TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 11, 2015 at 8:07 PM
    #661
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea thats on my list as well. Mostly cosmetic IMO but I like the way it cleans up the engine bay as well
  2. Nov 11, 2015 at 8:15 PM
    #662
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I just looked at the two clutches you recommend....I keep seeing/reading that the throw out bearing should be upgraded....the urd clutch gives you the opportunity to buy/upgrade it at a cheaper price if you buy it with a urd clutch....looking at the SPEC clutch it doesn't say anything about upgrading the throw out bearing.....I've never worked on a clutch so it's gonna be new to me. Should the throw out bearing be upgraded regardless of what clutch you put in???
  3. Nov 11, 2015 at 8:21 PM
    #663
    VolcomTacoma
    Jeff
    NorCal
    Yes. Upgrade the throw out bearing regardless of what clutch. It is a known weak point Toyota just wont fix.
    Torspd likes this.
  4. Nov 12, 2015 at 12:46 AM
    #664
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I agree I don't think it helps direct air I smiply wanted it for he fact that it cleans up that gap very nicely.
    Also that's not a logo on there I sticker slapped it with a sticker her sends with
  5. Nov 12, 2015 at 5:07 AM
    #665
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm curious if Bulletproof will make one without the opening for the hood latch. Hmm...
  6. Nov 12, 2015 at 5:09 AM
    #666
    StOrMyThEtAcO
    Cody
    CO
    All of them
    How will your hood ratchet then :boink:
  7. Nov 12, 2015 at 5:13 AM
    #667
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think Tor has fiberglass with hood pins or some such. Positive on the glass, but not about how he secures it.
  8. Nov 12, 2015 at 5:33 AM
    #668
    StOrMyThEtAcO
    Cody
    CO
    All of them
    Ahhh that makes sense then
  9. Nov 12, 2015 at 7:13 AM
    #669
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is the easy part. How will I support the hood though, since the prop will be covered? Hmmmm. (Hood stuts aren't supposed to be used with fiber glass hoods.)
    Aerocatch = Win
  10. Nov 13, 2015 at 10:53 AM
    #670
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I thought you had an AFR gauge? Do you not?
  11. Nov 13, 2015 at 11:08 AM
    #671
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Might be time to install them and see what is going on....soot is definitely rich.
  12. Nov 13, 2015 at 11:23 AM
    #672
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Since the fuel gauge is installed, might as well hook it up temporarily at least. To see where it is. It might be fine. Could just be that the reflash is really rich.
  13. Nov 13, 2015 at 2:38 PM
    #673
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Most likely, but doesn't rule anything out. When Torspd was running turbo with the stock ecu he was 'rollin coal' as it was super rich (maxed out the scale on the aem gauge) However I would request a day vid or have a buddy drive behind you to determine the color and thickness of the smoke to help in diagnosing the issue. However is the driveability? How are the fluid levels?
  14. Nov 13, 2015 at 4:36 PM
    #674
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I've always modulated the throttle while watching the afr when I rlly need to move out. Well, maybe it took a couple weeks to train myself to do that instead of mashing the gas.
  15. Nov 13, 2015 at 4:48 PM
    #675
    VolcomTacoma
    Jeff
    NorCal
    Well, he's got me on ignore anyways, but Christian if you ever got around to installing your URD 2.85 pulley instead of whining about it, it does help bring your AFR up. Mine never dips down below 10.5 these days, at full WOT it usually does a quick dip to the mid 10s and then sits around 11-11.5. But I guess you can't check your AFR anyways...
  16. Nov 13, 2015 at 5:10 PM
    #676
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    What are you getting for mpg with the 2.85?
  17. Nov 13, 2015 at 5:37 PM
    #677
    VolcomTacoma
    Jeff
    NorCal
    Shitty, since I'm on the throttle so much. Look, guys, your MPG isn't hurt by the supercharger, its hurt by putting your foot to the floor.
  18. Nov 13, 2015 at 5:39 PM
    #678
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    ^^^ Plain and simple. With great power comes great responsibility. Or so I was told. ;)
  19. Nov 13, 2015 at 5:42 PM
    #679
    VolcomTacoma
    Jeff
    NorCal
    @Torspd IIRC Someone checked and found their is slim to no parasitic drag off the SC, so you would get normal power and MPG numbers as long as you stayed in a vacuum and out of boost.
    Shit I got on it yesterday and watched my gas gauge drop from like 1/3 to just about 1/4 tank! But that was pulling hard from a dead stop and then pegging out on a straght away :anonymous:
  20. Nov 13, 2015 at 6:25 PM
    #680
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    just Toyota attorneys covering toys ass
