TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Nov 27, 2015 at 5:36 PM
    #861
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    My URD Y pipe came with an installed bung already. On the passenger side. Off the top of my head I think I connected everything, one of the wires you can use to tap into the dimmer switch, blue I think, but its really not that bright at night.
  2. Nov 27, 2015 at 6:32 PM
    #862
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah now that you say that I think my URD pipe had a bung too....I'll crawl under there tomorrow and double check.
    For the main power wire....you want it connected to a source that has power all the time(as soon as you turn the ignition on) right?? Or is the main power wire just for the light?
    My mechanical boost gauge I have powered to a fuse on one of my headlights so the light comes on only when I turn the headlights on. It always works though because of the vacuum hose.
  3. Nov 27, 2015 at 7:08 PM
    #863
    VolcomTacoma
    Jeff
    NorCal
    Wait, I was thinking my speed hut gauge. I cant quite remember the AFR gauge. I usually fuse tap power from the rear window fuse. Its a 10 IIRC, that way if it pops I'm not killing anything vital.
  4. Nov 27, 2015 at 7:10 PM
    #864
    VolcomTacoma
    Jeff
    NorCal
    If your URD Y pipe is new within the last year or so, and 4x4, (not sure on 2wd version) URD started adding the bung to all of them after much demand. Its on the passenger side. I just routed the sensor wire across the firewall in the engine bay and ran it down behind the heat shielding and in to the bung, keeping it away from hot stuff. Careful when reaching your hand in there, the heat shielding is thin and sharp as fuck.
  5. Nov 27, 2015 at 7:17 PM
    #865
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yup, sounds easy enough. I'll crawl underneath and check mine tomorrow. Looks like I'll be adding a gauge here soon at some point. Thanks and thanks to @Justus for the good info and advice.
    Justus likes this.
  6. Nov 27, 2015 at 7:35 PM
    #866
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    meh, that Nabisco kid is an asshole
  7. Nov 27, 2015 at 7:42 PM
    #867
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol.....you guys are alright:thumbsup:
    Justus likes this.
  8. Nov 27, 2015 at 7:48 PM
    #868
    VolcomTacoma
    Jeff
    NorCal
    Justus[QUOTED] likes this.
  9. Nov 28, 2015 at 2:45 AM
    #869
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rpm gauge? Nah. Don't need that shit either. Remove that fuel gauge to while you're at it. Really clean up the dash.
    BTW, AEM has a new AFR gauge out. Reads leaner and richer than their last gauge, as well as shows AFR's in the hundredths instead of just tenths, like all others do.
    Had Memario had a boost gauge at the time of his S/C install, he'd have known immediately that there was a problem with his bypass valve being stuck open.
    Had another had one, he'd have known that he had a vacuum leak at a well known TRD boost port.
    With age and heat cycles, OEM vacuum lines degrade and crack. Then they leak. Then they cause idle, driving, and misfire issues.
    Gauges aren't once and done. They give you realtime data of engine functions. Once you know the reference points for what your gauges monitor, it becomes quick and easy to spot a problem or potential problem.
    Although....there is that saying that ignorance is bliss......
    SonnyBones, Biscuits and Justus like this.
  10. Nov 28, 2015 at 4:02 AM
    #870
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol, I got it man thanks. :bowdown:
  11. Nov 29, 2015 at 6:03 PM
    #871
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Alright so again guys thanks for the advice. I completely see why the afr guage is highly recommended. I crawled under to double check my y-pipe.....no extra bung. My plan is once I get the gauge to have a bung welded in in the collector of the y just before the connection to the catback. I found another thread that where a member did it in that spot. Also, in his pic he has the bung welded at a slightly downward angle and not straight into the collector. To let any possible condensation build up drip off the sensor and not let it sit there potentially damaging it.
    @VolcomTacoma did you fuse tap your power behind the coin tray or under the hood in the main fuse box?
  12. Nov 29, 2015 at 6:48 PM
    #872
    VolcomTacoma
    Jeff
    NorCal
    Behind the coin tray.
  13. Nov 29, 2015 at 8:20 PM
    #873
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Sweet...thanks
  14. Nov 29, 2015 at 8:22 PM
    #874
    VolcomTacoma
    Jeff
    NorCal
    IIRC This one is the one I normally use because it something non-critical. Either windshield fluid or window regulator. Can't quite remember off the top of my head.
  15. Nov 29, 2015 at 8:23 PM
    #875
    VolcomTacoma
    Jeff
    NorCal
    Not my pic BTW. That connector would be sealed lol.
  16. Nov 29, 2015 at 8:26 PM
    #876
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Cool......lol....am I looking at the actual fuse you taped or the one circled....or either one?
  17. Nov 29, 2015 at 8:28 PM
    #877
    VolcomTacoma
    Jeff
    NorCal
    The one I circled is the one I usually tap for ignition switch power. That one is power to windshield wipers...so if they stop working and gauges stop, check your fuses :D
  18. Nov 29, 2015 at 8:30 PM
    #878
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Cool thanks again
  19. Nov 30, 2015 at 6:30 AM
    #879
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have the bung welded in a position between 10 o'clock - 2 o'clock. I am not sure jf that is what you were saying, that is why I am clarifying.
  20. Nov 30, 2015 at 6:55 AM
    #880
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah I saw that too....I interpreted that based on if it's going in a manifold and the route of the pipe leaves you putting it in a 10/2 like you said. I don't know if I verbalized that correctly. In the pic I found in the thread I was referring to the guy had it just tilted down just a little....I believe that would accomplish the same thing no?? I'll find it and post it to see what you think. Any help is definitely appreciated.
