will be your consistent or not.
    Wait. What sort of fuel pump do you have. Also how is your fuel pressure regulator set up?
  7. Nov 6, 2017 at 11:56 AM
    #4527
    GT7
    Grant
    Phoenix
    2013 DCLB
    I have never understood the fpr thing. So its however it is stock, I also don’t understand the mechanics of it.
    Walbro 255 or the other 255 I forget
  8. Nov 6, 2017 at 11:58 AM
    #4528
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I did the fpr mod a few times.
    Things got richer (not needed)
    Wasted more fuel.
    Undid it, truck ran fine, less fuel used, not as rich afr.
    Also no effect on the stupid lean issue when at partial throttle and creating boost.
    Ymmv
  9. Nov 6, 2017 at 11:59 AM
    #4529
    GT7
    Grant
    Phoenix
    2013 DCLB
    It should be noted my afr gauge hasnt worked in quite awhile, bosch sensors suck, I am going to replace it asap.
  10. Nov 6, 2017 at 11:59 AM
    #4530
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Boost referencing. Google that term. Now, as far as boost goes, fuel is a major gamer in the setup and it is very important that the proper fuel volume be mixed with boost or else it WILL limit you boost. It limited me from hitting 10 for sure with my 2.5 pulley. Move your fuel pressure regulator hose to your boost port. You will feel a noticeable difference in take off alone and it should further regulate the amount of boost you are capable of consistently reaching.
  11. Nov 6, 2017 at 12:00 PM
    #4531
    inwood customs
    Dave
    The truck FELT sluggish with the fpr mod done (routed from boost port to fpr). Kinda makes sense as richer afr.... butt dyno tho
  12. Nov 6, 2017 at 12:08 PM
    #4532
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah but remember he has Ucon, and he is also at a higher elvation, so not only is he leaner, but he also has the ability to compensate for such changes in fueling and elevation changes.
    My truck personally woke up like a raped ape.
  13. Nov 6, 2017 at 12:08 PM
    #4533
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I played Hooky today... soooo :anonymous:
    After removing the jet I gained .5-1lb of boost.
    Tested my Bypass valve and no change, so that checks out OK.
    Disconnected the Snorkel and tested, no change, just more CFM's/better response (which is always good obviously, may change it up depending on driving scenario), so that checks out OK
    Still showing 6, flashes of 7 lbs. I checked vacuum leaks a few months ago with a smoke test machine. found one, sealed it.. but it could be back.. :notsure:
    Last thing to check (which I have in the past, just need to do it again) is to replace the belts (shorter and Gates)
    One more thing to go with the above.. is a new custom tensioner (since I've broken two now). There's a company I reached out to that said they would be willing to work with me on something. just need to provide them with the appropriate info and parts .. just gonna be $$$..
    I have a new Coupler sitting on my workbench too.. I believe mine is going out (symptoms are "sounds like rocks in the blower during idle/low speeds"). Need to swap that in.. At that time I will inspect the bearings and rotors themselves.. as at that point.. that will be all that's left. My worry is the ceramic coating on the rotors is shot/needs an internal rebuild.
    Truck has:
    Airflow Snorkel
    K&N oiled filter
    TRD blower
    2.85" pulley
    Deatschwerks 255 Pump
    URD Spec U headers
    URD o2 sims
    IPT Valve Body
    3" exhaust
    Nitro 4.56's
    shows a max of 7lbs. (after all the above tests... this 7lbs has been the best it has been in a long time). It normal shows 6lbs though... Just flashes 7.
  14. Nov 6, 2017 at 12:10 PM
    #4534
    inwood customs
    Dave
    Thatz why i put ymmv.
    I fingered others may find it beneficial, but its not for everyone.
    I was fine at 7,000 ft without it done and making 7lbs iirc.
  15. Nov 6, 2017 at 12:11 PM
    #4535
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ok as I said I dont know specifically which hose and specifically where I should put it.
    Do you mean boost port on top of the sc? If that even is one
    dbs1 and 12TRDTacoma[QUOTED] like this.
  16. Nov 6, 2017 at 12:12 PM
    #4536
    inwood customs
    Dave
    Yes, its on the top left side... towardz the rear.
    Orange rubber cap unless you have taken it off for anything
    Route the line from fuel pressure reg to this, and disconnect/cap the small line going from your intake to the fuel pressure regulator
    12TRDTacoma likes this.
  17. Nov 6, 2017 at 12:14 PM
    #4537
    GT7
    Grant
    Phoenix
    2013 DCLB
    I dont have an orange cap nor have I ever seen one.
    Thats sounds like a problem
  18. Nov 6, 2017 at 12:16 PM
    #4538
    GT7
    Grant
    Phoenix
    2013 DCLB
    Are we referring to this?
  19. Nov 6, 2017 at 12:17 PM
    #4539
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Boost port has an orange cap on it as previously stated on back at the top of the supercharger. So your fuel pressure regulator has a hose that runs to a port on the intake air cleaner. Remove the hose at the intake air cleaner end and relocate that to the boost port end. FPR is now being boost referenced to supply the injectors the necessary fuel volume needed when boost is introduced at 1:1 ratio.
  20. Nov 6, 2017 at 12:17 PM
    #4540
    inwood customs
    Dave
    Further back
