TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 28, 2017 at 12:04 PM
    #5081
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Needs moar boost.
  2. Nov 28, 2017 at 12:08 PM
    #5082
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :rofl:
  3. Nov 28, 2017 at 12:09 PM
    #5083
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. Every percent
    loginfailed likes this.
  4. Nov 28, 2017 at 12:27 PM
    #5084
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What? I'm confused... you mean it is aluminum in the housing and plenum and all?
  5. Nov 28, 2017 at 12:43 PM
    #5085
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The entire housing is aluminum, the rotors, gears, main shaft, etc are all steel.
    TireFire[QUOTED] likes this.
  6. Nov 28, 2017 at 12:52 PM
    #5086
    TireFire
    Olympic Peninsula
    Thanks
  7. Nov 28, 2017 at 2:59 PM
    #5087
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I got my tacoma...2011....in Aug/Sep 2010. Brand new, for like 29,7...even with S/C, that seems high
  8. Nov 28, 2017 at 2:59 PM
    #5088
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I got my 13 in may 15 with 12,000 for 24g or so totally stock sport
  9. Nov 28, 2017 at 3:02 PM
    #5089
    Skootter14
    Jeremy
    yea, that other one def seems high. I bet the dealer is banking on the S/C up'ing the price to an unsuspecting buyer.
    GT7[QUOTED] likes this.
  10. Nov 28, 2017 at 3:05 PM
    #5090
    Skootter14
    Jeremy
    called gadget today to see about running the UCON without the S/C and the only thing he added, was to also do the injectors with the cam and thermostat w/ ucon and there will be no issues. Run that for a couple days then install the S/C. Not that this has to all be done in 3 different stages, but he agreed that any trouble shooting would be substantially reduced doing it this way and agreed with the idea.
    oni06, jojotoo, Torspd and 1 other person like this.
  11. Nov 29, 2017 at 7:22 AM
    #5091
    ThomasMore66
    Dallas/Fort Worth & Durango
    But now you have so much money in it...
  12. Nov 29, 2017 at 7:26 AM
    #5092
    GT7
    Grant
    Phoenix
    2013 DCLB
    Haha that wasnt me saying I would sell it. Thats me sayin the truck for sale is too much
  13. Feb 26, 2018 at 4:59 PM
    #5093
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Hey all! I’m sure it’s an asked like 1000 times but I’m due for plugs and wondering which ones I should go with. Also, how much of a PITA is it to do the plugs on a supercharged motor? It seems like three of them could be real hard to get to
  14. Feb 26, 2018 at 5:11 PM
    #5094
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Stock plugs that come with the kit are denso ikh22 but most people go to the ikh24 because it’s a colder plug.
    If you have swivel attachments I’m told you can change the plugs with out taking the supercharger off.
    Tacoma SS[QUOTED] likes this.
  15. Feb 27, 2018 at 11:57 AM
    #5095
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Yes this is true I did it about a month ago. One or two of them was PIA but not too hard since its on top. It's a blind reach in there and I think I actually used an jointed and ball together to get in there with a long extension.
  16. Feb 27, 2018 at 12:02 PM
    #5096
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Sounds like a decent price to me especially with camper shell and 4wd. I paid 27k for mine with 70k on it and it wasn't from TX so it had a bit of rust.
    Check the exhaust diameter extra bonus if the performance exhaust is installed. It has a bigger outlet and was sometimes also added when people splurged on dealer option.
    I think you can look here to see when S/C and if any other options were installed by using VIN - https://www.toyota.com/owners/vehicle-specification
  17. Feb 27, 2018 at 1:17 PM
    #5097
    Tacoma SS
    Denver
    Those em effers are pricy! Should I pick them up from a Toyota dealer or can I just buy them online somewhere? Also, do you know if they come gapped to the right amount or will I have to adjust them?
  18. Feb 27, 2018 at 1:18 PM
    #5098
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    They should come close, but always check the gap before installing plugs. Who knows if someone dropped them or not.
  19. Feb 27, 2018 at 1:33 PM
    #5099
    Tacoma SS
    Denver
    Any idea what the gap should be? I would assume it’s different than factory
  20. Feb 27, 2018 at 2:45 PM
    #5100
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Most modern plugs (at least the Iridiums I've used) are pre-gapped precisely. Be careful if you decide to adjust the gap.
    Tacoma SS likes this.
