TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 9, 2017 at 4:44 PM
    #4961
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Time for a valve body upgrade. I had the symptoms you did at about 50K until about 70K when I did the valve body upgrade. Symptoms are all gone and 4th to 5th shift beautifully now. In boost or not.
    I did post this in the mods tips and tricks thread though. Almost verbatim. Shame shame @Murphinator
    Murphinator[QUOTED] likes this.
  2. Nov 9, 2017 at 4:47 PM
    #4962
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I thought so but was not sure. Just need to find a shop who can do it and not fck it up. I don’t want to attempt it all the springs and what not in there I would probably lose one lol. I can’t believe how cheap it is for the ratiotek one. Thats probably the one I will go with.
    Also huge props to you for that thread, it is great to have all the information in one place!
  3. Nov 9, 2017 at 4:49 PM
    #4963
    ThomasMore66
    Dallas/Fort Worth & Durango
    All the time if I’m on it and then back off once I’m up to speed. Think on-ramp or merging. I shift manually 4-5 a lot.
  4. Nov 9, 2017 at 5:04 PM
    #4964
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you want to get it done for cheaper, buy a valve body on Amazon. Buy the RatioTek kit and I can install the shift kit for you then send it back to you. All you have to do is remove and replace at that point.
    It'll still flare. I shift manually also. Even now. Lol.
  5. Nov 10, 2017 at 7:03 AM
    #4965
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Do you know how I can find out what exact valve body I need? I see like 3 different versions on Amazon
  6. Nov 10, 2017 at 7:05 AM
    #4966
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes I do. I just went through this with @GT7 Last night. I am going to modify a valve body for him. He said he would give you his valve body for $100 If you wanted me or a shop to modify that one.
  7. Nov 10, 2017 at 7:05 AM
    #4967
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    It has 39k miles
  8. Nov 10, 2017 at 7:38 AM
    #4968
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Ok cool, I just ordered the valvebody kit on Amazon right now. How hard would it be to just swap the valve bodies, relatively easy? Send me a PM on how much you want for doing this please!
  9. Nov 10, 2017 at 7:42 AM
    #4969
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll send you more info right now. :thumbsup:
  10. Nov 10, 2017 at 10:32 AM
    #4970
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Just calculated best fuel economy for a long time, 18.6 MPG after the monday evening jet mod. I also adjusted the spark timing too about week ago, might be most of that.
    12TRDTacoma[QUOTED] likes this.
  11. Nov 10, 2017 at 10:43 AM
    #4971
    GT7
    Grant
    Phoenix
    2013 DCLB
    Damnnnnn son! Nice
  12. Nov 10, 2017 at 11:28 AM
    #4972
    GT7
    Grant
    Phoenix
    2013 DCLB
    PSA
    Get a new fuel strainer before you start your pump install!
  13. Nov 10, 2017 at 11:38 AM
    #4973
    12TRDTacoma
    Rob
    Concordia
    Boosted
    GT7[QUOTED] likes this.
  14. Nov 10, 2017 at 11:47 AM
    #4974
    GT7
    Grant
    Phoenix
    2013 DCLB
    As someone who has never really messed with the fuel system I was totally unaware.
    Skootter14 likes this.
  15. Nov 10, 2017 at 5:27 PM
    #4975
    GT7
    Grant
    Phoenix
    2013 DCLB
    Well 320 aem is fully installed and ill be getting the bed back on tomorrow.
    I hate fuel pumps now. Couldnt have done it without @12TRDTacoma helping me with some tricky (at least to me) parts.
    12TRDTacoma, yota243 and Torspd like this.
  16. Nov 10, 2017 at 5:30 PM
    #4976
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I got this going on in a few days (Walbro 255 going in) what are all the trouble spots haha?!?!?
    I was thinking about just dropping the tank (i have access to a full lift and xmsn jack). I couldnt tell is raising the bed (with the light wires and everything) was going to be harder in the end (timewise) than just dropping the tank. Whatcha think?
  17. Nov 10, 2017 at 5:33 PM
    #4977
    ThomasMore66
    Not sure if you two should hang out together...
    JuanitoBonito and GT7[QUOTED] like this.
  18. Nov 10, 2017 at 5:34 PM
    #4978
    GT7
    Grant
    Phoenix
    2013 DCLB
    I undid the bed, with me and two others, lifted it and put about 6” of wood between the frame and bed. Not too bad to get the pump assembly in and out.
    Looking back if I had a full lift i might drop the tank. The hard part was just getting the pump to play nice with the housing. I drilled alot of white plastic off lets just say that.
  19. Nov 10, 2017 at 5:35 PM
    #4979
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just trying to give recognition where its due.
  20. Nov 10, 2017 at 5:35 PM
    #4980
    Skootter14
    Jeremy
    able to snag any pics? I did the URD pump upgrade kit and kinda curious how easy modifiying the white housing is going to be with the walbro pump...
