TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 6, 2017 at 3:14 PM
    #4621
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Quick romp showed i went from 10s and 11s afr, to 11.5 to 12s?
  2. Nov 6, 2017 at 3:16 PM
    #4622
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup. :burnrubber:
  3. Nov 6, 2017 at 3:17 PM
    #4623
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do the FPR mod. The stock pump can barely handle the motor in NA configuration let alone the supercharger with a 6 psi 3.0 pulley.
    What...?
    Did you do a mod or something? If so, which one did you do? What is important is AFR at initial hit and regulation over time after the hit but still while buried to the floor.
  4. Nov 6, 2017 at 3:26 PM
    #4624
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Well glad I looked into this thread. Looks like I need to grab some hose clamps and pull that little jet thingy out tomorrow and see what happens
    12TRDTacoma likes this.
  5. Nov 6, 2017 at 3:43 PM
    #4625
    12TRDTacoma
    Rob
    Concordia
    Boosted
    And replace your hose preferably.
    Not like... your hose, because you can't do that, but the hose on your supercharger to your bypass valve. :D
  6. Nov 6, 2017 at 3:49 PM
    #4626
    inwood customs
    Dave
    Did the jet removal.... was hitting 11.5 and 12:1
    Boost referenced it, and back down to 10.5:1 wot
    Hmmmmmmm
  7. Nov 6, 2017 at 3:52 PM
    #4627
    inwood customs
    Dave
    Ill give it a day or 2 and finger out what to do.
    10.5 is crazy
  8. Nov 6, 2017 at 3:57 PM
    #4628
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have a UCON or are you using the TRD tune?
  9. Nov 6, 2017 at 4:02 PM
    #4629
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It is an itp. Still needed to be installed. Did it in a garage.
  10. Nov 6, 2017 at 4:02 PM
    #4630
    ThomasMore66
    Dallas/Fort Worth & Durango
    No coolant drips under the truck in the parking garage tonight!
    Torspd and JuanitoBonito like this.
  11. Nov 6, 2017 at 4:23 PM
    #4631
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    IPT*
    XPOTRPR[QUOTED] likes this.
  12. Nov 6, 2017 at 4:23 PM
    #4632
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    just tee the fpr hose to the boost port? and cap the one on my intake?
  13. Nov 6, 2017 at 4:24 PM
    #4633
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you see the video?
    inwood customs and 12TRDTacoma like this.
  14. Nov 6, 2017 at 4:49 PM
    #4634
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    How are you guys getting to your bypass valve? If it is where I think it is, its like center of engine bay all the way behind the blower. Are you taking the blower or bypass off somehow? My short arms can barely reach in there lol.
  15. Nov 6, 2017 at 4:49 PM
    #4635
    Blacktaco2042
    wisconsin
    yea just when back found it. just did that and the jet mod but wont be driving the truck for a few days as i have it torn apart to fix the light bar. ill have to see what the butt dyno thinks later
  16. Nov 6, 2017 at 4:54 PM
    #4636
    Blacktaco2042
    wisconsin
    I used a lil vise grip. It's kinda hard to get out. Is the boost reference gonna make me use more gas?
  17. Nov 6, 2017 at 4:58 PM
    #4637
    inwood customs
    Dave
    srry, been busy.
    turd tune
  18. Nov 6, 2017 at 4:58 PM
    #4638
    inwood customs
    Dave
    yes
  19. Nov 6, 2017 at 4:59 PM
    #4639
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Some would say yes but I have been getting the same shit gas mileage both before and after the mod so I am going to say no, unless you just floor it everywhere you go all the time. Lol. You only use boost 5% of the time. The other 95% is spent in vacuum.
  20. Nov 6, 2017 at 4:59 PM
    #4640
    inwood customs
    Dave
    hands wouldnt fit well........... I had to borrow some extra long needle nose pliers to get the jet out.
    as for the hose, I closed my eyes, twisted to break any seal and pulled.
    Murphinator[QUOTED] likes this.
