TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Dec 2, 2015 at 3:26 PM
    #901
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    spit on it
  2. Dec 2, 2015 at 3:28 PM
    #902
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    This.
    SC2SC and Justus[QUOTED] like this.
  3. Dec 2, 2015 at 3:28 PM
    #903
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Cool thanks.
  4. Dec 2, 2015 at 8:48 PM
    #904
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yeah, walk into the garage and it starts whiring.
  5. Dec 2, 2015 at 8:51 PM
    #905
    VolcomTacoma
    Jeff
    NorCal
    So new oil in the engine (Mobil 1) and Redline Mt90 in the trans really made a bit of difference. Seems a hair smoother...black shit came out of both, So I'm guessing it was a good time. Trans plug magnet had a boat load of debris attached...probably what my clutch turned into :rofl:. Oh yea, that reminds me, time to order a URD Stage 3! Since I'm a URD fanboy and all, might as well stick with the club.
    1truckdriver and Torspd like this.
  6. Dec 2, 2015 at 8:54 PM
    #906
    ThomasMore66
    Automatic FTW!
  7. Dec 2, 2015 at 8:56 PM
    #907
    VolcomTacoma
    Jeff
    NorCal
    True story. Fingers crossed a new clutch makes all my issues go away :D. Then i'll be 'Man pedal FTW'!
  8. Dec 2, 2015 at 8:56 PM
    #908
    ThomasMore66
    So the TRD OR only has the electronic locker. Even in Auto LSD the nanny kicks in if you attempt to drift the truck. So annoying.
  9. Dec 2, 2015 at 8:57 PM
    #909
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    #abskillswitch :D
    Justus likes this.
  10. Dec 2, 2015 at 8:58 PM
    #910
    ThomasMore66
    Will that handle it?
  11. Dec 2, 2015 at 9:18 PM
    #911
    ThomasMore66
    Abs kill installed?
  12. Dec 2, 2015 at 9:27 PM
    #912
    StOrMyThEtAcO
    Cody
    CO
    All of them
    @Moose1988 did the locker and the ABS kill switch
    I plan to do both as well so I can has one or the other on alone.
  13. Dec 2, 2015 at 9:43 PM
    #913
    StOrMyThEtAcO
    Cody
    CO
    All of them
    Yeahh I havnt needed it either but I know one day I will so I want to do it
    I need to do the anytime locker SOON!
    Just need to get insight from someone that did it with a stick
  14. Dec 3, 2015 at 4:21 PM
    #914
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    But did sire order a flywheel? o_O
  15. Dec 3, 2015 at 6:10 PM
    #915
    VolcomTacoma
    Jeff
    NorCal
    Tonight I'll be ordering the full package. Flywheel/Clutch combo with Throw out bearing upgrade and all ARP bolts and all that.
    Let me ask you this, @Torpsd What's the difference between the Stage 2 and Stage 3? I'm not looking for a super racey clutch, just something that will engage a bit quicker and be able to handle the HP while holding up to some slippage and not turning to glass in another 5k miles. When I pound on it, I slip it alot, I know this. I realize I need to get better at it, but I'd like to order something that will not get trashed quickly.
  16. Dec 3, 2015 at 6:17 PM
    #916
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I had an exedy clutch, stage 3, and it chattered quite a bit. Do the replacements for the Tacoma chatter too?
  17. Dec 3, 2015 at 6:20 PM
    #917
    VolcomTacoma
    Jeff
    NorCal
    :shrug: Your guess is as good as mine! I don't mind chatter, I was just talking to a buddy at work who said he drove a friends car that had a stage 3 in it and it bucked like a bronco when he tried to drive normally...it only worked great when he dumped the clutch on a full pedal or slipped it for 10 minutes lol. That's what worries me lol.
  18. Dec 3, 2015 at 6:43 PM
    #918
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    The Cobalt was ok to drive normally. It grabbed really good so if you had poor clutch control, it'll let you know.
  19. Dec 3, 2015 at 6:46 PM
    #919
    VolcomTacoma
    Jeff
    NorCal
    Which, I basically relearned clutch on the Tacoma, having mostly ridden motorcycles, so my clutch control isn't the best in the truck still.
  20. Dec 4, 2015 at 8:48 AM
    #920
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the URD is a sprung hub, it will make engagement easy. Even with a course material disk.
    URD Stage 3 is a higher torque capacity clutch. Which will handle the added vehicle weight and engine torque.
