TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 27, 2017 at 12:17 PM
    #5061
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    For the boost referenced fuel rail mod. Has anyone tried it that runs a fuel pressure gauge to confirm it works? Seems to me and feel free to correct if im wrong- say you're at 10psi boost, the fuel pump is gonna either back off to maintain the pressure it likes (44psi IIRC) or it's gonna be working harder to pump at the new psi of 54psi and adding extra wear to it. Someone enlighten me.
    GT7 likes this.
  2. Nov 27, 2017 at 1:43 PM
    #5062
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In vacuum it will reduce fuel pressure, and in boost it will raise the fuel pressure 1 PSI per pound of boost.
    12TRDTacoma and inwood customs like this.
  3. Nov 27, 2017 at 8:05 PM
    #5063
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    I still think it’s working fine.
  4. Nov 27, 2017 at 8:06 PM
    #5064
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    does the wideband going from 11s and 12s at WOT down to (10:1 when referenced) or even richer count?
  5. Nov 27, 2017 at 8:10 PM
    #5065
    ThomasMore66
    Mine dips on tip in and then levels out just like it always did. I kinda thought it pinged when the jet was in there. For sure there was a bit of lag.
  6. Nov 27, 2017 at 8:18 PM
    #5066
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    How can you hear ping? I always try to listen but can never hear anything
  7. Nov 27, 2017 at 8:37 PM
    #5067
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    This^^^ between intake, s/c, tires, and wind noise, even if I turn the stereo off, there's no way in hell I'd be able to hear a little bit of pinging. And I really know what to listen for. My truck is safe to drive or not scale is based on OBD calculated afr's, catastrophic sounding sounds, seat of the pants feel, and 6 years of motorcycle related performance work.
  8. Nov 27, 2017 at 8:39 PM
    #5068
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yeah shit is loud as hell, I tried a couple times and gave up
  9. Nov 27, 2017 at 8:40 PM
    #5069
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Same. Put s keen ear to the window/ engine after someone was complaining about pinging from removing the brass jet last week or whenever it was
    inwood customs and GT7[QUOTED] like this.
  10. Nov 27, 2017 at 10:54 PM
    #5070
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That someone was me. It was there without the jet, and has gone away since reinstalling it. I have a set of those keen ears you speak of. :thumbsup:
  11. Nov 28, 2017 at 9:10 AM
    #5071
    Vertical_Taco_74
    Vertical_Taco_74 New Member
    Hi everbody. I'm looking into buying a Certified 2011 Tacoma TRD with the SC from a local dealer where it was initally sold. It has less than 28K and they are asking 27.9 for it. Anything that I should be wary of?[​IMG]
    jojotoo likes this.
  12. Nov 28, 2017 at 9:12 AM
    #5072
    GT7
    Grant
    Phoenix
    2013 DCLB
    Price sounds high. 4wd?
  13. Nov 28, 2017 at 9:18 AM
    #5073
    Vertical_Taco_74
    Yes. 4X and Crew Cab. I'm going to work on them on the price a bit. Could have potential for a fun project.
  14. Nov 28, 2017 at 9:49 AM
    #5074
    ThomasMore66
    Low miles.
  15. Nov 28, 2017 at 10:24 AM
    #5075
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Low boost
    TRON and loginfailed like this.
  16. Nov 28, 2017 at 11:30 AM
    #5076
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Just like mine too... I was/am trying to sell mine for $28k but has 65k miles. TRD supercharger with long travel suspension and lots of other goodies.
  17. Nov 28, 2017 at 11:46 AM
    #5077
    GT7
    Grant
    Phoenix
    2013 DCLB
    Part out....... :boink::D
  18. Nov 28, 2017 at 11:53 AM
    #5078
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What grade steel is the supercharger casting made of?
  19. Nov 28, 2017 at 11:55 AM
    #5079
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Aluminum grade.
  20. Nov 28, 2017 at 12:03 PM
    #5080
    TireFire
    Olympic Peninsula
    Are you sure? Somebody told me steel but wasn't sure if it was mild steel or something else
