TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 10, 2017 at 5:37 PM
    #4981
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    So I had that pump in and just took it out, seems like if you follow the instructions you will be good, its really not that horrible its just my first time with this and I had a learning curve
  2. Nov 10, 2017 at 5:40 PM
    #4982
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    gotcha :thumbsup: Thats reassuring..unless youre just BSin me haha. I read through the install instructions from start to finish once. Didn't seem too bad...but nothing ever goes as smooth as reading the instructions haha. Glad ya got it taken care of!
    EDIT: are you removing the pump due to issues with it??? Talking to Gadget, that pump would be sufficient for the S/C. . .
  3. Nov 10, 2017 at 5:44 PM
    #4983
    GT7
    Grant
    Phoenix
    2013 DCLB
    I did have issues
    But after removing it the pump seems totally fine. My fuel line was jacked up from the shop that installed it put on the hose clamps way too tight and it destroyed the line over time
    Torspd likes this.
  4. Nov 10, 2017 at 5:47 PM
    #4984
    ThomasMore66
    Dallas/Fort Worth & Durango
    But maybe you’ll talk each other into a little spray...
    JuanitoBonito and GT7[QUOTED] like this.
  5. Nov 10, 2017 at 5:49 PM
    #4985
    GT7
    Grant
    Phoenix
    2013 DCLB
    Thomas. No. Bad. I can only afford to have one vehicle and its payed off. I cant go too far you nut :burnrubber:
  6. Nov 10, 2017 at 5:58 PM
    #4986
    ThomasMore66
    I’ll buy the spray...
    JuanitoBonito likes this.
  7. Nov 10, 2017 at 5:59 PM
    #4987
    GT7
    Grant
    Phoenix
    2013 DCLB
    And put it on your truck....
    Why are you so interested in spray
  8. Nov 10, 2017 at 6:09 PM
    #4988
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Shit people......I fly in to watch !!!!
  9. Nov 10, 2017 at 6:13 PM
    #4989
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Watch mine pull like a supercharged truck? C'mon down!!! :plane:
  10. Nov 10, 2017 at 6:25 PM
    #4990
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Has this fixed your trouble codes, and assumed UCON issues?
    Just to be informative, IF you (plural) have the program, then you could do a datalog. Looking at the fuel adaptives, you could see how close they are to 12% demand out, from what they should be. Which means you have some sort of fueling issue. I think past 12% the guardian kicks in.
  11. Nov 10, 2017 at 6:31 PM
    #4991
    GT7
    Grant
    Phoenix
    2013 DCLB
    I have been having regular gaurdian interventions. This should fix that. My P219A is just from my trd flashed ecu I believe. I will update tomorrow when the bed is back on and I can do a data log
    Torspd[QUOTED] likes this.
  12. Nov 10, 2017 at 6:37 PM
    #4992
    GT7
    Grant
    Phoenix
    2013 DCLB
    Also was having random misfire code, but I changed plugs yesterday. We will see what happens in the coming days
  13. Nov 10, 2017 at 6:54 PM
    #4993
    Skootter14
    Jeremy
    sucks they messed up your line, but glad to hear it doesn't sound like the pump was the culprit.
    GT7[QUOTED] likes this.
  14. Nov 10, 2017 at 7:02 PM
    #4994
    ThomasMore66
    See, that’s what I’m about. Bringing people together. Pulley Man and GT7 changin’ fuel pumps. We’re a community.
  15. Nov 10, 2017 at 7:06 PM
    #4995
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :drunk:
    12TRDTacoma and GT7 like this.
  16. Nov 10, 2017 at 7:08 PM
    #4996
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Bet your truck is going to run really well after this.
    Fuel pump line split, is the most common problem associated with the upgrade, and rears its head months later. Taken many a truck out of service.
  17. Nov 10, 2017 at 7:36 PM
    #4997
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im worried about months later from now because I was extremely careful but im a shit mechanic when it comes to fuel pumps
    @ThomasMore66 one day we all gotta link up and do some drags
    Id drive far to do that
  18. Nov 10, 2017 at 8:12 PM
    #4998
    ThomasMore66
    You, little man, need to get that turbo back on that stroker motor and show us what you’ve got. It’s been long enough.
    GT7 and JuanitoBonito like this.
  19. Nov 10, 2017 at 8:14 PM
    #4999
    ThomasMore66
    I might have to put a cage on something...
  20. Nov 10, 2017 at 8:26 PM
    #5000
    GT7
    Grant
    Phoenix
    2013 DCLB
    This is true @Torspd get that badass mofo going!
