TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Oct 12, 2015 at 3:00 PM
    #521
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Gotcha...I just figured there'd be a crush gasket there like from the y to the manifold.
  2. Oct 12, 2015 at 3:07 PM
    #522
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea the donut gasket looks super crushed and used, I pulled it off and was like...fuck...I didn't get a replacement, but as soon as you put it on the new stuff and start tightening up, everything goes together just fine
  3. Oct 23, 2015 at 6:01 PM
    #523
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So I just got my hands on a trd boost gauge......quick question....I got a hard but flexible rubber line. I plan on using it to run from the brass tube on the back of the gauge to the brass port on the s/c.
    My question is.....will it work? It shouldn't collapse because it is rigid.....it's just not the nylon tubing like what is normally used.
  4. Oct 23, 2015 at 8:02 PM
    #524
    VolcomTacoma
    Jeff
    NorCal
    Should be fine, I dont see why not. Maybe toss some hard pipe around where you punch through the fire wall if you really wanna be safe
  5. Oct 23, 2015 at 8:09 PM
    #525
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    That was gonna be my next delema.....I've seen a couple threads of this install. People have gone through the fire wall the hood latch cable grommet to be exact....looks like in the pic it's by the steering column as well. Delema being if the rubber line I have is too thick to fish through the hole.
  6. Oct 23, 2015 at 8:18 PM
    #526
    VolcomTacoma
    Jeff
    NorCal
    Ok so go through where your main wire harness punches through. Trust me, there is pleeeeeennntty of room there. First time its always tight hehe. TWSS. In your case, put a coat hangee partly into the tube, electrical tape the shit out of it so its a smooth transition from tube to hanger....poke it through from engine side, and start pulling once you get to the tubing side. Works great with 2 people, but you can do it yourself if you go slowly and run back and forth a bunch. Careful you dont go in to much before checking under the pedals, you might accidentally puncture one of the wire harnesses under there
  7. Oct 23, 2015 at 8:23 PM
    #527
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Gotcha....when I go to do it, I'll look for that access.
  8. Oct 23, 2015 at 8:24 PM
    #528
    VolcomTacoma
    Jeff
    NorCal
    Its right on the wheel well, its probably a couple inches across, with a big ass bundle of wires punching through.
  9. Oct 23, 2015 at 8:37 PM
    #529
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol, ok. Kinda in line with the coin holder as I come through the wall from the engine side?
  10. Oct 23, 2015 at 8:40 PM
    #530
    VolcomTacoma
    Jeff
    NorCal
    Yup. Just get your line all set up and go in from the engine side, once you get about 6" of the coat hanger through, grab a flash light and look underneath for it. I've found if you lay on your back looking up at the steering wheel, its easier to twist over and see in to the corner. Then just find your coat hanger and start pulling.
  11. Oct 23, 2015 at 8:48 PM
    #531
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Cool....sounds easy enough. Just waiting on my gauge mount to come then I'll tackle it
  12. Oct 24, 2015 at 6:02 AM
    #532
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    That's the same way I ran the wires for my AFR guage, worked fine. Not sure if the rubber grommet is still waterproof though
  13. Oct 24, 2015 at 8:17 AM
    #533
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Did you make the hole bigger
  14. Oct 24, 2015 at 8:51 AM
    #534
    Tacoma SS
    Denver
    No, I just slid the wire right alongside of the harness. But I don't know if that could have left a little gap or something like that that water could get through
  15. Oct 24, 2015 at 11:41 AM
    #535
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I see......so I just found exactly where you guys are referring to.....I'm assuming you guys had to unbolt a couple of the brackets ......I believe one was the brake fluid....have to double check. For hand clearance??
  16. Oct 24, 2015 at 11:55 AM
    #536
    VolcomTacoma
    Jeff
    NorCal
    Ok first of all, that grommet probably isn't water proof in the first place, maybe water resistant, but if are fording rivers and have your engine bay submerged up to that grommet, you have other problems, so I wouldn't worry about a little gap. When I pulled everything out of my 2011, i had a good sized gap in there lol, just moved some wires around and it closed up a bit.
  17. Oct 24, 2015 at 12:00 PM
    #537
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah....I can see that....about the water. I think because of the s/c the couple of hoses and brackets that are now there is gonna make it a pain.....but itl get done.
  18. Oct 24, 2015 at 12:41 PM
    #538
    Tacoma SS
    Denver
    I had to unbolt the bracket for the supercharger coolant reservoir but that's it. It's not that bad
  19. Oct 24, 2015 at 12:51 PM
    #539
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Cool....thanks John
  20. Oct 24, 2015 at 12:52 PM
    #540
    Tacoma SS
    Denver
    No problem, good luck :thumbsup:
