TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 9, 2017 at 5:35 AM
    #4921
    ThomasMore66
    Dallas/Fort Worth & Durango
    See?! It’s the answer! Glory lasts forever.
    JuanitoBonito[QUOTED] likes this.
  2. Nov 9, 2017 at 5:48 AM
    #4922
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Your enthusiasm is refreshing. :D
    12TRDTacoma and GT7 like this.
  3. Nov 9, 2017 at 5:53 AM
    #4923
    Aw9d
    Aw9d That one guy
    Whenever you want to try it let's do it.
    GT7 likes this.
  4. Nov 9, 2017 at 5:54 AM
    #4924
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    If y’all are trying it I gotta be there to see it
    Aw9d[QUOTED] likes this.
  5. Nov 9, 2017 at 5:57 AM
    #4925
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  6. Nov 9, 2017 at 6:00 AM
    #4926
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Enthusiasm/ sarcasm/ shit talking, whatever you need I got you covered
    JuanitoBonito, 12TRDTacoma and GT7 like this.
  7. Nov 9, 2017 at 6:01 AM
    #4927
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fist bump
  8. Nov 9, 2017 at 6:46 AM
    #4928
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    wait are you saying you are using like the torque app for your boost gauge? I checked mine and I could pull 10 psi when I was N/A just sayin
    jojotoo, 12TRDTacoma and GT7 like this.
  9. Nov 9, 2017 at 6:51 AM
    #4929
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bumpy you say?! Bumpy is my speciality. ;) Game on.
  10. Nov 9, 2017 at 7:04 AM
    #4930
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Something similar to that. Actually messed around with it and realized I had the gauge maxed at 18.5, bumped that to 50 and added the calculated hp gauge. I'm pushing 38psi at 450hp right now apparently on stock internals. Damn these Toyota motors are good.
    Must be because I am at higher elevation ~7000' The air is thinner up here making it more compressible, thus allowing the s/c to force more air molecules into the engine creating much more boost. The fueling system sees this added air and dumps more fuel in, and bam!!! 38psi and 450hp
    I know y'all are :jellydance:
    jojotoo likes this.
  11. Nov 9, 2017 at 7:05 AM
    #4931
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  12. Nov 9, 2017 at 7:06 AM
    #4932
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  13. Nov 9, 2017 at 7:06 AM
    #4933
    GT7
    Grant
    Phoenix
    2013 DCLB
    Thanks for the laugh, Im dying
  14. Nov 9, 2017 at 7:06 AM
    #4934
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Let's do it!!!! You're in CA I'm in AZ, I'm sure we could find a common ground in the middle somewhere
  15. Nov 9, 2017 at 7:07 AM
    #4935
    12TRDTacoma
    Rob
    Concordia
    Boosted
    After I cage my engine... if I keep playing the way I have in the past the radiator will go and fall right out of the truck. I think you've seen my rad support in the past.
  16. Nov 9, 2017 at 7:09 AM
    #4936
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Helps that I know enough to make a very convincing and completely bs argument that someone could read and might actually believe. Just got to say it with confidence and make it seem logical
  17. Nov 9, 2017 at 7:09 AM
    #4937
    GT7
    Grant
    Phoenix
    2013 DCLB
    Fake it til u make it
    snowsk8air2[QUOTED] likes this.
  18. Nov 9, 2017 at 7:10 AM
    #4938
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I need to start gusseting and beefing up some stuff now that I'm LT if I want to play hard and not bend or break stuff. So spring of 2020? Should give us time to get our shit together for the showdown
  19. Nov 9, 2017 at 7:13 AM
    #4939
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :D hahaha. Yeah something like that. If I can get a beater to drive around in so a fabricator can keep my truck for a week or two.
    I'll be disappointed the entire time because no boozt.
  20. Nov 9, 2017 at 7:22 AM
    #4940
    ThomasMore66
    Nope. You can't start back peddling now!
    I'm so excited. This tread hasn't seen this much activity in years. What have you guys been doing? We've been here, loyal to the cause keeping the flame alive and it was all quiet.
    Torspd, Murphinator and JuanitoBonito like this.
