TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 6, 2017 at 4:59 PM
    #4641
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What pulley you running?
  2. Nov 6, 2017 at 5:01 PM
    #4642
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    2.85 stealth
    long tubes
    urd ypipe
    urd mk2 exhaust (switched mufflers, but still 3")
    afe stage 2si
    walbro 255
  3. Nov 6, 2017 at 5:02 PM
    #4643
    inwood customs
    Dave
    im not gunna get a smaller pulley. I dont wanna meth/7th uconn mapecu3
    Im hearing about an adjustable fpr tho...... theres this birdy in my ear
    12TRDTacoma and Torspd like this.
  4. Nov 6, 2017 at 5:11 PM
    #4644
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    Ok. I'll drive it next week and see what I think. I get like 15ish. 3 inch lift and tires doesn't help lol
  5. Nov 6, 2017 at 5:12 PM
    #4645
    ThomasMore66
    Dallas/Fort Worth & Durango
    6AE78BB4-1042-4304-B7B1-D948DE0D6C32.jpg Not much chance to play on the way home...
    inwood customs likes this.
  6. Nov 6, 2017 at 5:21 PM
    #4646
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spaghetti bowl! :annoyed:
  7. Nov 6, 2017 at 5:26 PM
    #4647
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah well I get 10.5-10.8 WOT run with my 2.5 pulley. AEM 320 green fuel pump, urd true cold air intake, valve body upgrade, modded Y pipe, aero turbine exhaust and fpr mod... I'm fairly happy. Power levels are ridiculous and shifting is beautifully firm.
  8. Nov 6, 2017 at 5:27 PM
    #4648
    inwood customs
    Dave
    so much room for more powa
  9. Nov 6, 2017 at 5:29 PM
    #4649
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Esplain youself. What else you got for more power? A 7th injector? Long tubes?
    I forgot to mention I have a 1 gallon coolant reservoir and my blower water pump is upgraded to pump 1.10 gallons over the stock one.
  10. Nov 6, 2017 at 5:30 PM
    #4650
    inwood customs
    Dave
    not me, you
    so rich
  11. Nov 6, 2017 at 5:33 PM
    #4651
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes it is rich. I agree. I can clean it up at least 1 more point. 11.5- 11.8 woul d be great. Blower spins at 16,800 RPM with the current pulley. I can spin it 1,200 rpm faster before I hit it's max RPM before inefficiency ceiling.
  12. Nov 6, 2017 at 5:34 PM
    #4652
    inwood customs
    Dave
    u should rig post boost temp sensor, im curious how much heat is produced
    12TRDTacoma[QUOTED] likes this.
  13. Nov 6, 2017 at 5:38 PM
    #4653
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That would be interesting. I'd have to find a place to tap into it though.
    Remember, these Gen 5 blowers make more power off less boost compared to it's gen 3 and 4 predecessors. Statement from Eaton says these blowers are capable up to 18,000 RPM before they start losing efficiency. Which means you can spin it at 17,8xx 17,9xx all day long and it will still be efficient.
  14. Nov 6, 2017 at 5:47 PM
    #4654
    inwood customs
    Dave
    eatons website was a snap to figure out about 1-2yrs ago, but its a PITA and I dont see any figures for the mp90 (5th gen) anymore.
    How did those 18,000 rpm claims come up?
    not to argue, simply curious as I cant find shit from eaton anymore
  15. Nov 6, 2017 at 5:48 PM
    #4655
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Ladder or grow
    Torspd and 12TRDTacoma like this.
  16. Nov 6, 2017 at 5:49 PM
    #4656
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Used a step ladder from driver side ..
    12TRDTacoma and Murphinator like this.
  17. Nov 6, 2017 at 5:51 PM
    #4657
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The info is actually still there. It is titled differently is all if I remember correctly. How else have I found all my info? Definitely not on here. :D
    SERIOUS homework and determination to find said info.
  18. Nov 6, 2017 at 5:52 PM
    #4658
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I will use a step stool and need something to hold the damn hood up higher
    jojotoo likes this.
  19. Nov 6, 2017 at 5:52 PM
    #4659
    inwood customs
    Dave
    meh I did just that long ago.
    let us know when you find your links to the new pages.
  20. Nov 6, 2017 at 5:53 PM
    #4660
    inwood customs
    Dave
    maybe someone to keep the stepstool from flying out from under ya too
    Murphinator[QUOTED] and jojotoo like this.
