TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Sep 1, 2020 at 4:53 AM
    #5241
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    george2pak and Torspd like this.
  2. Sep 1, 2020 at 3:21 PM
    #5242
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  3. Sep 9, 2020 at 2:17 PM
    #5243
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    Try superchargersonline.com
    george2pak[QUOTED] and rmepilot like this.
  4. Dec 13, 2020 at 2:03 PM
    #5244
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    In the center of this picture, that white/grey connector with black electrical tape around it. To the top/right of it is another wire cable that leads down into the bay. What is that connected to? Mine isn't connected, and has electrical tape wrapping it up.
    EricT likes this.
  5. Dec 13, 2020 at 3:05 PM
    #5245
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Acis, deleted system when the supercharger is put on.
    It's normal
    scootter82[QUOTED] likes this.
  6. Jan 18, 2021 at 3:10 AM
    #5246
    RocketTaco808
    RocketTaco808 Resident Telescope Expert
    Maui
    08 4wd URD MKIII.1 6-Speed
    Poly bushings all around, URD Headers, Composite Carbon Stage II clutch, TRD short throw, URD Spec U Exhaust, Tow package, Bunny Trails, Fairy Dust, Triple Dynamat Insulated, Blood, sweat, grit and some good old fashion elbow grease.
    Bwahahahahahahahahaahhaahhahaha
  7. Jun 30, 2023 at 3:05 PM
    #5247
    Suckafartout
    Suckafartout Well-Known Member
    2008 Tacoma trd sc
    Supercharged
    Thanks!!!
  8. Jun 30, 2023 at 3:26 PM
    #5248
    Suckafartout
    2008 Tacoma trd sc
    Supercharged
    I’m gonna try. Rn
    XPOTRPR[QUOTED] likes this.
  9. Jun 30, 2023 at 3:46 PM
    #5249
    Suckafartout
    2008 Tacoma trd sc
    Supercharged
    So what does this mean that they didn’t do something right at magnumsson? And told us to hook it up wrong I’m the directions? and I should change around, I don’t have a boost gauge, so just run the fuel pressure regulator Line straight into the capped off boost port? Clamp annd cap and call good?
  10. Jun 30, 2023 at 4:17 PM
    #5250
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nope. You need a to tune for the change if you want to run it like that and at minimum you need a boost gauge with preferably an AFR gauge while tuning.
    If you don't have either or don't touch your setup.
    Suckafartout[QUOTED] likes this.
  11. Jun 30, 2023 at 4:45 PM
    #5251
    Suckafartout
    2008 Tacoma trd sc
    Supercharged
    I have the old plx system, plugs in the obd2 port… so if I did switch it i should put it back, huh? Only take a minute. Should I not even started up and see what happens? lol real dummy here
  12. Jun 30, 2023 at 5:02 PM
    #5252
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
  13. Jun 30, 2023 at 6:06 PM
    #5253
    Suckafartout
    2008 Tacoma trd sc
    Supercharged
    Thanks I’ve seen this one, I’m basically there but have been sold and heard here don’t mess with what works. So if I buy the rebuild kit and do it all new bearings and everything wait until it starts making weird sounds? I’m scared I’ll mess it up. Really honestly.
  14. Apr 26, 2025 at 2:41 PM
    #5254
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    That answered my question finally lol! Been on the fence about the URD intake with my S/C…lol…how did you like the URD TCAI set up with your S/C?
  15. Apr 26, 2025 at 2:46 PM
    #5255
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It was not ideal at all. I didn't like it because it was one issue after another it seemed like. I eventually picked up a TRD CAI and called it a day.
    Norton and inwood customs like this.
  16. Apr 26, 2025 at 2:47 PM
    #5256
    TegoTaco
    Ontario, Canada
    Issues in what way?
  17. Apr 26, 2025 at 2:48 PM
    #5257
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's been so many years since I ditched the setup that I don't remember anymore. If I remember right it was a lot of rubbing in the front to the point where I worried it would damage the LTR fins.
  18. Apr 26, 2025 at 2:51 PM
    #5258
    TegoTaco
    Ontario, Canada
    Currently have the Volant intake to the snorkel along with the ram air piece to the front of the hood. Maybe I’ll just see how it goes with the S/C and my current intake.
  19. Apr 26, 2025 at 4:01 PM
    #5259
    Dingus
    Dingus Well-Known Member
    West slope of the Sierra
    2015 4x4 DCLB TRD Sport
    Exhaust/Supercharger/OME lift
    I have 56k on my 2015 sport long bed w/ SC. It is running perfect with regular maintenance! It pulls my Casita trailer to the high altitude campsites with no bitching.
  20. Apr 27, 2025 at 6:54 PM
    #5260
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Snorkels are a big no no when it comes to a boosted setup because it has too many bends which can cause MAF issues and lost boost. I would be careful with that.
