TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Dec 28, 2015 at 3:03 PM
    #1061
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    not sure havent done it myself
    Tacoma SS[QUOTED] likes this.
  2. Dec 28, 2015 at 3:09 PM
    #1062
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    I like the little video on your build page. What size pulley did you drop to and how much of a difference did it make?
  3. Dec 28, 2015 at 3:17 PM
    #1063
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    thnx 2.85 ....... it woke things up nicely.
  4. Dec 28, 2015 at 3:20 PM
    #1064
    Tacoma SS
    Denver
    How difficult was the install? Did you purchase the special tools from URD?
  5. Dec 28, 2015 at 3:25 PM
    #1065
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I had a couple buddies with me and it was a pita. But some have a tough time while others dont. The urd tool works good.
    smaldo76 likes this.
  6. Dec 28, 2015 at 3:27 PM
    #1066
    Tacoma SS
    Denver
    I wonder if there is anyone in Colorado that has the URD tool that would let me borrow/have their pulley tool. I really don't feel like buying one and only using it once haha
  7. Dec 29, 2015 at 10:56 AM
    #1067
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    You will need it later when switiching to 2.7 pulley lol.
    Valve body will not realy affect your off roading but the shift from 1st to second can be harsh and you'll have to egt use to it.
  8. Jan 7, 2016 at 9:09 PM
    #1068
    ThomasMore66
    Dallas/Fort Worth & Durango
    Nothing for the new year? Everybody went away. I'm lonely.
  9. Jan 7, 2016 at 9:17 PM
    #1069
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  10. Jan 7, 2016 at 9:19 PM
    #1070
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Finally got my URD Mark lll exhaust yesterday......back ordered from Black Friday. Itl hopefully go on tomorrow.
    WOODEX M.E., Torspd and GT7 like this.
  11. Jan 7, 2016 at 11:20 PM
    #1071
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    *Flat billed fox hats with red bull "sponsored" stickers
    Totally tubular.
  12. Jan 8, 2016 at 4:53 AM
    #1072
    ThomasMore66
    You are an active little man. When will the truck be "done"?
  13. Jan 8, 2016 at 5:52 AM
    #1073
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With the SPEC-U headers, and non equal length URD Y-pipe, the addition of the MKIII exhaust on @Lucario Runner 's T4R, made a significant "seat of the pants" improvement. According to him. He didn't stop smiling for two hours.
    Lucario Runner likes this.
  14. Jan 8, 2016 at 6:34 AM
    #1074
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol still have a couple things up my sleeve....:spy:
  15. Jan 8, 2016 at 6:41 AM
    #1075
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    The exhaust will be paired up with my current URD competition Y-pipe. As far as headers, if I did them. I'd like to see some reviews on AFE's with the high flow cats. These look sharp.
  16. Jan 8, 2016 at 7:11 AM
    #1076
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Let me clarify on what I wrote earlier. The headers and Y-pipe had been there for a long while. The catback was the newest edition. Even being 3", his truck feels much quicker to him, and much more responsive with comparison to similar throttle inputs.
    I am positive that his N/A 1GR is over 300 lbs/ft of wtq. As of his last dyno before the headers, it was very close to that already.
  17. Jan 8, 2016 at 1:27 PM
    #1077
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    URD Mark lll installed!!! noticeable difference, very glad I made this upgrade. :cool:
    1truckdriver and Torspd like this.
  18. Jan 8, 2016 at 2:28 PM
    #1078
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Yo Juan, Did the URD Y-pipe make your truck noticeably louder? Wanting to get the y-pipe with an extra bung for AFR but kinda like the way my truck sounds now.
  19. Jan 8, 2016 at 3:06 PM
    #1079
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    The Y-pipe in my opinion made it a hair louder. Not very noticeable at all. I can tell because I know my truck.....my fiance (who's always in it) couldn't tell.
    My URD exhaust sounds pretty close to my previous TRD catback. I can tell the rasp I had at times with the TRD is gone completely. With the combo of both URD Y-pipe and Mark lll exhaust it has made a positive improvement.
    The bung I had welded in last month along with installing the afr gauge.
    68vert likes this.
  20. Jan 8, 2016 at 7:20 PM
    #1080
    ThomasMore66
    when do you guys find time to install all this stuff? Between working and commuting, I never seem to find time. Retro's are my next project. Been in the garage for months. Got the fogs installed over Christmas.
    Biscuits likes this.
