TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 26, 2015 at 10:32 PM
    #821
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    big sur
  2. Nov 26, 2015 at 10:56 PM
    #822
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    cuz warm air ftw
  3. Nov 27, 2015 at 4:40 AM
    #823
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    You guys with the afe cai........do you keep that small plug at the bottom on or off???
  4. Nov 27, 2015 at 5:06 AM
    #824
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I have mine off for now, didnt really notice much difference
  5. Nov 27, 2015 at 5:10 AM
    #825
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I just threw it on when I installed it.....never really thought of it..I can't believe it would make too much of a difference
  6. Nov 27, 2015 at 7:37 AM
    #826
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It creates a swirl action when removed.
  7. Nov 27, 2015 at 8:13 AM
    #827
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Is it beneficial though? You think water can make its way in through normal drivin?
  8. Nov 27, 2015 at 8:37 AM
    #828
    ThomasMore66
    Dallas/Fort Worth & Durango
    Had it out and watched air intake temp on the UG for a few days this summer. Put it back in and watched air temps. It was always a few (<5) cooler with it in and running down the highway. It stayed in. Not sure it matters that much. Cooler must be better, right?
  9. Nov 27, 2015 at 8:47 AM
    #829
    ThomasMore66
    Does someone have a diagram for where you pulled power for your gauges? Dimming with lights? I'm over on Cravenspeed looking at the steering column gauge pod. Need to finally get gauges. I still like the idea of the drivers post mount, but you guys have convinced me quality is poor.
  10. Nov 27, 2015 at 8:56 AM
    #830
    ThomasMore66
    The lighted knob. Thanks for reminding me of something else I haven't done.
  11. Nov 27, 2015 at 9:42 AM
    #831
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
  12. Nov 27, 2015 at 10:22 AM
    #832
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I used the pillar pod from Lotek, I just think it looks cooler. On that, you do have make the holes a tad bigger (demmel) no biggy at all. The problem I had was with the pod mount in my hand, I matched the handle to it to see where I had the trim. What I should've done was snap the mount in place then match the handle to it to see where I had to trim. So that being said....I trimmed a little too much and you can see where I screwed it up....I will be ordering a new one.
    For my mechanical boost gauge, I ran the power wire through the firewall with the boost hose. Boost hose went to the s/c obviously. The power wire went to the left front headlight fuse with a add-a-fuse fusetap. Fast , simple, no wire crimping. If you do that, the fuses under the hood are low profile mini fuses. For the ground wire , I ran it down the pillar. Removed the door sil and the plastic by the left foot (easy) there is a bolt I unscrewed and used to connect the ground.
    There is a write up I used I can send a link
  13. Nov 27, 2015 at 12:49 PM
    #833
    ThomasMore66
    Send the link. Did you get an AFR gauge too?
  14. Nov 27, 2015 at 12:58 PM
    #834
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Well worth the money
  15. Nov 27, 2015 at 1:03 PM
    #835
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Atleast the lotek doesn't block any idiot lights ;)
  16. Nov 27, 2015 at 1:10 PM
    #836
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    the pics are deceiving then.... Looks like most are blocked. Despite shitty fitment, I wouldn't trade my low tech :)
  17. Nov 27, 2015 at 1:40 PM
    #837
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    No, I'm just running the boost gauge. On the hole a bought a cap that lotek sells to plug the hole. It's like $3.99. If I did the whole smaller pulley/bigger fuel pump thing I would but since I'm not I don't see the point. Honestly no point in the boost either other that it does look cool and I guess it's nice to see how much boost your getting when pushing it.
  18. Nov 27, 2015 at 1:52 PM
    #838
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    that's odd..... U threw on what, a $4000 part and don't care if its working properly? Also don't care if the truck leans out for any reason? Don't wanna see any possible vac leak warnings?
    They are not just for bragging but can also help diagnose problems.
    Ur a brave soul....
    Just throw some electrical tape over the check engine light cuz its just for show.
    Torspd likes this.
  19. Nov 27, 2015 at 1:57 PM
    #839
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    this doesn't surprise me. Just don't reproduce please :)
  20. Nov 27, 2015 at 2:04 PM
    #840
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    engine, trans, alternator, etc are OEM as well..... But we have nannies for them
