TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Dec 4, 2015 at 9:15 AM
    #921
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Awesome. Ordered the Stage 3 with lightweight flywheel and throw out bearing upgrade and ARP studs.
    Biscuits, JuanitoBonito and Torspd like this.
  2. Dec 4, 2015 at 7:26 PM
    #922
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Got my AEM afr gauge today. Just double checking, the little female adaptor is the actual bung I give my exhaust guy to weld into my y-pipe collector...yes???
  3. Dec 4, 2015 at 7:31 PM
    #923
    VolcomTacoma
    Jeff
    NorCal
  4. Dec 4, 2015 at 7:36 PM
    #924
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What I figured.....you gonna do that clutch yourself after all??
  5. Dec 4, 2015 at 7:56 PM
    #925
    VolcomTacoma
    Jeff
    NorCal
    I don't know. Unsure if I have the right tools to do it or not. Need to research more...
  6. Dec 5, 2015 at 9:26 AM
    #926
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    17mm deep socket; 14mm deep socket; vacuum cap for the clutch line once removed from the truck; knipex parallel pliers or 10mm flare nut wrench to remove the clutch line; various extensions; pic or similar to remove harness from top of trans; 14mm wrenches for drive shaft hardware; trans jack of some sort.
  7. Dec 5, 2015 at 10:08 AM
    #927
    VolcomTacoma
    Jeff
    NorCal
    ^Awesome. So the clutch/flywheel/throw out bearing are all bolt in parts? Nothing gets pressed in? What about clutch adjustment or something like that? Anything special about the job i should know? Ive never touched a trans before in my life, so this could get interesting lol
  8. Dec 5, 2015 at 2:44 PM
    #928
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    "Clutch adjustment," will be with the black piece which is attached to the clutch master cylinder, underneath the clutch pedal. Basically you adjust it, IF NEEDED, to have a small air gap. Between the tip of it and the pedal.
    The TOB is easy and self explanatory. Just clean and add new grease to the joints. You'll see when you're in there.
  9. Dec 5, 2015 at 2:48 PM
    #929
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It should come with an alignment tool, the clutch. If not, a deep 19mm in an extension will do the trick.
    Test fit the pressure plate onto the flywheel, prior to installation. To make sure the powder coating of the pressure plate, doesn't interfere with the aligning dowel pins of the flywheel. If it cannot easily slide onto the flywheel, remove the powder coating in those dowel pin holes. **********!!!!!!!!!
  10. Dec 5, 2015 at 3:23 PM
    #930
    VolcomTacoma
    Jeff
    NorCal
    !!!!!!!!!!!!! Ok lol. Still not sure if im gonna be doing it, garage is currently set up for the puppy and a bunch of other crap, so I cant quite park the truck in it to work on it. Gonna get a couple quotes from nearby shops and see if its affordable first. Dealer quoted $740 for installing all 3, but thats just the local dealer.
  11. Dec 5, 2015 at 4:08 PM
    #931
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Do you have to get the flywheel or is it just highly recommended??
  12. Dec 5, 2015 at 4:19 PM
    #932
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only if yours has bad deep heat spots.
  13. Dec 5, 2015 at 4:44 PM
    #933
    VolcomTacoma
    Jeff
    NorCal
    I don't know what mine is like, but ill give the lightweight a try...i read that its better for acceleration, but at a loss of torque, which since I'm not towing anythung, I'm ok with.
  14. Dec 5, 2015 at 4:59 PM
    #934
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I just very well figured that if you're swapping out the clutch , might as well do it all.
  15. Dec 5, 2015 at 5:16 PM
    #935
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I prefer the light weight. Less reciprocating mass = free'd up ponies.
  16. Dec 5, 2015 at 7:14 PM
    #936
    VolcomTacoma
    Jeff
    NorCal
    Downsides?
  17. Dec 6, 2015 at 1:08 AM
    #937
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Stalling?
    Mehby?
    Total ponder
  18. Dec 6, 2015 at 5:14 AM
    #938
    VolcomTacoma
    Jeff
    NorCal
    moar throttle?
  19. Dec 6, 2015 at 8:27 PM
    #939
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Better modulation
  20. Dec 6, 2015 at 8:31 PM
    #940
    VolcomTacoma
    Jeff
    NorCal
    Touché
